Deepstream preprocess roi
i want to Implement roi through preprocess group with deepstream-app config。How to write config_preprocess.txt,i I don’t know what configuration items there are
You can refer to our latest version. We have provided demo for preprocess in samples\configs\deepstream-app\source4_1080p_dec_preprocess_infer-resnet_preprocess_sgie_tiled_display_int8.txt.
why it doesnt work
[property]
enable=1
# list of component gie-id for which tensor is prepared
target-unique-ids=1
# 0=NCHW, 1=NHWC, 2=CUSTOM
network-input-order=0
# 0=process on objects 1=process on frames
process-on-frame=1
#uniquely identify the metadata generated by this element
unique-id=0
# gpu-id to be used
gpu-id=0
# if enabled maintain the aspect ratio while scaling
maintain-aspect-ratio=1
# if enabled pad symmetrically with maintain-aspect-ratio enabled
symmetric-padding=1
# processig width/height at which image scaled
processing-width=640
processing-height=368
# max buffer in scaling buffer pool
scaling-buf-pool-size=6
# max buffer in tensor buffer pool
tensor-buf-pool-size=6
# tensor shape based on network-input-order
network-input-shape= 60;3;368;640
# 0=RGB, 1=BGR, 2=GRAY
network-color-format=0
# 0=FP32, 1=UINT8, 2=INT8, 3=UINT32, 4=INT32, 5=FP16
tensor-data-type=0
# tensor name same as input layer name
tensor-name=input_1
# 0=NVBUF_MEM_DEFAULT 1=NVBUF_MEM_CUDA_PINNED 2=NVBUF_MEM_CUDA_DEVICE 3=NVBUF_MEM_CUDA_UNIFIED
scaling-pool-memory-type=0
# 0=NvBufSurfTransformCompute_Default 1=NvBufSurfTransformCompute_GPU 2=NvBufSurfTransformCompute_VIC
scaling-pool-compute-hw=0
# Scaling Interpolation method
# 0=NvBufSurfTransformInter_Nearest 1=NvBufSurfTransformInter_Bilinear 2=NvBufSurfTransformInter_Algo1
# 3=NvBufSurfTransformInter_Algo2 4=NvBufSurfTransformInter_Algo3 5=NvBufSurfTransformInter_Algo4
# 6=NvBufSurfTransformInter_Default
scaling-filter=0
# custom library .so path having custom functionality
custom-lib-path=/opt/nvidia/deepstream/deepstream/lib/gst-plugins/libcustom2d_preprocess.so
# custom tensor preparation function name having predefined input/outputs
# check the default custom library nvdspreprocess_lib for more info
custom-tensor-preparation-function=CustomTensorPreparation
[user-configs]
nvdspreprocess_lib
pixel-normalization-factor=0.003921568
[group-0]
src-ids=-1
custom-input-transformation-function=CustomAsyncTransformation
process-on-roi=1
roi-params-src-0=300;200;1000;800;
Why is the detection target not within the roi area?
Did you add the input-tensor-meta=1 parameter to the nvinfer configuration? You can refer to the demo file I attached before first.
there is a error
i use yolov5 model.how can i set “tensor-name” to yolov5’s input layer name.
Please set it according to your own model. You can refer to our Guide to set it yourself.
omg ,i refer to your guide ,it doesnt work.please help;this is my configurations
config_preprocess.txt (3.6 KB)
deepstream_app_config.txt (1.3 KB)
config_infer_primary_yoloV5.txt (681 字节)
Maybe setting the tensor-name parameter to your tensorrt’s input layer name does the job. (unless I misunderstood the parameter)
When you launch your pipeline, you can see the name of your input layer and output layer(s) in the terminal in the beginning.
It would look something like this
0 INPUT <input layer name> dimensions
1 OUTPUT <output layer name> dimensions & so on.
it means this?
yes, so your tensor-name=input and not input_1 is what I think.
thankyou very much.it works
