Deepstream not running with Flir camera using the statis IP address
• DeepStream Version
5.1
4.5
Xavier NX
question
I am using a Flir thermal camera which is connected to a static IP through an encoder, We can see the stream itself from the IP while the camera is running. But deepstream does not run stable with that camera, The configuration file is as follows:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
#----------Corrected -----------
type=4
#camera-width=640
#camera-height=480
#camera-fps-n=30
#camera-fps-d=1
#camera-v4l2-dev-node=0
uri=rtsp://192.168.1.168:554/hdmi
num-sources=1
select-rtp-protocol=4
If I start the deepstream several times the video will go through. The output from the deepstream is very low quality and laggy in comparison to the original video, here is the output:
[sink2]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
#set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
Regards
We suggest try a gst-launch-1.0 command to make sure the source is valid and stable:
$ gst-launch-1.0 uridecodebin uri=rtsp://192.168.1.168:554/hdmi ! nvoverlaysink sync=0
I am receiving the follwoing output:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://192.168.1.168:554/hdmi
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
(gst-launch-1.0:26558): GLib-ERROR **: 21:29:47.697: Creating pipes for GWakeup: Too many open files
Trace/breakpoint trap (core dumped)
What does this mean? I have another application that is using the Gstreamer. Could that application cause a conflict?
Regards
Please try with only rtspsrc plugin:
$ gst-launch-1.0 rtspsrc location='rtsp://192.168.1.168:554/hdmi' ! fakesink
Deepstream SDK is based on gstreamer so you would need to figure out a valid URIwhic can be plaeyed in gstreamer command successfully. Currently it looks like rtspsrc plugin cannot read the source correctly. Please check with camera vendor to get a valid URI first.
Thanks for your reply
As suggested by the company we can use an encoder to connect the camera. So we receive the data from an encoder. there are two options of TCP and UDP.
We change the settings to UDP and from the first command we are receiving the following:
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
type or paste code here
And from the second one we are receiving the following:
Both of the commands are stopping after Progress: (request) Sent PLAY request.
Regads
I just changed to a USB decoder.
thanks for your responses
