• Hardware Platform (Jetson Orin NX)
• DeepStream Version 7.0
• JetPack Version 6 36.3
• TensorRT Version
I have this pipeline in deepstream: yolov8s (PGIE) → LPD (SGIE0) → LPR (SGIE1)
the problem is that the lpd and lpr only detect the license plate if the vehicle is big enough
In the picture above, the license plate is not detected at all, while in the screenshot below it is detected when it gets very close:
Here are my configs:
LPD:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
labelfile-path=/yolov8s/yolov4/usa_lpd_label.txt
model-engine-file=/yolov8s/model/LPDNet_usa_pruned_tao5.onnx_b40_gpu0_int8.engine
onnx-file=/yolov8s/model/LPDNet_usa_pruned_tao5.onnx
int8-calib-file=/yolov8s/model/usa_cal_8.5.3.bin
#tlt-encoded-model=/yolov8s/
tlt-model-key=nvidia_tlt
infer-dims=3;480;640
#maintain-aspect-ratio=1
uff-input-dims=3;480;640;0
uff-input-order=0
uff-input-blob-name=input_1
batch-size=16
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=1
gie-unique-id=1
network-type=0
operate-on-gie-id=1
#operate-on-class-ids=0
#cluster-mode=3
output-blob-names=output_cov/Sigmoid;output_bbox/BiasAdd
input-object-min-height=30
input-object-min-width=40
classifier-async-mode=1
process-mode=2
is-classifier=1
[class-attrs-all]
pre-cluster-threshold=0.01
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
LPR :
[property]
gpu-id=0
model-engine-file=/yolov8s/lpr-model/us_lprnet_baseline18_deployable.etlt_b40_gpu0_fp16.engine
labelfile-path=/yolov8s/lpr-model/labels_us.txt
#custom-parse-dictionary-file=/yolov8s/lpr-model/labels_us.txt
tlt-encoded-model=/yolov8s/lpr-model/us_lprnet_baseline18_deployable.etlt
batch-size=16
network-mode=2
num-detected-classes=3
gie-unique-id=3
output-blob-names=tf_op_layer_ArgMax;tf_op_layer_Max
network-type=1
parse-classifier-func-name=NvDsInferParseCustomNVPlate
custom-lib-path=/ds-config-files/yolov8s/deepstream_lpr_app/nvinfer_custom_lpr_parser/libnvdsinfer_custom_impl_lpr.so
process-mode=2
operate-on-gie-id=2
net-scale-factor=0.00392156862745098
#net-scale-factor=1.0
#0=RGB 1=BGR 2=GRAY
[class-attrs-all]
threshold=0.65
Full config:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=4
square-seq-grid=1
[source-list]
num-source-bins=0
use-nvmultiurisrcbin=1
max-batch-size=4
http-ip=localhost
http-port=9010
sgie-batch-size=40
stream-name-display=1
[source-attr-all]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
latency=100
rtsp-reconnect-attempts=3
rtsp-reconnect-interval-sec=60
select-rtp-protocol=4
[streammux]
gpu-id=0
batch-size=4
batched-push-timeout=30000
width=960
height=544
enable-padding=0
nvbuf-memory-type=4
drop-pipeline-eos=1
live-source=1
attach-sys-ts-as-ntp=0
buffer-pool-size=4
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=1
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=4
[sink1]
enable=1
msg-broker-conn-str=localhost;6379;test
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_redis_proto.so
msg-conv-msg2p-new-api=0
msg-conv-frame-interval=1
msg-broker-config=/ds-config-files/yolov8s/cfg_redis.txt
msg-conv-payload-type=1
source-id=0
sync=0
type=6
topic=test
[sink2]
enable=0
type=3
container=1
codec=3
sync=1
bitrate=2000000
output-file=out.mp4
source-id=0
[sink3]
enable=1
type=4
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8555
udp-port=5511
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=4
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
nvbuf-memory-type=4
config-file=config_infer_primary_yoloV8_nx16.txt
model-engine-file=/yolov8s/model_b4_gpu0_int8.engine
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
[tracker]
enable=1
tracker-width=960
tracker-height=544
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file=config_tracker_NvDCF_PNv2.6_Interval_1_PVA.yml;config_tracker_NvDCF_PNv2.6_Interval_1_PVA.yml
sub-batches=2:2
gpu-id=0
display-tracking-id=1
### LPD model
[secondary-gie0]
enable=1
#model-engine-file=/yolov8s/model/LPDNet_usa_pruned_tao5.onnx_b40_gpu0_int8.engine
gpu-id=0
batch-size=4
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=2;3;5;7
#operate-on-class-ids=0;1;2;3;4;5;6;7;8;9;10;11;12;13;14;15;16;17;18;19
config-file=lpd_yolov4-tiny_us.txt
#config-file=test.txt
#classifier-async-mode=1
# LPR model
[secondary-gie1]
enable=1
gpu-id=0
batch-size=4
gie-unique-id=5
operate-on-gie-id=4
config-file=lpr_config_sgie_us.txt
### VahicleMakeNet Model
[secondary-gie2]
enable=1
gpu-id=0
batch-size=4
gie-unique-id=6
operate-on-gie-id=1
config-file=config_infer_secondary_vehicleMake.txt
# VahicleTypeNet Model
[secondary-gie3]
enable=1
gpu-id=0
batch-size=4
gie-unique-id=7
operate-on-gie-id=1
#config-file=vehicle_typenet_config_sgie.txt
config-file=config_infer_secondary_vehicleType.txt
# VahicleColorNet Model
[secondary-gie4]
enable=1
gpu-id=0
batch-size=4
gie-unique-id=8
operate-on-gie-id=1
config-file=config_infer_secondary_vehicleColor.txt
[tracker2]
enable=1
tracker-width=960
tracker-height=544
sub-batches=2:2
gpu-id=0
[tests]
file-loop=1
