I like minimalism when I’m learning something new. Sharing my minimal example for loading and displaying a specificly formatted video file in Deep Stream 6.0.
If you want, please share minimal examples of other use cases. Or post critiques of mine :)
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GObject, Gst
import argparse
run with command
GST_DEBUG=INFO deepstream_minimal.py --input /opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4
The pipeline is
GST_DEBUG=3 gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 !
qtdemux ! h264parse ! avdec_h264 ! nvvideoconvert ! nveglglessink
if __name__ == '__main__':
parser = argparse.ArgumentParser()
parser.add_argument('--input', '-i', type=str)
args = parser.parse_args()
GObject.threads_init()
Gst.init(None)
pipeline = Gst.Pipeline()
filesrc = Gst.ElementFactory.make("filesrc", "filesrc")
filesrc.set_property('location', args.input)
pipeline.add(filesrc)
qtdemux = Gst.ElementFactory.make("qtdemux", 'qtdemux')
pipeline.add(qtdemux)
avdec_h264 = Gst.ElementFactory.make("avdec_h264", "avdec_h264")
pipeline.add(avdec_h264)
def demuxer_pad_added(demuxer, pad, avdec_h264):
# comment out below to debug inside callbacks
# import pydevd_pycharm
# pydevd_pycharm.settrace()
if pad.name == 'video_0':
demuxer.link(avdec_h264)
qtdemux.connect("pad-added", demuxer_pad_added, avdec_h264)
nvvideoconvert = Gst.ElementFactory.make("nvvideoconvert", "nvvideoconvert")
pipeline.add(nvvideoconvert)
nveglglesssink = Gst.ElementFactory.make("nveglglessink", "nveglglessink")
pipeline.add(nveglglesssink)
Link
filesrc.link(qtdemux)
avdec_h264.link(nvvideoconvert)
nvvideoconvert.link(nveglglesssink)
loop = GObject.MainLoop()
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
pipeline.set_state(Gst.State.NULL)
