Is deepstream 7.0 can run this environment?
• Hardware Platform (Jetson / GPU) : GPU, geforce 4070ti
• DeepStream Version : deepstream 7.0
• TensorRT Version : 8.6.1.6
• NVIDIA GPU Driver Version (valid for GPU only) : 555.42.02
• Issue Type( questions, new requirements, bugs) : questions
cuda version : 12.5
can i use deepstream 7.0 in these environment?
also, can i use TensorRT 10.0.1 same environment?
Please refer to the dependency here: Installation — DeepStream documentation (nvidia.com)
You can also try DeepStream docker without modifying your driver/Cuda/TensorRT, check the description here: Installation — DeepStream documentation (nvidia.com)
This is incompatible
You can use docker to avoid version incompatibility issues
