Following the instructions in the README (/opt/nvidia/deepstream/deepstream/sources/objectDetector_SSD/README), when I issue the command:
$ python3 /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py \
frozen_inference_graph.pb -O NMS \
-p /usr/src/tensorrt/samples/sampleUffSSD/config.py \
-o sample_ssd_relu6.uff
It fails with this error:
2020-08-07 14:49:01.364038: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.2
Loading frozen_inference_graph.pb
File "/usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py", line 143, in <module>
main()
File "/usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py", line 139, in main
debug_mode=args.debug
File "/usr/lib/python3.6/dist-packages/uff/bin/../../uff/converters/tensorflow/conversion_helpers.py", line 274, in from_tensorflow_frozen_model
with tf.gfile.GFile(frozen_file, "rb") as frozen_pb:
AttributeError: module 'tensorflow' has no attribute 'gfile'
I have installed the latest tensorflow (2.2.0) as per the README.
I can fix this with an edit as follows to line #274 of
/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py
Change:
to
with tf.io.gfile.GFile(frozen_file, "rb") as frozen_pb:
But there are further errors…
Warning: No conversion function registered for layer: NMS_TRT yet.
AttributeError: module 'tensorflow' has no attribute 'AttrValue'
This used to work just fine in 5.0 developer preview so what has happened? Have the instructions not been updated or something???
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 5.0GA
