Jetson Xavier NX
I am running the inference for yolov5x model and the fps is just about 20 fps
. How can I increase the FPS for this model. my deepstream config files are below.
config_infer_primary_yolov5.txt (780 Bytes)
deepstream_app_config_yolov5.txt (3.7 KB)
• DeepStream Version
• TensorRT Version
Here it is, @kayccc
you can use tensorrt tool - trtexec to try profile your onnx model with different batch, e.g.
$ sudo nvpmodel -m 2
$ sudo jetson_clocks
$ /usr/src/tensorrt/bin/trtexec --onnx=yolov5x6.onnx --explicitBatch --workspace=2048 --int8
or
$ /usr/src/tensorrt/bin/trtexec --onnx=yolov5x6.onnx --explicitBatch --workspace=2048 --fp16
is your ONNX model explicitBatch?
@mchi This is is my model input, so I can convert it with --explicitBatch, right?
Looks your model has fixed batch, i.e. 1, you could try TensorRT/ONNX - eLinux.org to modify your model to be dynamic batch, so that you can try higher batch to get better perf
Hi, sorry to ask an off-topic question, but how did you generate the output in both of your screenshots with the Jetpack version etc?
Hi @Icancode ,
did you get your model converted to dynamic batch onnx model?
