DeepStream get cv::mat by
I want to load the GStreamer command line in OpenCV to use hard decoding(example nvn4l2decoder) to get image data for AI inference(my AI SDK not in nvinfer plugin)? What can I do to get the highest performance?
**• Hardware Platform (Jetson / GPU)**xavier nx
• DeepStream Version5.0
• TensorRT Version
The HW decoder output is Nvidia customized format, it can not be used outside DeepStream pipeline. You may try to use pipeline “video src => nvv4l2decoder ==> nvvideoconvert ==> appsink” to output decoded frames outside gstreamer pipeline.
You don’t want to use DeepStream for inferrence, right? So it is not a DeepStream topic.
Just Use HW decoder
openCV can run gstreamer pipeline, but the pipeline must be complete(from src to sink), the pipeline is a closed loop, no video data is available outside the pipeline.
OpenCV has CUDA codec interfaces for video. OpenCV: opencv2/cudacodec.hpp File Reference
This is not DeepStream or even Gstreamer related, you need to refer to openCV resources.
