Earlier I was using Deepstream1.0 and now wanted to upgrade to Deepstream2.0 to try out new features!!
Below is the issues which I am facing while doing the upgrade!!
Setup Details:
- Ubuntu 18.04 LTS
- GStreamer 1.14.1
- NVIDIA driver 390.48
- CUDA 9.2
- TensorRT 4.0.1.6
- Opencv 3.4.1
- GPU :- GeForce GTX 1050 (Pascal)
All the gst plugins provided in DeepStreamSDK-2.0_EA_beta1.2/DeepStream_Release/binaries/usr/lib/x86_64-linux-gnu loaded successfully
Issues faced:-
Issue 1:-
$:~/DeepStreamSDK-2.0_EA_beta1.2/DeepStream_Release$ deepstream-app -c samples/configs/deepstream-app/source30_720p_dec_infer-resnet_tiled_display_int8.txt
Unable to set device in gst_nvstreammux_change_state
** ERROR: main:490: Failed to set pipeline to PAUSED
Quitting
App run failed
Issue 2:- When compiling and executing deepstream-test1-app
$:~/DeepStreamSDK-2.0_EA_beta1.2/DeepStream_Release/sources/apps/deepstream-test1$ ./deepstream-test1-app …/…/…/samples/streams/sample_720p.h264
Now playing: …/…/…/samples/streams/sample_720p.h264
*** Unable to set device in gst_nv_osd_start Line 158
Issue 3:- $:~/DeepStreamSDK-2.0_EA_beta1.2/DeepStream_Release/sources/apps/deepstream-test2$ ./deepstream-test2-app …/…/…/samples/streams/sample_720p.h264
Issue 4:- Also tried to compile and install gstreamer plugin gst-dsexample
~/DeepStreamSDK-2.0_EA_beta1.2/DeepStream_Release/sources/gst-plugins/gst-dsexample
But on gst-inspect it came as blacklisted
$:~/DeepStreamSDK-2.0_EA_beta1.2/DeepStream_Release/sources/gst-plugins/gst-dsexample$ gst-inspect-1.0 -b
Blacklisted files:
libgstnvdsexample.so
Total count: 1 blacklisted file
Please share me some pointers to debug the issue further !!
Regards
Pallab Sarkar
