• Hardware Platform (Jetson / GPU) nano
• DeepStream Version 7.0
• JetPack Version (valid for Jetson only) 6.0
• TensorRT Version 8.6.2.3-1+cuda12.2
• NVIDIA GPU Driver Version (valid for GPU only) NVIDIA-SMI 540.2.0
How to create this kind of visulization ?
is Gst-nvdsanalytics helpful to create those kind of visulization ?
Is their any way to count the number of object in zone ?
want to add histogram in below part :
def pgie_src_pad_buffer_probe(pad, info, u_data):
frame_number = 0
num_rects = 0
obj_counter = {
PGIE_CLASS_ID_PERSON: 0, # Initialize person count to 0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
break
frame_number = frame_meta.frame_num
num_rects = frame_meta.num_obj_meta # Number of objects in the frame
# Access the object metadata list
l_obj = frame_meta.obj_meta_list
while l_obj is not None:
try:
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
break
# Increment the counter for detected person objects
if obj_meta.class_id == PGIE_CLASS_ID_PERSON:
obj_counter[PGIE_CLASS_ID_PERSON] += 1
# Set the border color of the object to blue
obj_meta.rect_params.border_color.set(0.0, 0.0, 1.0, 0.8)
try:
l_obj = l_obj.next
break
# Display person count and other metadata
display_text = f"Frame Number={frame_number} Number of Objects={num_rects} Person_count={obj_counter[PGIE_CLASS_ID_PERSON]}"
print(display_text) # Optional: Print to console for debugging
# Add text display to the frame (example, using pyds.NvOSD_TextParams)
py_nvosd_text_params = pyds.NvOSD_TextParams()
py_nvosd_text_params.display_text = display_text
py_nvosd_text_params.x_offset = 10
py_nvosd_text_params.y_offset = 12
py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
py_nvosd_text_params.font_params.font_size = 10
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.set_bg_clr = 1
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 0.5)
# (Optional) Display RTSP timestamp if available
if ts_from_rtsp:
ts = frame_meta.ntp_timestamp / 1000000000
print("RTSP Timestamp:", datetime.datetime.utcfromtimestamp(ts).strftime('%Y-%m-%d %H:%M:%S'))
try:
l_frame = l_frame.next
break
return Gst.PadProbeReturn.OK
