• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version installed with sdkmanager so 5+
• JetPack Version (valid for Jetson only) 4 5 1
:/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-ssd-parser$ python3 deepstream_ssd_parser.py /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating NvStreamMux
Creating Nvinferserver
2021-03-26 08:24:46.734910: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.2
Creating Nvvidconv
Creating OSD (nvosd)
Creating Queue
Creating Converter 2 (nvvidconv2)
Creating capsfilter
Creating Encoder
Creating Code Parser
Creating Container
Creating Sink
Playing file /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Opening in BLOCKING MODE
I0326 12:24:47.006803 26285 server.cc:120] Initializing Triton Inference Server
I0326 12:24:47.013040 26285 server_status.cc:55] New status tracking for model 'ssd_inception_v2_coco_2018_01_28'
I0326 12:24:47.013175 26285 model_repository_manager.cc:680] loading: ssd_inception_v2_coco_2018_01_28:1
I0326 12:24:47.013740 26285 base_backend.cc:176] Creating instance ssd_inception_v2_coco_2018_01_28_0_0_gpu0 on GPU 0 (7.2) using model.graphdef
2021-03-26 08:24:47.059738: W tensorflow/core/platform/profile_utils/cpu_utils.cc:98] Failed to find bogomips in /proc/cpuinfo; cannot determine CPU frequency
2021-03-26 08:24:47.060703: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x38f15a00 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
2021-03-26 08:24:47.060777: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Host, Default Version
2021-03-26 08:24:47.060990: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcuda.so.1
2021-03-26 08:24:47.061149: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2021-03-26 08:24:47.061305: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1639] Found device 0 with properties:
name: Xavier major: 7 minor: 2 memoryClockRate(GHz): 1.377
pciBusID: 0000:00:00.0
2021-03-26 08:24:47.061374: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.2
2021-03-26 08:24:47.061510: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcublas.so.10
2021-03-26 08:24:47.064035: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcufft.so.10
2021-03-26 08:24:47.064686: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcurand.so.10
2021-03-26 08:24:47.067568: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcusolver.so.10
2021-03-26 08:24:47.069854: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcusparse.so.10
2021-03-26 08:24:47.069981: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudnn.so.8
2021-03-26 08:24:47.070119: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2021-03-26 08:24:47.070299: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2021-03-26 08:24:47.070356: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1767] Adding visible gpu devices: 0
2021-03-26 08:24:48.976955: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1180] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-03-26 08:24:48.977041: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1186] 0
2021-03-26 08:24:48.977068: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1199] 0: N
2021-03-26 08:24:48.977230: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2021-03-26 08:24:48.977434: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2021-03-26 08:24:48.977566: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2021-03-26 08:24:48.977678: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1325] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 6329 MB memory) -> physical GPU (device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2)
2021-03-26 08:24:48.981699: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x7ecd4d3f10 initialized for platform CUDA (this does not guarantee that XLA will be used). Devices:
2021-03-26 08:24:48.981769: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Xavier, Compute Capability 7.2
I0326 12:24:49.426215 26285 model_repository_manager.cc:837] successfully loaded 'ssd_inception_v2_coco_2018_01_28' version 1
INFO: TrtISBackend id:5 initialized model: ssd_inception_v2_coco_2018_01_28
2021-03-26 08:24:57.918151: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudnn.so.8
2021-03-26 08:25:00.640879: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcublas.so.10
Error: gst-stream-error-quark: Internal data stream error. (1): gstbaseparse.c(3611): gst_base_parse_loop (): /GstPipeline:pipeline0/GstH264Parse:h264-parser:
streaming stopped, reason not-negotiated (-4)
I0326 12:25:06.400027 26285 model_repository_manager.cc:708] unloading: ssd_inception_v2_coco_2018_01_28:1
I0326 12:25:06.510468 26285 model_repository_manager.cc:816] successfully unloaded 'ssd_inception_v2_coco_2018_01_28' version 1
I0326 12:25:06.512438 26285 server.cc:179] Waiting for in-flight inferences to complete.
I0326 12:25:06.512544 26285 server.cc:194] Timeout 30: Found 0 live models and 0 in-flight requests
