Tried different sample configs with container images nvcr.io/nvidia/deepstream_360d:3.0-18.11 and nvcr.io/nvidia/deepstream:3.0-18.11, but none worked . Does DS 3.0 work with RTX2080?
Insider container:
root@2e436a9b6449:~# deepstream-app -c DeepStream_Release/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt
Unable to set device in gst_nvstreammux_change_state
** ERROR: main:564: Failed to set pipeline to PAUSED
Quitting
App run failed
On the VM:
ubuntu@ds-perception:~$ nvidia-smi
Wed Feb 20 03:46:42 2019
| NVIDIA-SMI 410.48 Driver Version: 410.48 |
| 0 GeForce RTX 2080 Off | 00000000:00:06.0 Off | N/A |
| 20% 43C P0 1W / 225W | 0MiB / 7952MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
