DeepStream not working on RTX3060
• Hardware Platform :** GPU RTX 3060, Intel i5 , 16GB Ram
• OS : Ubuntu 22.04.5 LTS
• DeepStream Version: 7.1.0
• TensorRT Version: 7.0.0
**• NVIDIA GPU Driver Version :**NVIDIA-SMI 580.95.05
Driver Version: 580.95.05
deepstream-app version 7.1.0
DeepStreamSDK 7.1.0
CUDA Driver Version: 13.0
CUDA Runtime Version: 12.2
TensorRT Version: 10.0
cuDNN Version: 0.6
libNVWarp360 Version: 2.0.1d3
• Issue Type: questions
My system can support deepstream or not ?
i try to run example but getiing many issue i try to fix with help chat gpt but not fixed.
if my pc supports which version support can you give me all library version . i want to run yolov8 engine model .
thank you.
DeepStream -7.1 supports RTX3060. but please install the correct tensorrt version.For DS-7.1, it is TRT-10.3.
I recommend you use the lastest DS-8.0.
Here is a repository about YoloV8 works on DS-8.0.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
