Deepstream problem
Hardware Platform (Jetson / GPU) Jetson AGX
• DeepStream Version 7.0
**• JetPack Version (valid for Jetson only) 6.0 GA
**• TensorRT Version 8.6
**• NVIDIA GPU Driver Version (valid for GPU only) 540.3.0
**• Issue Type( questions, new requirements, bugs) questions
I would like to ask, on JetPack 6.0, if I want to run DeepStream 7.1 Docker and it shows the following error, do I need to reinstall a higher version of CUDA in host or can I use the CUDA version in Docker
What is your Jetson board? AGX Orin?
Please follow the compatibility exactly. Installation — DeepStream documentation
Only JetPack 6.1 GA support DeepStream 7.1 GA. No backward compatibility.
The DeepStream Version of this host 7.0 ]
yes I want to pull docker DeepStream 7.1 and want to run this docker , this picture show this problem
Can only update the CUDA version on the host machine?
Is there CUDA12-6 in Docker that includes DeepStream 7.1 now? Is it necessary to update the CUDA of the host computer?
No. Please upgrade your JetPack version.
Please upgrade your JetPack version. Docker Containers — DeepStream documentation
