• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5
• TensorRT Version 7.2.3
• NVIDIA GPU Driver Version (valid for GPU only) 460+
• Issue Type( questions, new requirements, bugs) question
I’m trying to run a attendance system off rtsp cameras and from research i’ve found that latency in execution is stopping the rtsp stream thereby preventing deepstream from executing. The code doesn’t stop but it just freezes at a certain frame and does not restart. After changing the quantization of the model from 32 to 16 it runs for longer before stopping which leads me to believe its a latency issue. Here are the logs:
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating source_bin 1
Creating source bin
source-bin-01
Creating source_bin 2
Creating source bin
source-bin-02
Creating source_bin 3
Creating source bin
source-bin-03
Creating Pgie
Now playing…
Starting pipeline
0:00:01.623679826 74662 0x3b2c410 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 2]: deserialized trt engine from :/home/nxtgen/deepstream-fr/facenet.onnx_b1_gpu0_fp16.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1:0 3x160x160
1 OUTPUT kFLOAT Bottleneck_BatchNorm/batchnorm_1/add_1:0 128
0:00:01.623782954 74662 0x3b2c410 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 2]: Use deserialized engine model: /home/nxtgen/deepstream-fr/facenet.onnx_b1_gpu0_fp16.engine
0:00:01.624492821 74662 0x3b2c410 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 2]: Load new model:classifier_config.txt sucessfully
0:00:01.692372053 74662 0x3b2c410 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/home/nxtgen/deepstream-fr/models/Secondary_FaceDetect/fd_lpd.caffemodel_b1_gpu0_fp16.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT data 3x270x480
1 OUTPUT kFLOAT output_cov 4x17x30
2 OUTPUT kFLOAT output_bbox 16x17x30
0:00:01.692454038 74662 0x3b2c410 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /home/nxtgen/deepstream-fr/models/Secondary_FaceDetect/fd_lpd.caffemodel_b1_gpu0_fp16.engine
0:00:01.693031347 74662 0x3b2c410 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:detector_config.txt sucessfully
Decodebin child added: source
0:00:01.788095927 74662 0x1dd1940 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:fakesrc0:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:01.848236597 74662 0x1dadc00 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:fakesrc1:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:01.854866544 74662 0x1dad540 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:fakesrc2:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:01.859080132 74662 0x1dac680 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:fakesrc3:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
Decodebin child added: decodebin0
Decodebin child added: rtph264depay0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
0:00:03.844797678 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844815739 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MJPG
0:00:03.844822830 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844829571 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MJPG
0:00:03.844843914 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844849775 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG4
0:00:03.844857056 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844862769 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG4
0:00:03.844883916 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844889989 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG2
0:00:03.844895064 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844900657 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG2
0:00:03.844910622 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844916593 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H265
0:00:03.844921978 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844927625 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H265
0:00:03.844936404 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844942264 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP90
0:00:03.844947450 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844952946 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP90
0:00:03.844960856 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844966517 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP80
0:00:03.844971775 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844977375 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP80
0:00:03.844985876 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.844991627 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H264
0:00:03.844996893 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:03.845002258 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H264
0:00:03.845308502 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:03.845316877 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe minimum capture size for pixelformat NM12
0:00:03.845322445 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:03.845328585 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe maximum capture size for pixelformat NM12
0:00:03.845336099 74662 0x1dd2370 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7f3bdc0c9910 Failed to determine interlace mode
Decodebin child added: decodebin1
Decodebin child added: decodebin2
Decodebin child added: rtph264depay1
Decodebin child added: h264parse1
Decodebin child added: rtph264depay2
Decodebin child added: capsfilter1
Decodebin child added: h264parse2
Decodebin child added: capsfilter2
Decodebin child added: nvv4l2decoder1
0:00:03.905962574 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.905981329 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MJPG
0:00:03.905988941 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.905995828 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MJPG
0:00:03.906014003 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.906020238 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG4
0:00:03.906025820 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.906031596 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG4
0:00:03.906043630 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.906049748 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG2
0:00:03.906055224 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.906061082 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG2
0:00:03.906071455 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.906077318 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H265
0:00:03.906082726 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.906088502 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H265
0:00:03.906099689 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.906105609 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat VP90
0:00:03.906111288 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.906117301 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat VP90
0:00:03.906126105 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.906132202 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat VP80
0:00:03.906137803 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.906144052 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat VP80
0:00:03.906153521 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.906159495 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H264
0:00:03.906167243 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:03.906173041 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H264
0:00:03.906200727 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:03.906210400 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe minimum capture size for pixelformat NM12
0:00:03.906215969 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:03.906221821 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe maximum capture size for pixelformat NM12
Decodebin child added: nvv4l2decoder2
0:00:03.906229995 74662 0x1dd40f0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7f3b9005d590 Failed to determine interlace mode
0:00:03.906406439 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906422347 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat MJPG
0:00:03.906429581 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906436323 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat MJPG
0:00:03.906450268 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906456663 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat MPG4
0:00:03.906462257 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906468178 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat MPG4
0:00:03.906480789 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906486760 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat MPG2
0:00:03.906492177 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906497953 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat MPG2
0:00:03.906508307 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906514315 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat H265
0:00:03.906519920 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906525878 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat H265
0:00:03.906535188 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906541283 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat VP90
0:00:03.906548855 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906554684 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat VP90
0:00:03.906563459 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906569767 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat VP80
0:00:03.906575203 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906581284 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat VP80
0:00:03.906590897 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906596919 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat H264
0:00:03.906602391 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:03.906608237 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat H264
0:00:03.906646475 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:src Unable to try format: Unknown error -1
0:00:03.906652694 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:src Could not probe minimum capture size for pixelformat NM12
0:00:03.906657951 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:src Unable to try format: Unknown error -1
0:00:03.906663551 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:src Could not probe maximum capture size for pixelformat NM12
0:00:03.906670855 74662 0x1dd54f0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7f3b94071a90 Failed to determine interlace mode
0:00:03.950788980 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950805988 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950843369 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950848706 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950867066 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950872629 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950904905 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950912438 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950927607 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950932786 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950947241 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950952441 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950967532 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950973400 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950988512 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:03.950993804 74662 0x1dd2370 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
In cb_newpad
0:00:03.951601342 74662 0x1dd2370 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:03.951632801 74662 0x1dd2370 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:03.951970129 74662 0x1dabde0 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event: stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:03.952923653 74662 0x7f3bdc0aa190 WARN v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
Decodebin child added: decodebin3
Decodebin child added: rtph264depay3
Decodebin child added: h264parse3
Decodebin child added: capsfilter3
Decodebin child added: nvv4l2decoder3
0:00:04.002009351 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002023608 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat MJPG
0:00:04.002030615 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002037006 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat MJPG
0:00:04.002049692 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002055686 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat MPG4
0:00:04.002078068 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002084252 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat MPG4
0:00:04.002094806 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002108215 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat MPG2
0:00:04.002113594 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002121424 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat MPG2
0:00:04.002132398 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002138413 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat H265
0:00:04.002144135 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002150098 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat H265
0:00:04.002159258 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002165301 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat VP90
0:00:04.002170605 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002176436 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat VP90
0:00:04.002185066 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002191088 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat VP80
0:00:04.002196665 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002202680 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat VP80
0:00:04.002212032 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002218202 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat H264
0:00:04.002223966 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:04.002230460 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat H264
0:00:04.002256677 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:src Unable to try format: Unknown error -1
0:00:04.002266485 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2924:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:src Could not probe minimum capture size for pixelformat NM12
0:00:04.002272118 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:3038:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:src Unable to try format: Unknown error -1
0:00:04.002278040 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2930:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:src Could not probe maximum capture size for pixelformat NM12
0:00:04.002285543 74662 0x1dd68f0 WARN v4l2 gstv4l2object.c:2375:gst_v4l2_object_add_interlace_mode:0x7f3b840673b0 Failed to determine interlace mode
0:00:04.014543793 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014559222 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014579241 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014584273 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014602171 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014608442 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014623133 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014628429 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014660609 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014666102 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014681438 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014687713 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014703699 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014709248 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014725424 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014730862 74662 0x1dd54f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
In cb_newpad
0:00:04.014955143 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.014981672 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015005046 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015011033 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015032417 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015038067 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015054367 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015060324 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015075871 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015081210 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015094941 74662 0x1dd54f0 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:04.015096478 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015118748 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015113278 74662 0x1dd54f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2decoder2:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:04.015136736 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015144294 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015133936 74662 0x1dabde0 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event: stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:04.015163132 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.015297812 74662 0x1dd40f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
In cb_newpad
0:00:04.015659564 74662 0x1dabde0 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event: stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:04.015718915 74662 0x1dd40f0 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:04.015737213 74662 0x1dd40f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2decoder1:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:04.016731672 74662 0x1dd7630 WARN v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder2:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:04.020251334 74662 0x1dd7c00 WARN v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder1:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:04.107068979 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107084290 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107104557 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107109673 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107134482 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107148275 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107163565 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107168610 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107183083 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107188196 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107202280 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107210429 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107224937 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107230242 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107245701 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
0:00:04.107250912 74662 0x1dd68f0 ERROR v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
In cb_newpad
0:00:04.107586070 74662 0x1dd68f0 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:04.107601722 74662 0x1dd68f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2decoder3:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:04.107645769 74662 0x1dabde0 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event: stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:04.110580014 74662 0x7f3b84004770 WARN v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder3:pool:src Driver should never set v4l2_buffer.field to ANY
