Running Deepstream 5.1 Docker container on a RTX2070 Hardware system
GPU: RTX2070
• DeepStream Version
5.1
• TensorRT Version
7.0
CUDA 10.2
questions
I am trying to install the docker image of deepstream sdk 5.1 on my GPU which has RTX2070 Nvidia card. The deepstream container does not work properly and cannot find multiple .so files. Is this because of the above mentioned hardware specifications , because I read that deepstream docker only works on the following: P4, T4, V100, GA100.
Also, how can I make this work on my GPU system with the aboove details.
We test and maintain NVIDIA® T4, NVIDIA® Ampere for dGPU mentioned in the quick start guide, other users in the forum also run success with other dGPU, like Geforce 2080, 1080, etc.
please specify details about the errors you met.
