Today, we announced the availability of DeepStream SDK 2.0 for Tesla. The NVIDIA DeepStream SDK is ideal for developers who are creating and deploying AI-based solutions for video analytics applications at scale, offering a complete framework and all the essential building blocks. It lets you focus on the core deep learning networks and IP you care about, rather than designing an end-to-end solution from scratch.
DeepStream makes use of:
NVIDIA® TensorRT™ and NVIDIA CUDA® for AI and other GPU computing tasks
Video CODEC SDK and multimedia APIs for accelerated encode and decode
Imaging APIs for capture and processing
A graph-based architecture and modular plug-ins to create configurable processing pipelines
I agree with @suchi, the picture is unreadable. Please change it.
I have additional question about the status of 1.5 version, where you are using FFMPEG as a backend. Is FFMPEG version of DeepStream deprecated? Will there be any updates on FFMPEG version of DeepStream. I find FFMPEG version (i.e. 1.5) much more capable in terms of the flexibility as is easier to use (developer wise, as you work directly in C++ with relatively simple API) compared to 2.0 (GStreamer) where you are very limited with the capabilities that you can add and especially how easily you can add it. There is very little source code in 2.0, you are more or less limited to txt configuration files. Can you provide source code for the pre-built sample application binaries in order to get more insight? (Similar as source code is provided for 1.5 FFMPEG).
For DS 2.0 we have stopped supporting FFMPEG and migrated to Gstreamer for scalability, flexibility and plug and play arch.
The query related to providing source for reference application, yes we intend to provide the source for reference application once code clean is completed. For now any user can use “deepstream-test1 and deepstream-test2” sources for understanding and implementation.
I was running the deepstream2.o samples and it is not getting compiled.
Thinking that it would be a gstreamer issue I reinstalled it, but it didnt helped.
Here is the error that I am getting for deepstream-app -c source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
Using Cached GIE model /home/graymatics/Deep-stream/DeepStream_Release/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_int8.cache crypto flags(0)
Using Cached GIE model /home/graymatics/Deep-stream/DeepStream_Release/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_int8.cache crypto flags(0)
Using Cached GIE model /home/graymatics/Deep-stream/DeepStream_Release/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_int8.cache crypto flags(0)
Using Cached GIE model /home/graymatics/Deep-stream/DeepStream_Release/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_int8.cache crypto flags(0)
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:75>: Pipeline ready
nvstreamtiler: batchSize set as 4
cuGraphicsGLRegisterBuffer failed with error(304) gst_eglglessink_cuda_init texture = 1
** INFO: <bus_callback:60>: Pipeline running
Is there anything wrong with the setup?
I am using P4 Tesla and installed sudo apt install libssl1.0.0 libjpeg8 libgstreamer1.0-0 gstreamer-tools gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav libgtk-3-0. But no hope; opencv is compiled with ffmpeg which is further compiled with binary h264 and nv code. Let me know if you want to know further about the setup.
