• Hardware Platform GPU
• DeepStream Version 5.1-21.02
• TensorRT Version 20.12
• NVIDIA GPU Driver Version 450.142.00
• Issue Type bugs
• Reproducing, create HRNet, convert it in int8 TensorRT, then run it on examples and compare the tensorRT and DeepStream mask
So i convert my model in int8 with TensorRT and compare masks from TensorRT engine runner with DeepStream, and notice the masks not the same.
On left picture (int8 TensorRT inference), you can see in the middle of image small yellow blob inside big blue blob (approximate coordinates for small blob x = 650, y = 225), that blob is very important in my task. On the over hand on right picture that blob doesn’t exists.
The question is, how can i get the same mask as in TensorRT?
