I’m using DeepStream on Jetson Nano
Test App 1 is working properly with some h264 files but fails with h264 parser error on a particular h264 input file. I don’t know why this is happening
Can you provide your h264 input file and your command line so that we can try to reproduce the problem?
Dear Fiona, I solved the problem. My h264 file was corrupted. When I used the correct file, it worked properly.
Thank you
