Hardware Platform : Jetson Nano
DeepStream Version : 5.1
JetPack Version : 4.5.1
hello
I want to test deepstream_pose_estimation
I followed the guide at GitHub - NVIDIA-AI-IOT/deepstream_pose_estimation: This is a sample DeepStream application to demonstrate a human pose estimation pipeline., but there was a problem running after compilation.
I flashed Jetpack4.5.1 and installed DS5.1 normally.
And immediately, deepstream_pose_estimation was compiled and executed, but the following error was encountered.
Someone please help
The following is the process of executing deepstream_pose_estimation from DS5.1 installation.
sudo apt-get install
libssl1.0.0
libgstreamer1.0-0
gstreamer1.0-tools
libgstreamer-plugins-base1.0-dev
libgstreamer1.0-dev
gstreamer1.0-plugins-good
gstreamer1.0-plugins-bad
gstreamer1.0-plugins-ugly
gstreamer1.0-libav
gstreamer1.0-alsa
libgstrtspserver-1.0-0
libgstrtspserver-1.0-dev
libjansson4
libjson-glib-dev
libx11-dev
$ sudo tar xvf deepstream_sdk_v5.1.0_jetson.tbz2 -C /
$ cd /opt/nvidia/deepstream/deepstream-5.1
$ sudo ./install.sh
$ sudo ldconfig
And deepstream_pose_estimation was successfully compiled.
And I ran it, but I got the following error.
Someone please help
$ sudo ./deepstream-pose-estimation-app …/…/…/…/samples/streams/sample_1080p_h264.mp4 ./
Now playing: …/…/…/…/samples/streams/sample_1080p_h264.mp4
Opening in BLOCKING MODE
ERROR: Deserialize engine failed because file path: /home/robopia/deepstream_sdk_v5.1.0_jetson/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream_pose_estimation/pose_estimation.onnx_b1_gpu0_fp16.engine open error
0:00:06.576832978 31873 0x55981a34f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 1]: deserialize engine from file :/home/robopia/deepstream_sdk_v5.1.0_jetson/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream_pose_estimation/pose_estimation.onnx_b1_gpu0_fp16.engine failed
0:00:06.576938606 31873 0x55981a34f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 1]: deserialize backend context from engine from file :/home/robopia/deepstream_sdk_v5.1.0_jetson/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream_pose_estimation/pose_estimation.onnx_b1_gpu0_fp16.engine failed, try rebuild
0:00:06.576971940 31873 0x55981a34f0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
Input filename: /home/robopia/deepstream_sdk_v5.1.0_jetson/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream_pose_estimation/pose_estimation.onnx
ONNX IR version: 0.0.4
Opset version: 7
Producer name: pytorch
Producer version: 1.3
Domain:
Model version: 0
Doc string:
WARNING: [TRT]: onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
Killed
