• Hardware Platform : GPU RTX 3070, Ryzen 5 3600X, 16GB Ram
• OS : Ubuntu 20.04
• DeepStream Version: nvcr.io/nvidia/deepstream:5.0-20.08-devel-a100
• TensorRT Version: 7.0.0
• Issue Type: questions
Hello, I’m wonderring if anyone could run Deepstream-5.0 on RTX 3070?
I did try with nvcr.io/nvidia/deepstream:5.0-20.08-devel-a100 because I though A100 has the same architect with RTX 3070 - Ampere. Here is the error I got. It’s seem tensorrt does not support the current SW - 86.
oot@adddf63f3acf:/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test1# ./deepstream-test1-app ../../../../samples/streams/sample_1080p_h264.mp4 Now playing: ../../../../samples/streams/sample_1080p_h264.mp4 ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error 0:00:00.365906486 113 0x55e070ee3260 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed 0:00:00.365933236 113 0x55e070ee3260 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild 0:00:00.365941486 113 0x55e070ee3260 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1277 INT8 not supported by platform. Trying FP16 mode. WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1291 FP16 not supported by platform. Using FP32 mode. ERROR: ../nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: ../rtSafe/cuda/caskUtils.cpp (98) - Assertion Error in trtSmToCask: 0 (Unsupported SM.) ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1186 Build engine failed from config file ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:884 failed to build trt engine. 0:00:01.083725847 113 0x55e070ee3260 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1735> [UID = 1]: build engine file failed 0:00:01.083865436 113 0x55e070ee3260 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1821> [UID = 1]: build backend context failed 0:00:01.083873126 113 0x55e070ee3260 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1148> [UID = 1]: generate backend failed, check config file settings 0:00:01.083905645 113 0x55e070ee3260 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<primary-nvinference-engine> error: Failed to create NvDsInferContext instance 0:00:01.083910035 113 0x55e070ee3260 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<primary-nvinference-engine> error: Config file path: dstest1_pgie_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED Running... ERROR from element primary-nvinference-engine: Failed to create NvDsInferContext instance Error details: gstnvinfer.cpp(809): gst_nvinfer_start (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine: Config file path: dstest1_pgie_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED Returned, stopping playback Deleting pipeline
Thank you and best regards,
