Device : Jetson Xavier Nx
Jetpack : JetPack 4.5.1 [L4t 32.5.1]
I tried to run the sample python apps from here
[https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/apps/deepstream-ssd-parser](https://DeepStream Python SSD apps)
I followed instructions as stated in the above repository.
The GPU instance was set as
instance_group {
kind: KIND_GPU
count: 1
gpus: 0
Here is the log when the model is loaded
thukhi@thukhi:/opt/nvidia/deepstream/deepstream-5.1/sources/deepstream_python_apps/apps/deepstream-ssd-parser$ sudo python3 deepstream_ssd_parser.py ../../../../samples/streams/sample_720p.h264 Creating Pipeline Creating Source Creating H264Parser Creating Decoder Creating NvStreamMux Creating Nvinferserver Creating Nvvidconv Creating OSD (nvosd) Creating Queue Creating Converter 2 (nvvidconv2) Creating capsfilter Creating Encoder Creating Code Parser Creating Container Creating Sink Playing file ../../../../samples/streams/sample_720p.h264 Adding elements to Pipeline Linking elements in the Pipeline Starting pipeline Opening in BLOCKING MODE Opening in BLOCKING MODE I0519 06:46:02.314171 15820 pinned_memory_manager.cc:199] Pinned memory pool is created at '0x2030ba000' with size 67108864 I0519 06:46:02.314522 15820 cuda_memory_manager.cc:99] CUDA memory pool is created on device 0 with size 67108864 I0519 06:46:02.317155 15820 server.cc:141] +---------+--------+------+ | Backend | Config | Path | +---------+--------+------+ +---------+--------+------+ I0519 06:46:02.317284 15820 server.cc:184] +-------+---------+--------+ | Model | Version | Status | +-------+---------+--------+ +-------+---------+--------+ I0519 06:46:02.317763 15820 tritonserver.cc:1620] +----------------------------------+----------------------------------------------------------------------------------------------------------------+ | Option | Value | +----------------------------------+----------------------------------------------------------------------------------------------------------------+ | server_id | triton | | server_version | 2.5.0 | | server_extensions | classification sequence model_repository schedule_policy model_configuration system_shared_memory cuda_shared_ | | | memory binary_tensor_data statistics | | model_repository_path[0] | /opt/nvidia/deepstream/deepstream-5.1/samples/trtis_model_repo | | model_control_mode | MODE_EXPLICIT | | strict_model_config | 0 | | pinned_memory_pool_byte_size | 67108864 | | cuda_memory_pool_byte_size{0} | 67108864 | | min_supported_compute_capability | 5.3 | | strict_readiness | 1 | | exit_timeout | 30 | +----------------------------------+----------------------------------------------------------------------------------------------------------------+ I0519 06:46:02.321476 15820 model_repository_manager.cc:810] loading: ssd_inception_v2_coco_2018_01_28:1 2021-05-19 08:46:03.025265: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2 I0519 06:46:03.543636 15820 tensorflow.cc:1876] TRITONBACKEND_Initialize: tensorflow I0519 06:46:03.543728 15820 tensorflow.cc:1889] Triton TRITONBACKEND API version: 1.0 I0519 06:46:03.543797 15820 tensorflow.cc:1895] 'tensorflow' TRITONBACKEND API version: 1.0 I0519 06:46:03.543833 15820 tensorflow.cc:1916] backend configuration: {"cmdline":{"allow-soft-placement":"true","gpu-memory-fraction":"0.400000"}} I0519 06:46:03.544064 15820 tensorflow.cc:1978] TRITONBACKEND_ModelInitialize: ssd_inception_v2_coco_2018_01_28 (version 1) I0519 06:46:03.549827 15820 tensorflow.cc:2028] TRITONBACKEND_ModelInstanceInitialize: ssd_inception_v2_coco_2018_01_28_0 (GPU device 0) 2021-05-19 08:46:13.322728: W tensorflow/core/platform/profile_utils/cpu_utils.cc:98] Failed to find bogomips in /proc/cpuinfo; cannot determine CPU frequency 2021-05-19 08:46:13.324289: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x7f400508b0 initialized for platform Host (this does not guarantee that XLA will be used). Devices: 2021-05-19 08:46:13.324404: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Host, Default Version 2021-05-19 08:46:13.324787: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcuda.so.1 2021-05-19 08:46:13.325027: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1049] ARM64 does not support NUMA - returning NUMA node zero 2021-05-19 08:46:13.325221: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1665] Found device 0 with properties: name: Xavier major: 7 minor: 2 memoryClockRate(GHz): 1.109 pciBusID: 0000:00:00.0 2021-05-19 08:46:13.325322: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2 2021-05-19 08:46:13.325506: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10 2021-05-19 08:46:13.347415: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcufft.so.10 2021-05-19 08:46:13.386696: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcurand.so.10 2021-05-19 08:46:13.406021: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusolver.so.10 2021-05-19 08:46:13.432913: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusparse.so.10 2021-05-19 08:46:13.433305: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8 2021-05-19 08:46:13.433513: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1049] ARM64 does not support NUMA - returning NUMA node zero 2021-05-19 08:46:13.433738: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1049] ARM64 does not support NUMA - returning NUMA node zero 2021-05-19 08:46:13.433826: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1793] Adding visible gpu devices: 0 2021-05-19 08:46:13.434233: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1206] Device interconnect StreamExecutor with strength 1 edge matrix: 2021-05-19 08:46:13.434330: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1212] 0 2021-05-19 08:46:13.434400: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1225] 0: N 2021-05-19 08:46:13.434682: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1049] ARM64 does not support NUMA - returning NUMA node zero 2021-05-19 08:46:13.434913: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1049] ARM64 does not support NUMA - returning NUMA node zero 2021-05-19 08:46:13.435118: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1049] ARM64 does not support NUMA - returning NUMA node zero 2021-05-19 08:46:13.435317: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1351] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 3106 MB memory) -> physical GPU (device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2) 2021-05-19 08:46:13.441723: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x7f40057b60 initialized for platform CUDA (this does not guarantee that XLA will be used). Devices: 2021-05-19 08:46:13.441828: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Xavier, Compute Capability 7.2 I0519 06:46:15.267015 15820 model_repository_manager.cc:983] successfully loaded 'ssd_inception_v2_coco_2018_01_28' version 1 INFO: TrtISBackend id:5 initialized model: ssd_inception_v2_coco_2018_01_28 2021-05-19 08:46:28.736767: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8 2021-05-19 08:47:07.804698: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10 NvMMLiteOpen : Block : BlockType = 261 NVMEDIA: Reading vendor.tegra.display-size : status: 6 NvMMLiteBlockCreate : Block : BlockType = 261 Frame Number=0 Number of Objects=5 Vehicle_count=2 Person_count=2 Frame Number=1 Number of Objects=5 Vehicle_count=2 Person_count=2 Frame Number=2 Number of Objects=5 Vehicle_count=2 Person_count=2 Frame Number=3 Number of Objects=5 Vehicle_count=2 Person_count=2 Frame Number=4 Number of Objects=5 Vehicle_count=2 Person_count=2 Frame Number=5 Number of Objects=5 Vehicle_count=2 Person_count=2 Frame Number=6 Number of Objects=5 Vehicle_count=2 Person_count=2
In the log it shows it the GPU is utilized, but it is not utilized when running the code.
Could you please help ?
Thanks in Advance
