i just edited the c file of my deepstream
this is the github which i used
i connected 3 rtsp stream to this
how i can get the total number of bounding box detected from each camera
/static guint total_objects_detected = 0;/
guint count;
guint sum;
float avg;
//guint num_people_by_camera[MAX_SOURCE_BINS];
//guint num_people_by_camera=3;
static void
bbox_generated_probe_after_analytics (AppCtx * appCtx, GstBuffer * buf,
NvDsBatchMeta * batch_meta, guint index)
NvDsObjectMeta *obj_meta = NULL;
GstClockTime buffer_pts = 0;
guint32 stream_id = 0;
NvDsMetaList * l_obj = NULL;
NvDsDisplayMeta *display_meta = NULL;
//code by steeve
// guint num_objects_detected[MAX_NUM_CAMERAS] = {0};
//closed by steeve
if (!appCtx->config.dsanalytics_config.enable){
g_print ("Unable to get nvdsanalytics src pad\n");
return;
for (NvDsMetaList * l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = l_frame->data;
stream_id = frame_meta->source_id;
GstClockTime buf_ntp_time = 0;
if (playback_utc == FALSE) {
/** Calculate the buffer-NTP-time
* derived from this stream's RTCP Sender Report here:
StreamSourceInfo *src_stream = &testAppCtx->streams[stream_id];
buf_ntp_time = frame_meta->ntp_timestamp;
if (buf_ntp_time < src_stream->last_ntp_time) {
NVGSTDS_WARN_MSG_V ("Source %d: NTP timestamps are backward in time."
" Current: %lu previous: %lu", stream_id, buf_ntp_time,
src_stream->last_ntp_time);
src_stream->last_ntp_time = buf_ntp_time;
GList *l;
NvDsMetaList *l_analyticsuser;
l_analyticsuser = frame_meta->frame_user_meta_list;
AnalyticsUserMeta *user_data =
(AnalyticsUserMeta *) g_malloc0(sizeof(AnalyticsUserMeta));
if (l_analyticsuser != NULL) {
analytics_custom_parse_nvdsanalytics_meta_data(l_analyticsuser, user_data);
user_data->source_id = stream_id;
// l_analyticsuser = l_analyticsuser->next;
/* Code from test5 application */
for (l = frame_meta->obj_meta_list; l != NULL; l = l->next) {
/* Now using above information we need to form a text that should
* be displayed on top of the bounding box, so lets form it here. */
obj_meta = (NvDsObjectMeta *) (l->data);
//num_objects_detected[obj_meta->source_id] += 1;
* Enable only if this callback is after tiler
* NOTE: Scaling back code-commented
* now that bbox_generated_probe_after_analytics() is post analytics
* (say pgie, tracker or sgie)
* and before tiler, no plugin shall scale metadata and will be
* corresponding to the nvstreammux resolution
float scaleW = 0;
float scaleH = 0;
/* Frequency of messages to be send will be based on use case.
* Here message is being sent for first object every 30 frames.
buffer_pts = frame_meta->buf_pts;
if (!appCtx->config.streammux_config.pipeline_width
|| !appCtx->config.streammux_config.pipeline_height) {
g_print ("invalid pipeline params\n");
return;
LOGD ("stream %d==%d [%d X %d]\n", frame_meta->source_id,
frame_meta->pad_index, frame_meta->source_frame_width,
frame_meta->source_frame_height);
scaleW =
(float) frame_meta->source_frame_width /
appCtx->config.streammux_config.pipeline_width;
scaleH =
(float) frame_meta->source_frame_height /
appCtx->config.streammux_config.pipeline_height;
/** Use the buffer-NTP-time derived from this stream's RTCP Sender
* Report here:
buffer_pts = buf_ntp_time;
/** Generate NvDsEventMsgMeta for every object */
NvDsEventMsgMeta *msg_meta =
(NvDsEventMsgMeta *) g_malloc0 (sizeof (NvDsEventMsgMeta));
generate_event_msg_meta (msg_meta, PERSON_ID, TRUE,
/**< useTs NOTE: Pass FALSE for files without base-timestamp in URI */
buffer_pts,
appCtx->config.multi_source_config[stream_id].uri, stream_id,
appCtx->config.multi_source_config[stream_id].camera_id,
user_data, scaleW, scaleH, frame_meta);
testAppCtx->streams[stream_id].meta_number++;
NvDsUserMeta *user_event_meta =
nvds_acquire_user_meta_from_pool (batch_meta);
//num_people_by_camera[stream_id] += 1;
if (user_event_meta) {
* Since generated event metadata has custom objects for
* Vehicle / Person which are allocated dynamically, we are
* setting copy and free function to handle those fields when
* metadata copy happens between two components.
user_event_meta->user_meta_data = (void *) msg_meta;
user_event_meta->base_meta.batch_meta = batch_meta;
user_event_meta->base_meta.meta_type = NVDS_EVENT_MSG_META;
user_event_meta->base_meta.copy_func =
(NvDsMetaCopyFunc) meta_copy_func;
user_event_meta->base_meta.release_func =
(NvDsMetaReleaseFunc) meta_free_func;
nvds_add_user_meta_to_frame (frame_meta, user_event_meta);
} else {
g_print ("Error in attaching event meta to buffer\n");
testAppCtx->streams[stream_id].frameCount++;
//g_print ("strem id = %f \n",frame_meta->obj_meta_list);
//g_print("Camera %d: Number of people detected = %d\n", i, num_people_by_camera[i]);
int offset = 0;
total_objects_detected += g_list_length(frame_meta->obj_meta_list);
/*for (int i = 0; i < MAX_NUM_CAMERAS; i++) {
g_print("Camera %d: Number of objects detected = %d\n", i, num_objects_detected[i]);
count++;
sum += total_objects_detected;
if(count == 10){
avg = sum/count;
g_print ("Average Number of people in the room : %f \n",avg);
count = 0;
sum = 0;
//temporary
//closed
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
NvOSD_TextParams *txt_params = &display_meta->text_params[0];
display_meta->num_labels = 1;
txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Approximate number of people in the room = %f ", avg);
//offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
/* Now set the offsets where the string should appear */
txt_params->x_offset = 10;
txt_params->y_offset = 12;
/* Font , font-color and font-size */
txt_params->font_params.font_name = "Serif";
txt_params->font_params.font_size = 10;
txt_params->font_params.font_color.red = 1.0;
txt_params->font_params.font_color.green = 1.0;
txt_params->font_params.font_color.blue = 1.0;
txt_params->font_params.font_color.alpha = 1.0;
/* Text background color */
txt_params->set_bg_clr = 1;
txt_params->text_bg_clr.red = 0.0;
txt_params->text_bg_clr.green = 0.0;
txt_params->text_bg_clr.blue = 0.0;
txt_params->text_bg_clr.alpha = 1.0;
nvds_add_display_meta_to_frame(frame_meta, display_meta);
//g_print ("Number of objects = %d \n",total_objects_detected);
g_free(user_data);
i just edited the fundtion of the c file deepstream_test5_app_main.c
iam getting the approximate number of people in the room
its getting the data of one source i thing so
is this the correct way to do
how i can get the total number of bounding box detected in each cam seperately
is the any way to get those details from the config file?
