Deepstream on Nvidia 3080
We have got 2 new 3080 machines but having issues while installing and running Deepstream on it. So i want to clarify whether deepstream supports with 3080 machines or not
We maitain and test on Tesla series cards and Jetson devices, but user in the forum can run with gtx series cards.
can you paste the error log here?
User-1 Error log:
root@euclid-Z390-D:/home/euclid# deepstream-app -c /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
nvbufsurftransform:cuInit failed : 100
(gst-plugin-scanner:31959): GStreamer-WARNING **: 23:47:56.956: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtrtserver.so: cannot open shared object file: No such file or directory
** ERROR: <create_multi_source_bin:1057>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1132>: create_multi_source_bin failed
** ERROR: <create_pipeline:1296>: create_pipeline failed
** ERROR: main:636: Failed to create pipeline
Quitting
App run failed
User-2 Error log while running deepstream on 3080:
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: Assertion failed: Unsupported SM.
…/rtSafe/cuda/caskUtils.cpp:80
Aborting…
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: …/rtSafe/cuda/caskUtils.cpp (80) - Assertion Error in trtSmToCask: 0 (Unsupported SM.)
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1186 Build engine failed from config file
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:884 failed to build trt engine.
0:17:18.799430598 33 0x55badddd1460 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1735> [UID = 1]: build engine file failed
0:17:18.799555061 33 0x55badddd1460 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1821> [UID = 1]: build backend context failed
0:17:18.799593514 33 0x55badddd1460 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1148> [UID = 1]: generate backend failed, check config file settings
0:17:18.799615724 33 0x55badddd1460 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:17:18.799619877 33 0x55badddd1460 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start: error: Config file path: dstest1_pgie_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Running…
ERROR from element primary-nvinference-engine: Failed to create NvDsInferContext instance
Error details: gstnvinfer.cpp(809): gst_nvinfer_start (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Deleting pipeline
From your first log,
cudaErrorNoDevice = 100
This indicates that no CUDA-capable devices were detected by the installed CUDA driver.
Please check if you install driver properly, you can run sample deviceQuery to check the status, or run nvidia-smi, ls -l /dev/nvidia* to check devices created or not.
Let’s try to fix this first
as for user case 2, Assertion Error in trtSmToCask: 0 (Unsupported SM.), RTX 3080 is with ampere architecture, we support this on version TR7.1 cuda11, not sure about DS if support so far, will check, and get back to you.
