Deepstream Pipeline Issue
• Hardware Platform (Jetson / GPU) Jetson xavier NX
• DeepStream Version 6.1.1
• JetPack Version (valid for Jetson only) 5.0.2
• TensorRT Version 8.4
• Issue Type( questions, new requirements, bugs) questions
I have a pipeline like this
“gst-launch-1.0 filesrc location=/home/sensormatic/Videos/pvh-site-15min.mp4 ! decodebin ! nvvideoconvert ! m.sink_0 nvstreammux name=m width=1280 height=720 batch-size=1 batched-push-timeout=40000 ! queue ! nvinfer config-file-path=/home/sensormatic/vision-works-ds/cvads/configurations/occupancy/pgie_config.txt name=pgie ! queue ! nvtracker tracker-width=640 tracker-height=384 ll-lib-file=/opt/nvidia/deepstream/deepstream-6.1//lib/libnvds_nvmultiobjecttracker.so ll-config-file=/home/sensormatic/vision-works-ds/cvads/configurations/occupancy/config_tracker_NvDCF_perf.yml enable-past-frame=0 enable-batch-process=1 ! queue ! nvinfer config-file-path=/home/sensormatic/vision-works-ds/cvads/configurations/occupancy/sgie_config.txt name=sgie ! queue ! nvvideoconvert name=converter ! nvdsosd name=onscreendisplay process-mode=0 display-text=1 ! nv3dsink name=nv3d-sink”
I am trying to access the tensormeta of the sgie which gives binary classiification results. when i use the above pipeline means pgie->tracker->sgie i am not getting any results of sgie (few rarely) but when i use pgie->sgie->tracker i am getting classification results from sgie.
i wonder what is causing the issue. if i use sgie before tracker i am not able to use appsink.
Can you share your config file of PGIE/SGIE/tracker? Please check if you set “classifier-async-mode=1” in SGIE config file: Gst-nvinfer — DeepStream 6.3 Release documentation
I have commented this line classifier-async-mode=1
please find the pgie, sgie configs
pgie_config.txt (3.1 KB)
sgie_config.txt (3.0 KB)
I think i am not getting any sgie tensormeta data in appsink prob
@kesong any update on this.
sorry i have shared the other pipeline, please find the pipeline which i am using appsink.
“gst-launch-1.0 filesrc location=/home/sensormatic/Videos/pvh-site-15min.mp4 ! decodebin ! nvvideoconvert ! m.sink_0 nvstreammux name=m width=1280 height=720 batch-size=1 batched-push-timeout=40000 ! queue ! nvinfer config-file-path=/home/sensormatic/vision-works-ds/cvads/configurations/occupancy/pgie_config.txt name=pgie ! queue ! nvtracker tracker-width=640 tracker-height=384 ll-lib-file=/opt/nvidia/deepstream/deepstream-6.1//lib/libnvds_nvmultiobjecttracker.so ll-config-file=/home/sensormatic/vision-works-ds/cvads/configurations/occupancy/config_tracker_NvDCF_perf.yml enable-past-frame=0 enable-batch-process=1 ! queue ! nvinfer config-file-path=/home/sensormatic/vision-works-ds/cvads/configurations/occupancy/sgie_config.txt name=sgie ! queue ! appsink name=appsink emit-signals=True sync=false”
As you have the nvinfer source code, can you check if the object has been processed in function should_infer_object().
I am using python3 for pipeline and the same giving the results with nvosd but not in appsink.
Python pipeline also use nvinfer plugin, it will print the log if you add debug log in nvinfer source code and compile it.
Hi @kesong can you help me to resolve the issue when i use pgie->tracker->sgie i am not getting sgie results.
Meanwhile i will look into the nvinfer for appsink issue.
I need you add log in should_infer_object() and build nvinfer based on: /opt/nvidia/deepstream/deepstream-6.3/sources/gst-plugins/gst-nvinfer/README
