root@va03:/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-nvdsanalytics-test# export NVDS_ENABLE_COMPONENT_LATENCY_MEASUREMENT=1
root@va03:/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-nvdsanalytics-test# export NVDS_ENABLE_LATENCY_MEASUREMENT=1
root@va03:/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-nvdsanalytics-test# ./deepstream-app -c ./assets/topconfig30.txt
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8555/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8556/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8557/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8558/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8559/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8560/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8561/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8562/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8563/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8564/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8565/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8566/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8567/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8568/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8569/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8570/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8571/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8572/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8573/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8574/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8575/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8576/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8577/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8578/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8579/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8580/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8581/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8582/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8583/ds-test ***
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_iou.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
0:00:00.555561239 262 0x55f2401e1e30 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 2 output network tensors.
0:01:14.313613478 262 0x55f2401e1e30 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1748> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-nvdsanalytics-test/assets/resnet10_detector.etlt_b30_gpu0_int8.engine successfully
WARNING: …/nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x1080x1920
1 OUTPUT kFLOAT output_bbox/BiasAdd 4x68x120
2 OUTPUT kFLOAT output_cov/Sigmoid 1x68x120
0:01:14.327121747 262 0x55f2401e1e30 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-nvdsanalytics-test/assets/pgie-config.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg) FPS 4 (Avg) FPS 5 (Avg) FPS 6 (Avg) FPS 7 (Avg) FPS 8 (Avg) FPS 9 (Avg) FPS 10 (Avg) FPS 11 (Avg) FPS 12 (Avg) FPS 13 (Avg) FPS 14 (Avg) FPS 15 (Avg) FPS 16 (Avg) FPS 17 (Avg) FPS 18 (Avg) FPS 19 (Avg) FPS 20 (Avg) FPS 21 (Avg) FPS 22 (Avg) FPS 23 (Avg) FPS 24 (Avg) FPS 25 (Avg) FPS 26 (Avg) FPS 27 (Avg) FPS 28 (Avg) FPS 29 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
ERROR from src_elem6: Unauthorized
Debug info: gstrtspsrc.c(6116): gst_rtspsrc_send (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin6/GstRTSPSrc:src_elem6:
Unauthorized (401)
** INFO: <reset_source_pipeline:1154>: Resetting source 6
ERROR from src_elem14: Unauthorized
Debug info: gstrtspsrc.c(6116): gst_rtspsrc_send (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin14/GstRTSPSrc:src_elem14:
Unauthorized (401)
** INFO: <reset_source_pipeline:1154>: Resetting source 14
Unauthorized (401)
Unauthorized (401)
IOU Tracker Init with threshold 0.100000
Alerting Set after 200 frames
BATCH-NUM = 0**
Batch meta not found for buffer 0x7fcddc0ba330
BATCH-NUM = 1**
Batch meta not found for buffer 0x7fcc1c1831f0
BATCH-NUM = 2**
Batch meta not found for buffer 0x7fcd7c078340
BATCH-NUM = 3**
Batch meta not found for buffer 0x7fccdc07e380
BATCH-NUM = 0**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917746673.521973 out_system_timestamp = 1609917747694.389893 component latency= 1020.867920
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 0 in_system_timestamp = 1609917747694.603027 out_system_timestamp = 1609917747717.592041 component_latency = 22.989014
Comp name = primary_gie in_system_timestamp = 1609917747717.650879 out_system_timestamp = 1609917747717.752930 component latency= 0.102051
Comp name = tracking_tracker in_system_timestamp = 1609917747717.777100 out_system_timestamp = 1609917747718.412109 component latency= 0.635010
Comp name = dsanalytics0 in_system_timestamp = 1609917747718.465088 out_system_timestamp = 1609917747718.739014 component latency= 0.273926
Comp name = demuxer in_system_timestamp = 1609917747718.762939 out_system_timestamp = 1609917747720.201904 component latency= 1.438965
Comp name = osd_conv in_system_timestamp = 1609917750091.076904 out_system_timestamp = 1609917750093.023926 component latency= 1.947021
Comp name = nvosd0 in_system_timestamp = 1609917750093.191895 out_system_timestamp = 1609917750099.647949 component latency= 6.456055
Source id = 0 Frame_num = 0 Frame latency = 3426.184082 (ms)
BATCH-NUM = 1**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917747662.115967 out_system_timestamp = 1609917747706.394043 component latency= 44.278076
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 1 in_system_timestamp = 1609917747706.454102 out_system_timestamp = 1609917747777.795898 component_latency = 71.341797
Comp name = primary_gie in_system_timestamp = 1609917747777.840088 out_system_timestamp = 1609917747777.904053 component latency= 0.063965
Comp name = tracking_tracker in_system_timestamp = 1609917747777.918945 out_system_timestamp = 1609917747778.257080 component latency= 0.338135
Comp name = dsanalytics0 in_system_timestamp = 1609917747778.297119 out_system_timestamp = 1609917747778.445068 component latency= 0.147949
Comp name = demuxer in_system_timestamp = 1609917747778.462891 out_system_timestamp = 1609917747778.566895 component latency= 0.104004
Comp name = osd_conv in_system_timestamp = 1609917750093.408936 out_system_timestamp = 1609917750095.134033 component latency= 1.725098
Comp name = nvosd0 in_system_timestamp = 1609917750099.985107 out_system_timestamp = 1609917750109.362061 component latency= 9.376953
Source id = 0 Frame_num = 1 Frame latency = 2447.281982 (ms)
BATCH-NUM = 2**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917747662.195068 out_system_timestamp = 1609917747742.929932 component latency= 80.734863
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 2 in_system_timestamp = 1609917747742.995117 out_system_timestamp = 1609917747838.042969 component_latency = 95.047852
Comp name = primary_gie in_system_timestamp = 1609917747838.095947 out_system_timestamp = 1609917747898.062988 component latency= 59.967041
Comp name = tracking_tracker in_system_timestamp = 1609917747898.077881 out_system_timestamp = 1609917747898.617920 component latency= 0.540039
Comp name = dsanalytics0 in_system_timestamp = 1609917747898.667969 out_system_timestamp = 1609917747898.949951 component latency= 0.281982
Comp name = demuxer in_system_timestamp = 1609917747898.977051 out_system_timestamp = 1609917747899.079102 component latency= 0.102051
Comp name = osd_conv in_system_timestamp = 1609917750095.345947 out_system_timestamp = 1609917750099.846924 component latency= 4.500977
Comp name = nvosd0 in_system_timestamp = 1609917750109.589111 out_system_timestamp = 1609917750120.373047 component latency= 10.783936
Source id = 0 Frame_num = 2 Frame latency = 2458.210938 (ms)
BATCH-NUM = 3**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917747671.285889 out_system_timestamp = 1609917747788.690918 component latency= 117.405029
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 3 in_system_timestamp = 1609917747788.749023 out_system_timestamp = 1609917747898.499023 component_latency = 109.750000
Comp name = primary_gie in_system_timestamp = 1609917747899.841064 out_system_timestamp = 1609917747899.886963 component latency= 0.045898
Comp name = tracking_tracker in_system_timestamp = 1609917747899.916016 out_system_timestamp = 1609917747900.510986 component latency= 0.594971
Comp name = dsanalytics0 in_system_timestamp = 1609917747907.808105 out_system_timestamp = 1609917747908.052979 component latency= 0.244873
Comp name = demuxer in_system_timestamp = 1609917747908.075928 out_system_timestamp = 1609917747908.185059 component latency= 0.109131
Comp name = osd_conv in_system_timestamp = 1609917750100.205078 out_system_timestamp = 1609917750111.209961 component latency= 11.004883
Comp name = nvosd0 in_system_timestamp = 1609917750120.599121 out_system_timestamp = 1609917750123.888916 component latency= 3.289795
Source id = 0 Frame_num = 3 Frame latency = 2452.626221 (ms)
BATCH-NUM = 4**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917747674.221924 out_system_timestamp = 1609917747844.929932 component latency= 170.708008
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 4 in_system_timestamp = 1609917747844.989990 out_system_timestamp = 1609917747958.750977 component_latency = 113.760986
Comp name = primary_gie in_system_timestamp = 1609917747958.886963 out_system_timestamp = 1609917747959.011963 component latency= 0.125000
Comp name = tracking_tracker in_system_timestamp = 1609917747959.034912 out_system_timestamp = 1609917747959.477051 component latency= 0.442139
Comp name = dsanalytics0 in_system_timestamp = 1609917747959.518066 out_system_timestamp = 1609917747959.770996 component latency= 0.252930
Comp name = demuxer in_system_timestamp = 1609917747959.803955 out_system_timestamp = 1609917747959.946045 component latency= 0.142090
Comp name = osd_conv in_system_timestamp = 1609917750113.194092 out_system_timestamp = 1609917750121.354004 component latency= 8.159912
Comp name = nvosd0 in_system_timestamp = 1609917750124.051025 out_system_timestamp = 1609917750127.382080 component latency= 3.331055
Source id = 0 Frame_num = 4 Frame latency = 2453.177002 (ms)
BATCH-NUM = 4**
Batch meta not found for buffer 0x7fcc20068d70
BATCH-NUM = 5**
Batch meta not found for buffer 0x7fcddc0e1c90
BATCH-NUM = 6**
Batch meta not found for buffer 0x7fcbdc06d8d0
BATCH-NUM = 7**
Batch meta not found for buffer 0x7fcd100871b0
BATCH-NUM = 8**
Batch meta not found for buffer 0x7fcd98067e40
BATCH-NUM = 9**
Batch meta not found for buffer 0x7fcd3c084120
BATCH-NUM = 10**
Batch meta not found for buffer 0x7fcd100eb1d0
BATCH-NUM = 11**
Batch meta not found for buffer 0x7fcd100e78f0
BATCH-NUM = 12**
Batch meta not found for buffer 0x7fcbf80ca800
BATCH-NUM = 13**
Batch meta not found for buffer 0x7fcddc07ea00IOU Tracker Init with threshold 0.100000
BATCH-NUM = 5**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917747701.020996 out_system_timestamp = 1609917750094.988037 component latency= 2393.967041
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 5 in_system_timestamp = 1609917750095.050049 out_system_timestamp = 1609917750428.993896 component_latency = 333.943848
Comp name = primary_gie in_system_timestamp = 1609917750429.121094 out_system_timestamp = 1609917750429.275879 component latency= 0.154785
Comp name = tracking_tracker in_system_timestamp = 1609917750429.309082 out_system_timestamp = 1609917750431.073975 component latency= 1.764893
Comp name = dsanalytics0 in_system_timestamp = 1609917750431.123047 out_system_timestamp = 1609917750431.875977 component latency= 0.752930
Comp name = demuxer in_system_timestamp = 1609917750431.923096 out_system_timestamp = 1609917750432.012939 component latency= 0.089844
Comp name = osd_conv in_system_timestamp = 1609917750432.150879 out_system_timestamp = 1609917750452.225098 component latency= 20.074219
Comp name = nvosd0 in_system_timestamp = 1609917750452.412109 out_system_timestamp = 1609917750517.302979 component latency= 64.890869
Source id = 0 Frame_num = 5 Frame latency = 2816.333984 (ms)
BATCH-NUM = 14**
Batch meta not found for buffer 0x7fcb4c0b5e80
BATCH-NUM = 15**
Batch meta not found for buffer 0x7fcbdc0636d0
BATCH-NUM = 16**
Batch meta not found for buffer 0x7fcd1008f170
BATCH-NUM = 17**
Batch meta not found for buffer 0x7fcb940d4990
BATCH-NUM = 18**
Batch meta not found for buffer 0x7fcd3c0eb1a0
BATCH-NUM = 19**
Batch meta not found for buffer 0x7fcddc07f010
BATCH-NUM = 20**
Batch meta not found for buffer 0x7fcb4c09da40
BATCH-NUM = 21**
Batch meta not found for buffer 0x7fcd1c072a60
BATCH-NUM = 22**
Batch meta not found for buffer 0x7fccdc27b5b0
BATCH-NUM = 23**
Batch meta not found for buffer 0x7fcb70130170
BATCH-NUM = 24**
Batch meta not found for buffer 0x7fcb7c082910
BATCH-NUM = 25**
Batch meta not found for buffer 0x7fcbf80bbaa0
BATCH-NUM = 6**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917747742.655029 out_system_timestamp = 1609917750127.500977 component latency= 2384.845947
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 6 in_system_timestamp = 1609917750127.610107 out_system_timestamp = 1609917750489.757080 component_latency = 362.146973
Comp name = primary_gie in_system_timestamp = 1609917750489.822998 out_system_timestamp = 1609917750859.125977 component latency= 369.302979
Comp name = tracking_tracker in_system_timestamp = 1609917750859.162109 out_system_timestamp = 1609917750860.435059 component latency= 1.272949
Comp name = dsanalytics0 in_system_timestamp = 1609917750860.514893 out_system_timestamp = 1609917750861.246094 component latency= 0.731201
Comp name = demuxer in_system_timestamp = 1609917750861.297119 out_system_timestamp = 1609917750861.381104 component latency= 0.083984
Comp name = osd_conv in_system_timestamp = 1609917750861.518066 out_system_timestamp = 1609917750867.666016 component latency= 6.147949
Comp name = nvosd0 in_system_timestamp = 1609917750868.000000 out_system_timestamp = 1609917750903.022949 component latency= 35.022949
Source id = 0 Frame_num = 6 Frame latency = 3160.417969 (ms)
BATCH-NUM = 7**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917747762.872070 out_system_timestamp = 1609917750128.175049 component latency= 2365.302979
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 7 in_system_timestamp = 1609917750128.220947 out_system_timestamp = 1609917750550.370117 component_latency = 422.149170
Comp name = primary_gie in_system_timestamp = 1609917750639.070068 out_system_timestamp = 1609917750859.809082 component latency= 220.739014
Comp name = tracking_tracker in_system_timestamp = 1609917750859.836914 out_system_timestamp = 1609917750861.200928 component latency= 1.364014
Comp name = dsanalytics0 in_system_timestamp = 1609917750863.207031 out_system_timestamp = 1609917750863.766113 component latency= 0.559082
Comp name = demuxer in_system_timestamp = 1609917750863.823975 out_system_timestamp = 1609917750863.894043 component latency= 0.070068
Comp name = osd_conv in_system_timestamp = 1609917750867.982910 out_system_timestamp = 1609917750881.125000 component latency= 13.142090
Comp name = nvosd0 in_system_timestamp = 1609917750903.333984 out_system_timestamp = 1609917751087.846924 component latency= 184.512939
Source id = 0 Frame_num = 7 Frame latency = 3325.024902 (ms)
**PERF: 3.24 (3.15) 2.66 (2.60) 0.00 (0.00) 4.52 (4.32) 5.03 (4.80) 5.53 (5.28) 0.00 (0.00) 0.47 (0.46) 8.80 (7.75) 3.39 (3.31) 3.24 (2.96) 7.35 (6.45) 3.01 (2.77) 5.03 (4.80) 0.00 (0.00) 8.80 (7.75) 3.14 (3.07) 3.83 (3.73) 9.57 (8.49) 4.28 (3.88) 5.53 (5.28) 7.55 (3.27) 5.53 (5.28) 8.80 (7.75) 4.06 (3.94) 4.47 (3.42) 4.72 (4.23) 8.80 (7.75) 3.71 (3.62) 4.94 (4.74)
BATCH-NUM = 26**
Batch meta not found for buffer 0x7fcd94355a10
BATCH-NUM = 27**
Batch meta not found for buffer 0x7fcb4c069880
BATCH-NUM = 28**
Batch meta not found for buffer 0x7fcc100857e0
BATCH-NUM = 29**
Batch meta not found for buffer 0x7fcd3c069bd0
BATCH-NUM = 30**
Batch meta not found for buffer 0x7fcb4c056710
BATCH-NUM = 31**
Batch meta not found for buffer 0x7fcdec103070
BATCH-NUM = 32**
Batch meta not found for buffer 0x7fcb700c09d0
BATCH-NUM = 33**
Batch meta not found for buffer 0x7fcd4c078800
BATCH-NUM = 8**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917747839.372070 out_system_timestamp = 1609917750128.548096 component latency= 2289.176025
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 8 in_system_timestamp = 1609917750128.572998 out_system_timestamp = 1609917750610.851074 component_latency = 482.278076
Comp name = primary_gie in_system_timestamp = 1609917750639.267090 out_system_timestamp = 1609917750860.327881 component latency= 221.060791
Comp name = tracking_tracker in_system_timestamp = 1609917750860.345947 out_system_timestamp = 1609917750861.215088 component latency= 0.869141
Comp name = dsanalytics0 in_system_timestamp = 1609917750865.343994 out_system_timestamp = 1609917750865.733887 component latency= 0.389893
Comp name = demuxer in_system_timestamp = 1609917750865.771973 out_system_timestamp = 1609917750865.991943 component latency= 0.219971
Comp name = osd_conv in_system_timestamp = 1609917751360.977051 out_system_timestamp = 1609917751382.937012 component latency= 21.959961
Comp name = nvosd0 in_system_timestamp = 1609917751383.097900 out_system_timestamp = 1609917751407.334961 component latency= 24.237061
Source id = 0 Frame_num = 8 Frame latency = 3568.004883 (ms)
BATCH-NUM = 34**
Batch meta not found for buffer 0x7fcbf813a1c0
BATCH-NUM = 35**
Batch meta not found for buffer 0x7fcd7c06fb80
BATCH-NUM = 36**
Batch meta not found for buffer 0x7fcbdc069410
BATCH-NUM = 37**
Batch meta not found for buffer 0x7fccf807d150
BATCH-NUM = 38**
Batch meta not found for buffer 0x7fcc7006bc50
BATCH-NUM = 39**
Batch meta not found for buffer 0x7fccc40787b0
BATCH-NUM = 40**
Batch meta not found for buffer 0x7fccf8079950
BATCH-NUM = 41**
Batch meta not found for buffer 0x7fcb7c0751b0
BATCH-NUM = 42**
Batch meta not found for buffer 0x7fccf8079620
BATCH-NUM = 43**
Batch meta not found for buffer 0x7fcd980729f0
BATCH-NUM = 44**
Batch meta not found for buffer 0x7fcc200cc8a0
BATCH-NUM = 45**
Batch meta not found for buffer 0x7fcbdc107290
BATCH-NUM = 46**
Batch meta not found for buffer 0x7fcd3c0c79e0
BATCH-NUM = 47**
Batch meta not found for buffer 0x7fccc40c33e0
BATCH-NUM = 48**
Batch meta not found for buffer 0x7fcd98070d10
BATCH-NUM = 49**
Batch meta not found for buffer 0x7fcdec07f220
BATCH-NUM = 9**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917747846.094971 out_system_timestamp = 1609917750130.898926 component latency= 2284.803955
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 9 in_system_timestamp = 1609917750131.020996 out_system_timestamp = 1609917750671.472900 component_latency = 540.451904
Comp name = primary_gie in_system_timestamp = 1609917750671.531006 out_system_timestamp = 1609917751107.552979 component latency= 436.021973
Comp name = tracking_tracker in_system_timestamp = 1609917751107.589111 out_system_timestamp = 1609917751109.280029 component latency= 1.690918
Comp name = dsanalytics0 in_system_timestamp = 1609917751109.326904 out_system_timestamp = 1609917751109.951904 component latency= 0.625000
Comp name = demuxer in_system_timestamp = 1609917751110.007080 out_system_timestamp = 1609917751110.083984 component latency= 0.076904
Comp name = osd_conv in_system_timestamp = 1609917751488.172119 out_system_timestamp = 1609917751503.897949 component latency= 15.725830
Comp name = nvosd0 in_system_timestamp = 1609917751504.086914 out_system_timestamp = 1609917751517.459961 component latency= 13.373047
Source id = 0 Frame_num = 9 Frame latency = 3671.416992 (ms)
BATCH-NUM = 50**
Batch meta not found for buffer 0x7fcb4c0d53f0
BATCH-NUM = 51**
Batch meta not found for buffer 0x7fcc1007d090
BATCH-NUM = 52**
Batch meta not found for buffer 0x7fcbc408d390
BATCH-NUM = 53**
Batch meta not found for buffer 0x7fcb400ef620
BATCH-NUM = 54**
Batch meta not found for buffer 0x7fcc10061d10
BATCH-NUM = 10**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917750125.593994 out_system_timestamp = 1609917750496.285889 component latency= 370.691895
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 10 in_system_timestamp = 1609917750496.386963 out_system_timestamp = 1609917750923.930908 component_latency = 427.543945
Comp name = primary_gie in_system_timestamp = 1609917750924.061035 out_system_timestamp = 1609917751108.143066 component latency= 184.082031
Comp name = tracking_tracker in_system_timestamp = 1609917751108.169922 out_system_timestamp = 1609917751109.331055 component latency= 1.161133
Comp name = dsanalytics0 in_system_timestamp = 1609917751111.485107 out_system_timestamp = 1609917751111.891113 component latency= 0.406006
Comp name = demuxer in_system_timestamp = 1609917751111.947998 out_system_timestamp = 1609917751112.022949 component latency= 0.074951
Comp name = osd_conv in_system_timestamp = 1609917751678.229004 out_system_timestamp = 1609917751682.959961 component latency= 4.730957
Comp name = nvosd0 in_system_timestamp = 1609917751683.139893 out_system_timestamp = 1609917751701.711914 component latency= 18.572021
Source id = 0 Frame_num = 10 Frame latency = 1576.170898 (ms)
BATCH-NUM = 55**
Batch meta not found for buffer 0x7fcc2008bc20
BATCH-NUM = 56**
Batch meta not found for buffer 0x7fcc1006e340
BATCH-NUM = 11**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917750127.669922 out_system_timestamp = 1609917750891.996094 component latency= 764.326172
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 11 in_system_timestamp = 1609917750892.168945 out_system_timestamp = 1609917750984.525879 component_latency = 92.356934
Comp name = primary_gie in_system_timestamp = 1609917750984.629883 out_system_timestamp = 1609917751108.820068 component latency= 124.190186
Comp name = tracking_tracker in_system_timestamp = 1609917751108.854980 out_system_timestamp = 1609917751109.460938 component latency= 0.605957
Comp name = dsanalytics0 in_system_timestamp = 1609917751113.412109 out_system_timestamp = 1609917751113.712891 component latency= 0.300781
Comp name = demuxer in_system_timestamp = 1609917751113.742920 out_system_timestamp = 1609917751113.789062 component latency= 0.046143
Comp name = osd_conv in_system_timestamp = 1609917751867.625977 out_system_timestamp = 1609917751889.282959 component latency= 21.656982
Comp name = nvosd0 in_system_timestamp = 1609917751889.465088 out_system_timestamp = 1609917751921.023926 component latency= 31.558838
Source id = 0 Frame_num = 11 Frame latency = 1793.402100 (ms)
BATCH-NUM = 57**
Batch meta not found for buffer 0x7fccf80841c0
BATCH-NUM = 58**
Batch meta not found for buffer 0x7fcb7c07f600
BATCH-NUM = 12**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917750128.373047 out_system_timestamp = 1609917750968.844971 component latency= 840.471924
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 12 in_system_timestamp = 1609917750968.971924 out_system_timestamp = 1609917751044.935059 component_latency = 75.963135
Comp name = primary_gie in_system_timestamp = 1609917751045.031006 out_system_timestamp = 1609917751280.352051 component latency= 235.321045
Comp name = tracking_tracker in_system_timestamp = 1609917751280.377930 out_system_timestamp = 1609917751281.404053 component latency= 1.026123
Comp name = dsanalytics0 in_system_timestamp = 1609917751281.437988 out_system_timestamp = 1609917751281.908936 component latency= 0.470947
Comp name = demuxer in_system_timestamp = 1609917751281.937012 out_system_timestamp = 1609917751282.020996 component latency= 0.083984
Comp name = osd_conv in_system_timestamp = 1609917751999.677979 out_system_timestamp = 1609917752076.033936 component latency= 76.355957
Comp name = nvosd0 in_system_timestamp = 1609917752076.175049 out_system_timestamp = 1609917752107.439941 component latency= 31.264893
Source id = 0 Frame_num = 12 Frame latency = 1979.091064 (ms)
BATCH-NUM = 13**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917750128.636963 out_system_timestamp = 1609917751406.641113 component latency= 1278.004150
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 13 in_system_timestamp = 1609917751406.802979 out_system_timestamp = 1609917751413.513916 component_latency = 6.710938
Comp name = primary_gie in_system_timestamp = 1609917751413.587891 out_system_timestamp = 1609917751413.688965 component latency= 0.101074
Comp name = tracking_tracker in_system_timestamp = 1609917751413.718018 out_system_timestamp = 1609917751414.198975 component latency= 0.480957
Comp name = dsanalytics0 in_system_timestamp = 1609917751414.221924 out_system_timestamp = 1609917751414.349121 component latency= 0.127197
Comp name = demuxer in_system_timestamp = 1609917751414.361084 out_system_timestamp = 1609917751415.108887 component latency= 0.747803
Comp name = osd_conv in_system_timestamp = 1609917752259.351074 out_system_timestamp = 1609917752260.587891 component latency= 1.236816
Comp name = nvosd0 in_system_timestamp = 1609917752260.761963 out_system_timestamp = 1609917752269.358887 component latency= 8.596924
Source id = 0 Frame_num = 13 Frame latency = 2140.766113 (ms)
BATCH-NUM = 59**
Batch meta not found for buffer 0x7fcd3c0ef490
BATCH-NUM = 14**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917750142.106934 out_system_timestamp = 1609917751510.584961 component latency= 1368.478027
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 14 in_system_timestamp = 1609917751510.708984 out_system_timestamp = 1609917751534.309082 component_latency = 23.600098
Comp name = primary_gie in_system_timestamp = 1609917751534.556885 out_system_timestamp = 1609917751621.252930 component latency= 86.696045
Comp name = tracking_tracker in_system_timestamp = 1609917751621.268066 out_system_timestamp = 1609917751622.022949 component latency= 0.754883
Comp name = dsanalytics0 in_system_timestamp = 1609917751624.094971 out_system_timestamp = 1609917751624.365967 component latency= 0.270996
Comp name = demuxer in_system_timestamp = 1609917751624.392090 out_system_timestamp = 1609917751625.438965 component latency= 1.046875
Comp name = osd_conv in_system_timestamp = 1609917752358.011963 out_system_timestamp = 1609917752360.635010 component latency= 2.623047
Comp name = nvosd0 in_system_timestamp = 1609917752360.782959 out_system_timestamp = 1609917752364.558105 component latency= 3.775146
Source id = 0 Frame_num = 14 Frame latency = 2222.474121 (ms)
BATCH-NUM = 60**
Batch meta not found for buffer 0x7fcbdc137cf0
BATCH-NUM = 15**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917750496.520996 out_system_timestamp = 1609917751691.385010 component latency= 1194.864014
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 15 in_system_timestamp = 1609917751691.551025 out_system_timestamp = 1609917751747.686035 component_latency = 56.135010
Comp name = primary_gie in_system_timestamp = 1609917751747.747070 out_system_timestamp = 1609917751840.955078 component latency= 93.208008
Comp name = tracking_tracker in_system_timestamp = 1609917751840.966064 out_system_timestamp = 1609917751841.376953 component latency= 0.410889
Comp name = dsanalytics0 in_system_timestamp = 1609917751842.530029 out_system_timestamp = 1609917751842.593994 component latency= 0.063965
Comp name = demuxer in_system_timestamp = 1609917751842.601074 out_system_timestamp = 1609917751842.644043 component latency= 0.042969
Comp name = osd_conv in_system_timestamp = 1609917752464.437988 out_system_timestamp = 1609917752465.812988 component latency= 1.375000
Comp name = nvosd0 in_system_timestamp = 1609917752465.982910 out_system_timestamp = 1609917752479.345947 component latency= 13.363037
Source id = 0 Frame_num = 15 Frame latency = 1982.853027 (ms)
BATCH-NUM = 61**
Batch meta not found for buffer 0x7fcc3c122e50
BATCH-NUM = 16**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917750892.716064 out_system_timestamp = 1609917751911.808105 component latency= 1019.092041
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 16 in_system_timestamp = 1609917751911.991943 out_system_timestamp = 1609917751959.333984 component_latency = 47.342041
Comp name = primary_gie in_system_timestamp = 1609917751959.404053 out_system_timestamp = 1609917752143.811035 component latency= 184.406982
Comp name = tracking_tracker in_system_timestamp = 1609917752143.841064 out_system_timestamp = 1609917752144.724121 component latency= 0.883057
Comp name = dsanalytics0 in_system_timestamp = 1609917752144.945068 out_system_timestamp = 1609917752145.663086 component latency= 0.718018
Comp name = demuxer in_system_timestamp = 1609917752145.702881 out_system_timestamp = 1609917752346.802979 component latency= 201.100098
Comp name = osd_conv in_system_timestamp = 1609917752571.272949 out_system_timestamp = 1609917752571.870117 component latency= 0.597168
Comp name = nvosd0 in_system_timestamp = 1609917752572.000977 out_system_timestamp = 1609917752576.441895 component latency= 4.440918
Source id = 0 Frame_num = 16 Frame latency = 1683.766846 (ms)
BATCH-NUM = 62**
Batch meta not found for buffer 0x7fcc480826c0
BATCH-NUM = 63**
Batch meta not found for buffer 0x7fcd4c083bb0
BATCH-NUM = 64**
Batch meta not found for buffer 0x7fcb940d4cc0
BATCH-NUM = 17**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917750968.969971 out_system_timestamp = 1609917752146.974121 component latency= 1178.004150
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 17 in_system_timestamp = 1609917752147.102051 out_system_timestamp = 1609917752148.367920 component_latency = 1.265869
Comp name = primary_gie in_system_timestamp = 1609917752148.414062 out_system_timestamp = 1609917752195.197998 component latency= 46.783936
Comp name = tracking_tracker in_system_timestamp = 1609917752195.218994 out_system_timestamp = 1609917752195.517090 component latency= 0.298096
Comp name = dsanalytics0 in_system_timestamp = 1609917752379.514893 out_system_timestamp = 1609917752379.633057 component latency= 0.118164
Comp name = demuxer in_system_timestamp = 1609917752379.648926 out_system_timestamp = 1609917752379.896973 component latency= 0.248047
Comp name = osd_conv in_system_timestamp = 1609917752852.683105 out_system_timestamp = 1609917752859.122070 component latency= 6.438965
Comp name = nvosd0 in_system_timestamp = 1609917752859.299072 out_system_timestamp = 1609917752872.873047 component latency= 13.573975
Source id = 0 Frame_num = 17 Frame latency = 1903.944092 (ms)
BATCH-NUM = 18**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917751510.802979 out_system_timestamp = 1609917752263.032959 component latency= 752.229980
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 18 in_system_timestamp = 1609917752263.148926 out_system_timestamp = 1609917752437.061035 component_latency = 173.912109
Comp name = primary_gie in_system_timestamp = 1609917752437.138916 out_system_timestamp = 1609917752437.229980 component latency= 0.091064
Comp name = tracking_tracker in_system_timestamp = 1609917752437.273926 out_system_timestamp = 1609917752438.757080 component latency= 1.483154
Comp name = dsanalytics0 in_system_timestamp = 1609917752438.806885 out_system_timestamp = 1609917752439.593018 component latency= 0.786133
Comp name = demuxer in_system_timestamp = 1609917752439.635986 out_system_timestamp = 1609917752439.709961 component latency= 0.073975
Comp name = osd_conv in_system_timestamp = 1609917753137.178955 out_system_timestamp = 1609917753146.693115 component latency= 9.514160
Comp name = nvosd0 in_system_timestamp = 1609917753146.850098 out_system_timestamp = 1609917753168.073975 component latency= 21.223877
Source id = 0 Frame_num = 18 Frame latency = 1657.317139 (ms)
BATCH-NUM = 65**
Batch meta not found for buffer 0x7fcc3c0b80d0
BATCH-NUM = 66**
Batch meta not found for buffer 0x7fcb7c0992e0
BATCH-NUM = 67**
Batch meta not found for buffer 0x7fcb940c9ad0
BATCH-NUM = 68**
Batch meta not found for buffer 0x7fcb4c0563e0
BATCH-NUM = 19**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917751510.896973 out_system_timestamp = 1609917752363.552979 component latency= 852.656006
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 19 in_system_timestamp = 1609917752363.689941 out_system_timestamp = 1609917752498.132080 component_latency = 134.442139
Comp name = primary_gie in_system_timestamp = 1609917752498.205078 out_system_timestamp = 1609917752498.313965 component latency= 0.108887
Comp name = tracking_tracker in_system_timestamp = 1609917752498.356934 out_system_timestamp = 1609917752499.549072 component latency= 1.192139
Comp name = dsanalytics0 in_system_timestamp = 1609917752499.594971 out_system_timestamp = 1609917752500.354004 component latency= 0.759033
Comp name = demuxer in_system_timestamp = 1609917752500.415039 out_system_timestamp = 1609917752500.517090 component latency= 0.102051
Comp name = osd_conv in_system_timestamp = 1609917753344.157959 out_system_timestamp = 1609917753344.597900 component latency= 0.439941
Comp name = nvosd0 in_system_timestamp = 1609917753344.800049 out_system_timestamp = 1609917753351.562988 component latency= 6.762939
Source id = 0 Frame_num = 19 Frame latency = 1840.708984 (ms)
BATCH-NUM = 69**
Batch meta not found for buffer 0x7fcc10074260
BATCH-NUM = 70**
Batch meta not found for buffer 0x7fcdec0f88c0
BATCH-NUM = 71**
Batch meta not found for buffer 0x7fcc200bde00
BATCH-NUM = 20**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917751691.493896 out_system_timestamp = 1609917752473.782959 component latency= 782.289062
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 20 in_system_timestamp = 1609917752473.941895 out_system_timestamp = 1609917752558.846924 component_latency = 84.905029
Comp name = primary_gie in_system_timestamp = 1609917752558.906006 out_system_timestamp = 1609917752787.049072 component latency= 228.143066
Comp name = tracking_tracker in_system_timestamp = 1609917752787.082031 out_system_timestamp = 1609917752788.837891 component latency= 1.755859
Comp name = dsanalytics0 in_system_timestamp = 1609917752848.873047 out_system_timestamp = 1609917752849.414062 component latency= 0.541016
Comp name = demuxer in_system_timestamp = 1609917752849.458008 out_system_timestamp = 1609917752849.524902 component latency= 0.066895
Comp name = osd_conv in_system_timestamp = 1609917753571.541992 out_system_timestamp = 1609917753580.865967 component latency= 9.323975
Comp name = nvosd0 in_system_timestamp = 1609917753581.001953 out_system_timestamp = 1609917753588.173096 component latency= 7.171143
Source id = 0 Frame_num = 20 Frame latency = 1896.722168 (ms)
BATCH-NUM = 72**
Batch meta not found for buffer 0x7fcddc0799b0
BATCH-NUM = 73**
BATCH-NUM = 74**
Batch meta not found for buffer 0x7fcb4c072370
BATCH-NUM = 75**
Batch meta not found for buffer 0x7fcbc40d5630
BATCH-NUM = 76**
Batch meta not found for buffer 0x7fcd10272190
BATCH-NUM = 77**
Batch meta not found for buffer 0x7fcb940fb710
BATCH-NUM = 21**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917751912.060059 out_system_timestamp = 1609917752575.031006 component latency= 662.970947
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 21 in_system_timestamp = 1609917752575.197021 out_system_timestamp = 1609917752619.439941 component_latency = 44.242920
Comp name = primary_gie in_system_timestamp = 1609917752619.562012 out_system_timestamp = 1609917752787.779053 component latency= 168.217041
Comp name = tracking_tracker in_system_timestamp = 1609917752787.805908 out_system_timestamp = 1609917752788.896973 component latency= 1.091064
Comp name = dsanalytics0 in_system_timestamp = 1609917752979.996094 out_system_timestamp = 1609917752980.745117 component latency= 0.749023
Comp name = demuxer in_system_timestamp = 1609917752980.795898 out_system_timestamp = 1609917752982.062012 component latency= 1.266113
Comp name = osd_conv in_system_timestamp = 1609917753780.909912 out_system_timestamp = 1609917753806.355957 component latency= 25.446045
Comp name = nvosd0 in_system_timestamp = 1609917753806.531982 out_system_timestamp = 1609917753818.664062 component latency= 12.132080
Source id = 0 Frame_num = 21 Frame latency = 1906.647949 (ms)
BATCH-NUM = 78**
Batch meta not found for buffer 0x7fcdec082ce0
BATCH-NUM = 79**
Batch meta not found for buffer 0x7fccdc080770
BATCH-NUM = 22**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917752147.077881 out_system_timestamp = 1609917752870.451904 component latency= 723.374023
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 22 in_system_timestamp = 1609917752870.570068 out_system_timestamp = 1609917752902.186035 component_latency = 31.615967
Comp name = primary_gie in_system_timestamp = 1609917752902.260986 out_system_timestamp = 1609917753142.527100 component latency= 240.266113
Comp name = tracking_tracker in_system_timestamp = 1609917753142.547119 out_system_timestamp = 1609917753143.593994 component latency= 1.046875
Comp name = dsanalytics0 in_system_timestamp = 1609917753143.637939 out_system_timestamp = 1609917753144.343018 component latency= 0.705078
Comp name = demuxer in_system_timestamp = 1609917753144.405029 out_system_timestamp = 1609917753146.102051 component latency= 1.697021
Comp name = osd_conv in_system_timestamp = 1609917753897.156006 out_system_timestamp = 1609917753902.124023 component latency= 4.968018
Comp name = nvosd0 in_system_timestamp = 1609917753902.262939 out_system_timestamp = 1609917753908.687012 component latency= 6.424072
Source id = 0 Frame_num = 22 Frame latency = 1761.650146 (ms)
BATCH-NUM = 80**
Batch meta not found for buffer 0x7fcd7c0750c0
BATCH-NUM = 81**
Batch meta not found for buffer 0x7fcb940665c0
BATCH-NUM = 82**
Batch meta not found for buffer 0x7fcd982627e0
BATCH-NUM = 83**
Batch meta not found for buffer 0x7fcd3c05c050
BATCH-NUM = 84**
Batch meta not found for buffer 0x7fcb2809d220
BATCH-NUM = 85**
Batch meta not found for buffer 0x7fcb940e5990
BATCH-NUM = 23**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917752263.249023 out_system_timestamp = 1609917753158.826904 component latency= 895.577881
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 23 in_system_timestamp = 1609917753158.955078 out_system_timestamp = 1609917753190.022949 component_latency = 31.067871
Comp name = primary_gie in_system_timestamp = 1609917753190.090088 out_system_timestamp = 1609917753309.740967 component latency= 119.650879
Comp name = tracking_tracker in_system_timestamp = 1609917753309.767090 out_system_timestamp = 1609917753310.512939 component latency= 0.745850
Comp name = dsanalytics0 in_system_timestamp = 1609917753311.395020 out_system_timestamp = 1609917753311.674072 component latency= 0.279053
Comp name = demuxer in_system_timestamp = 1609917753311.701904 out_system_timestamp = 1609917753312.129883 component latency= 0.427979
Comp name = osd_conv in_system_timestamp = 1609917754125.372070 out_system_timestamp = 1609917754135.540039 component latency= 10.167969
Comp name = nvosd0 in_system_timestamp = 1609917754135.722900 out_system_timestamp = 1609917754145.656982 component latency= 9.934082
Source id = 0 Frame_num = 23 Frame latency = 1882.445068 (ms)
BATCH-NUM = 86**
Batch meta not found for buffer 0x7fcbac102960
BATCH-NUM = 87**
Batch meta not found for buffer 0x7fcd980747f0
BATCH-NUM = 24**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917752363.689941 out_system_timestamp = 1609917753347.206055 component latency= 983.516113
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 24 in_system_timestamp = 1609917753347.370117 out_system_timestamp = 1609917753371.904053 component_latency = 24.533936
Comp name = primary_gie in_system_timestamp = 1609917753371.972900 out_system_timestamp = 1609917753542.464111 component latency= 170.491211
Comp name = tracking_tracker in_system_timestamp = 1609917753542.521973 out_system_timestamp = 1609917753543.701904 component latency= 1.179932
Comp name = dsanalytics0 in_system_timestamp = 1609917753544.061035 out_system_timestamp = 1609917753544.600098 component latency= 0.539062
Comp name = demuxer in_system_timestamp = 1609917753544.639893 out_system_timestamp = 1609917753545.656982 component latency= 1.017090
Comp name = osd_conv in_system_timestamp = 1609917754232.389893 out_system_timestamp = 1609917754235.907959 component latency= 3.518066
Comp name = nvosd0 in_system_timestamp = 1609917754236.045898 out_system_timestamp = 1609917754245.970947 component latency= 9.925049
Source id = 0 Frame_num = 24 Frame latency = 1882.322998 (ms)
BATCH-NUM = 88**
Batch meta not found for buffer 0x7fcdb007e880
BATCH-NUM = 89**
Batch meta not found for buffer 0x7fcd1c0bf260
BATCH-NUM = 90**
Batch meta not found for buffer 0x7fcb7c09c150
BATCH-NUM = 25**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917752474.002930 out_system_timestamp = 1609917753586.460938 component latency= 1112.458008
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 25 in_system_timestamp = 1609917753586.620117 out_system_timestamp = 1609917753604.885986 component_latency = 18.265869
Comp name = primary_gie in_system_timestamp = 1609917753604.941895 out_system_timestamp = 1609917753772.582031 component latency= 167.640137
Comp name = tracking_tracker in_system_timestamp = 1609917753772.612061 out_system_timestamp = 1609917753773.763916 component latency= 1.151855
Comp name = dsanalytics0 in_system_timestamp = 1609917754202.743896 out_system_timestamp = 1609917754203.208984 component latency= 0.465088
Comp name = demuxer in_system_timestamp = 1609917754203.263916 out_system_timestamp = 1609917754204.218994 component latency= 0.955078
Comp name = osd_conv in_system_timestamp = 1609917754340.840088 out_system_timestamp = 1609917754348.427002 component latency= 7.586914
Comp name = nvosd0 in_system_timestamp = 1609917754348.645020 out_system_timestamp = 1609917754362.333008 component latency= 13.687988
Source id = 0 Frame_num = 25 Frame latency = 1888.370117 (ms)
BATCH-NUM = 91**
Batch meta not found for buffer 0x7fcbdc1076d0
BATCH-NUM = 26**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917752870.659912 out_system_timestamp = 1609917753817.552002 component latency= 946.892090
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 26 in_system_timestamp = 1609917753817.718994 out_system_timestamp = 1609917753831.073975 component_latency = 13.354980
Comp name = primary_gie in_system_timestamp = 1609917753831.190918 out_system_timestamp = 1609917753831.263916 component latency= 0.072998
Comp name = tracking_tracker in_system_timestamp = 1609917753831.285889 out_system_timestamp = 1609917753832.018066 component latency= 0.732178
Comp name = dsanalytics0 in_system_timestamp = 1609917754209.593994 out_system_timestamp = 1609917754209.949951 component latency= 0.355957
Comp name = demuxer in_system_timestamp = 1609917754209.985107 out_system_timestamp = 1609917754210.794922 component latency= 0.809814
Comp name = osd_conv in_system_timestamp = 1609917754519.014893 out_system_timestamp = 1609917754615.635986 component latency= 96.621094
Comp name = nvosd0 in_system_timestamp = 1609917754615.849121 out_system_timestamp = 1609917754630.840088 component latency= 14.990967
Source id = 0 Frame_num = 26 Frame latency = 1760.247070 (ms)
BATCH-NUM = 92**
Batch meta not found for buffer 0x7fccc40d0de0
BATCH-NUM = 93**
Batch meta not found for buffer 0x7fcbc408ec00
BATCH-NUM = 94**
BATCH-NUM = 95**
Batch meta not found for buffer 0x7fccdc08dcc0
BATCH-NUM = 96**
Batch meta not found for buffer 0x7fcd7c06a170
BATCH-NUM = 97**
Batch meta not found for buffer 0x7fcc20076de0
BATCH-NUM = 27**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917753158.981934 out_system_timestamp = 1609917753911.149902 component latency= 752.167969
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 27 in_system_timestamp = 1609917753911.253906 out_system_timestamp = 1609917754263.987061 component_latency = 352.733154
Comp name = primary_gie in_system_timestamp = 1609917754264.081055 out_system_timestamp = 1609917754264.211914 component latency= 0.130859
Comp name = tracking_tracker in_system_timestamp = 1609917754264.260010 out_system_timestamp = 1609917754265.500977 component latency= 1.240967
Comp name = dsanalytics0 in_system_timestamp = 1609917754292.775879 out_system_timestamp = 1609917754293.116943 component latency= 0.341064
Comp name = demuxer in_system_timestamp = 1609917754293.139893 out_system_timestamp = 1609917754293.194092 component latency= 0.054199
Comp name = osd_conv in_system_timestamp = 1609917754740.602051 out_system_timestamp = 1609917754741.007080 component latency= 0.405029
Comp name = nvosd0 in_system_timestamp = 1609917754741.227051 out_system_timestamp = 1609917754749.175049 component latency= 7.947998
Source id = 0 Frame_num = 27 Frame latency = 1590.228027 (ms)
BATCH-NUM = 98**
Batch meta not found for buffer 0x7fcb400771f0
BATCH-NUM = 99**
Batch meta not found for buffer 0x7fcddc0e1410
BATCH-NUM = 100**
Batch meta not found for buffer 0x7fcb4c078c80
BATCH-NUM = 101**
Batch meta not found for buffer 0x7fcc1006e890
BATCH-NUM = 28**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917753347.385010 out_system_timestamp = 1609917754137.417969 component latency= 790.032959
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 28 in_system_timestamp = 1609917754137.524902 out_system_timestamp = 1609917754324.845947 component_latency = 187.321045
Comp name = primary_gie in_system_timestamp = 1609917754324.930908 out_system_timestamp = 1609917754325.022949 component latency= 0.092041
Comp name = tracking_tracker in_system_timestamp = 1609917754325.066895 out_system_timestamp = 1609917754326.256104 component latency= 1.189209
Comp name = dsanalytics0 in_system_timestamp = 1609917754355.499023 out_system_timestamp = 1609917754356.166016 component latency= 0.666992
Comp name = demuxer in_system_timestamp = 1609917754356.221924 out_system_timestamp = 1609917754356.310059 component latency= 0.088135
Comp name = osd_conv in_system_timestamp = 1609917754960.891113 out_system_timestamp = 1609917755016.753906 component latency= 55.862793
Comp name = nvosd0 in_system_timestamp = 1609917755016.899902 out_system_timestamp = 1609917755032.287109 component latency= 15.387207
Source id = 0 Frame_num = 28 Frame latency = 1684.937988 (ms)
BATCH-NUM = 102**
Batch meta not found for buffer 0x7fcdec0847f0
BATCH-NUM = 103**
Batch meta not found for buffer 0x7fcab000aa70
BATCH-NUM = 104**
Batch meta not found for buffer 0x7fcdec0fc600
BATCH-NUM = 105**
Batch meta not found for buffer 0x7fcd9807beb0
BATCH-NUM = 29**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917753586.647949 out_system_timestamp = 1609917754245.068115 component latency= 658.420166
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 29 in_system_timestamp = 1609917754245.197998 out_system_timestamp = 1609917754385.571045 component_latency = 140.373047
Comp name = primary_gie in_system_timestamp = 1609917754385.666992 out_system_timestamp = 1609917754621.506104 component latency= 235.839111
Comp name = tracking_tracker in_system_timestamp = 1609917754621.543945 out_system_timestamp = 1609917754623.251953 component latency= 1.708008
Comp name = dsanalytics0 in_system_timestamp = 1609917754719.405029 out_system_timestamp = 1609917754719.931885 component latency= 0.526855
Comp name = demuxer in_system_timestamp = 1609917754719.970947 out_system_timestamp = 1609917754720.041992 component latency= 0.071045
Comp name = osd_conv in_system_timestamp = 1609917755257.181885 out_system_timestamp = 1609917755257.678955 component latency= 0.497070
Comp name = nvosd0 in_system_timestamp = 1609917755257.809082 out_system_timestamp = 1609917755264.979980 component latency= 7.170898
Source id = 0 Frame_num = 29 Frame latency = 1678.375000 (ms)
BATCH-NUM = 106**
Batch meta not found for buffer 0x7fcd100c49b0
BATCH-NUM = 107**
BATCH-NUM = 108**
Batch meta not found for buffer 0x7fcc10067770
BATCH-NUM = 109**
BATCH-NUM = 110**
Batch meta not found for buffer 0x7fcb7c0881f0
BATCH-NUM = 111**
Batch meta not found for buffer 0x7fccf810db10
BATCH-NUM = 112**
Batch meta not found for buffer 0x7fcb7c076b80
BATCH-NUM = 30**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917753817.705078 out_system_timestamp = 1609917754357.974121 component latency= 540.269043
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 30 in_system_timestamp = 1609917754358.047119 out_system_timestamp = 1609917754445.995117 component_latency = 87.947998
Comp name = primary_gie in_system_timestamp = 1609917754446.123047 out_system_timestamp = 1609917754622.270996 component latency= 176.147949
Comp name = tracking_tracker in_system_timestamp = 1609917754622.299072 out_system_timestamp = 1609917754623.293945 component latency= 0.994873
Comp name = dsanalytics0 in_system_timestamp = 1609917754816.322021 out_system_timestamp = 1609917754816.923096 component latency= 0.601074
Comp name = demuxer in_system_timestamp = 1609917754816.978027 out_system_timestamp = 1609917754817.073975 component latency= 0.095947
Comp name = osd_conv in_system_timestamp = 1609917755354.208984 out_system_timestamp = 1609917755356.583984 component latency= 2.375000
Comp name = nvosd0 in_system_timestamp = 1609917755356.722900 out_system_timestamp = 1609917755375.129883 component latency= 18.406982
Source id = 0 Frame_num = 30 Frame latency = 1557.471924 (ms)
BATCH-NUM = 113**
Batch meta not found for buffer 0x7fcd982821a0
BATCH-NUM = 114**
Batch meta not found for buffer 0x7fcd9826b550
BATCH-NUM = 115**
Batch meta not found for buffer 0x7fcb5c059c70
BATCH-NUM = 31**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917753911.251953 out_system_timestamp = 1609917754633.112061 component latency= 721.860107
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 31 in_system_timestamp = 1609917754633.219971 out_system_timestamp = 1609917754773.253906 component_latency = 140.033936
Comp name = primary_gie in_system_timestamp = 1609917754773.335938 out_system_timestamp = 1609917755020.487061 component latency= 247.151123
Comp name = tracking_tracker in_system_timestamp = 1609917755020.539062 out_system_timestamp = 1609917755022.561035 component latency= 2.021973
Comp name = dsanalytics0 in_system_timestamp = 1609917755022.938965 out_system_timestamp = 1609917755023.591064 component latency= 0.652100
Comp name = demuxer in_system_timestamp = 1609917755023.654053 out_system_timestamp = 1609917755023.733887 component latency= 0.079834
Comp name = osd_conv in_system_timestamp = 1609917755583.809082 out_system_timestamp = 1609917755589.152100 component latency= 5.343018
Comp name = nvosd0 in_system_timestamp = 1609917755589.292969 out_system_timestamp = 1609917755603.610107 component latency= 14.317139
Source id = 0 Frame_num = 31 Frame latency = 1692.431152 (ms)
BATCH-NUM = 116**
Batch meta not found for buffer 0x7fcd3c0e3660
BATCH-NUM = 117**
Batch meta not found for buffer 0x7fcbdc0858e0
BATCH-NUM = 118**
Batch meta not found for buffer 0x7fcb2806c180
BATCH-NUM = 119**
Batch meta not found for buffer 0x7fccdc07b150
BATCH-NUM = 120**
Batch meta not found for buffer 0x7fcb940ca580
BATCH-NUM = 32**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917754137.673096 out_system_timestamp = 1609917754746.957031 component latency= 609.283936
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 32 in_system_timestamp = 1609917754747.073975 out_system_timestamp = 1609917754833.827881 component_latency = 86.753906
Comp name = primary_gie in_system_timestamp = 1609917754833.959961 out_system_timestamp = 1609917755021.367920 component latency= 187.407959
Comp name = tracking_tracker in_system_timestamp = 1609917755021.439941 out_system_timestamp = 1609917755022.635010 component latency= 1.195068
Comp name = dsanalytics0 in_system_timestamp = 1609917755121.055908 out_system_timestamp = 1609917755121.840088 component latency= 0.784180
Comp name = demuxer in_system_timestamp = 1609917755121.904053 out_system_timestamp = 1609917755121.985107 component latency= 0.081055
Comp name = osd_conv in_system_timestamp = 1609917755697.281006 out_system_timestamp = 1609917755701.147949 component latency= 3.866943
Comp name = nvosd0 in_system_timestamp = 1609917755701.308105 out_system_timestamp = 1609917755705.940918 component latency= 4.632812
Source id = 0 Frame_num = 32 Frame latency = 1568.305908 (ms)
BATCH-NUM = 121**
Batch meta not found for buffer 0x7fcb4c07ee10
BATCH-NUM = 122**
Batch meta not found for buffer 0x7fcb7c073d50
BATCH-NUM = 123**
Batch meta not found for buffer 0x7fcddc104790
BATCH-NUM = 124**
Batch meta not found for buffer 0x7fccc4086d00
BATCH-NUM = 33**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917754245.335938 out_system_timestamp = 1609917755019.340088 component latency= 774.004150
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 33 in_system_timestamp = 1609917755019.450928 out_system_timestamp = 1609917755073.511963 component_latency = 54.061035
Comp name = primary_gie in_system_timestamp = 1609917755073.574951 out_system_timestamp = 1609917755259.562012 component latency= 185.987061
Comp name = tracking_tracker in_system_timestamp = 1609917755259.596924 out_system_timestamp = 1609917755260.397949 component latency= 0.801025
Comp name = dsanalytics0 in_system_timestamp = 1609917755282.680908 out_system_timestamp = 1609917755282.979004 component latency= 0.298096
Comp name = demuxer in_system_timestamp = 1609917755283.004883 out_system_timestamp = 1609917755283.085938 component latency= 0.081055
Comp name = osd_conv in_system_timestamp = 1609917755791.791016 out_system_timestamp = 1609917755793.395020 component latency= 1.604004
Comp name = nvosd0 in_system_timestamp = 1609917755793.523926 out_system_timestamp = 1609917755804.326904 component latency= 10.802979
Source id = 0 Frame_num = 33 Frame latency = 1559.041992 (ms)
BATCH-NUM = 125**
Batch meta not found for buffer 0x7fcbf80e82a0
BATCH-NUM = 126**
Batch meta not found for buffer 0x7fcbf80c2d50
BATCH-NUM = 127**
Batch meta not found for buffer 0x7fcd10088280
BATCH-NUM = 34**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917754358.166016 out_system_timestamp = 1609917755259.085938 component latency= 900.919922
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 34 in_system_timestamp = 1609917755259.252930 out_system_timestamp = 1609917755334.030029 component_latency = 74.777100
Comp name = primary_gie in_system_timestamp = 1609917755334.113037 out_system_timestamp = 1609917755559.299072 component latency= 225.186035
Comp name = tracking_tracker in_system_timestamp = 1609917755559.318115 out_system_timestamp = 1609917755560.245117 component latency= 0.927002
Comp name = dsanalytics0 in_system_timestamp = 1609917755680.076904 out_system_timestamp = 1609917755680.467041 component latency= 0.390137
Comp name = demuxer in_system_timestamp = 1609917755680.520020 out_system_timestamp = 1609917755680.577881 component latency= 0.057861
Comp name = osd_conv in_system_timestamp = 1609917756094.486084 out_system_timestamp = 1609917756099.237061 component latency= 4.750977
Comp name = nvosd0 in_system_timestamp = 1609917756099.444092 out_system_timestamp = 1609917756112.250000 component latency= 12.805908
Source id = 0 Frame_num = 34 Frame latency = 1754.112061 (ms)
BATCH-NUM = 128**
Batch meta not found for buffer 0x7fcbf813a0b0
BATCH-NUM = 129**
Batch meta not found for buffer 0x7fcb4c07ed00
BATCH-NUM = 130**
BATCH-NUM = 131**
Batch meta not found for buffer 0x7fccf8081290
BATCH-NUM = 132**
Batch meta not found for buffer 0x7fcd3c089be0
BATCH-NUM = 133**
Batch meta not found for buffer 0x7fcd3c0994e0
BATCH-NUM = 134**
BATCH-NUM = 135**
Batch meta not found for buffer 0x7fcc48082390
BATCH-NUM = 136**
Batch meta not found for buffer 0x7fcd1c0bfe10
BATCH-NUM = 137**
Batch meta not found for buffer 0x7fcd3c0a5930**PERF: 5.27 (4.36) 5.47 (4.12) 0.00 (0.00) 5.47 (5.08) 5.67 (5.37) 5.27 (5.22) 0.00 (0.00) 5.47 (3.11) 6.08 (6.23) 5.06 (4.23) 4.82 (4.09) 6.28 (6.23) 4.44 (3.75) 5.88 (5.51) 0.00 (0.00) 5.88 (6.06) 4.86 (4.01) 5.06 (4.48) 5.67 (6.01) 5.02 (4.65) 5.67 (5.51) 3.47 (4.15) 5.07 (5.08) 6.08 (6.23) 5.06 (4.58) 4.24 (4.23) 5.02 (4.81) 5.88 (6.06) 4.86 (4.29) 5.47 (5.19)
BATCH-NUM = 35**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917754633.322998 out_system_timestamp = 1609917755358.801025 component latency= 725.478027
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 35 in_system_timestamp = 1609917755358.912109 out_system_timestamp = 1609917755394.457031 component_latency = 35.544922
Comp name = primary_gie in_system_timestamp = 1609917755401.384033 out_system_timestamp = 1609917755559.643066 component latency= 158.259033
Comp name = tracking_tracker in_system_timestamp = 1609917755559.669922 out_system_timestamp = 1609917755560.299072 component latency= 0.629150
Comp name = dsanalytics0 in_system_timestamp = 1609917755735.114014 out_system_timestamp = 1609917755735.461914 component latency= 0.347900
Comp name = demuxer in_system_timestamp = 1609917755735.493896 out_system_timestamp = 1609917755771.550049 component latency= 36.056152
Comp name = osd_conv in_system_timestamp = 1609917756183.709961 out_system_timestamp = 1609917756197.220947 component latency= 13.510986
Comp name = nvosd0 in_system_timestamp = 1609917756197.339111 out_system_timestamp = 1609917756210.053955 component latency= 12.714844
Source id = 0 Frame_num = 35 Frame latency = 1576.770020 (ms)
BATCH-NUM = 138**
Batch meta not found for buffer 0x7fcbf80cf390
BATCH-NUM = 139**
Batch meta not found for buffer 0x7fcd3c079c90
BATCH-NUM = 140**
Batch meta not found for buffer 0x7fcc3c0b5cc0
BATCH-NUM = 141**
Batch meta not found for buffer 0x7fcdec0f02d0
BATCH-NUM = 142**
BATCH-NUM = 143**
Batch meta not found for buffer 0x7fcdb006e7a0
BATCH-NUM = 144**
Batch meta not found for buffer 0x7fcd3c0ce9c0
BATCH-NUM = 145**
Batch meta not found for buffer 0x7fcd3c084230
BATCH-NUM = 146**
Batch meta not found for buffer 0x7fcd1008b9f0
BATCH-NUM = 147**
BATCH-NUM = 148**
Batch meta not found for buffer 0x7fccf80d01c0
BATCH-NUM = 149**
Batch meta not found for buffer 0x7fcc100fa890
BATCH-NUM = 150**
BATCH-NUM = 151**
Batch meta not found for buffer 0x7fcbc409c240
BATCH-NUM = 152**
Batch meta not found for buffer 0x7fcd3c0cead0
BATCH-NUM = 36**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917754747.211914 out_system_timestamp = 1609917755594.887939 component latency= 847.676025
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 36 in_system_timestamp = 1609917755595.003906 out_system_timestamp = 1609917755731.148926 component_latency = 136.145020
Comp name = primary_gie in_system_timestamp = 1609917755731.227051 out_system_timestamp = 1609917756014.604004 component latency= 283.376953
Comp name = tracking_tracker in_system_timestamp = 1609917756014.632080 out_system_timestamp = 1609917756015.652100 component latency= 1.020020
Comp name = dsanalytics0 in_system_timestamp = 1609917756015.675049 out_system_timestamp = 1609917756016.104004 component latency= 0.428955
Comp name = demuxer in_system_timestamp = 1609917756016.129883 out_system_timestamp = 1609917756016.200928 component latency= 0.071045
Comp name = osd_conv in_system_timestamp = 1609917756306.759033 out_system_timestamp = 1609917756324.241943 component latency= 17.482910
Comp name = nvosd0 in_system_timestamp = 1609917756324.389893 out_system_timestamp = 1609917756345.419922 component latency= 21.030029
Source id = 0 Frame_num = 36 Frame latency = 1598.255127 (ms)
BATCH-NUM = 153**
Batch meta not found for buffer 0x7fccf8075300
BATCH-NUM = 154**
Batch meta not found for buffer 0x7fcc20076010
BATCH-NUM = 155**
Batch meta not found for buffer 0x7fcc7006d3b0
BATCH-NUM = 156**
Batch meta not found for buffer 0x7fccdc084520
BATCH-NUM = 157**
Batch meta not found for buffer 0x7fcd7c078890
BATCH-NUM = 158**
Batch meta not found for buffer 0x7fcd1c066c40
BATCH-NUM = 159**
Batch meta not found for buffer 0x7fcd1c072400
BATCH-NUM = 37**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917755019.511963 out_system_timestamp = 1609917755702.500000 component latency= 682.988037
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 37 in_system_timestamp = 1609917755702.569092 out_system_timestamp = 1609917755795.293945 component_latency = 92.724854
Comp name = primary_gie in_system_timestamp = 1609917755795.427979 out_system_timestamp = 1609917756015.159912 component latency= 219.731934
Comp name = tracking_tracker in_system_timestamp = 1609917756015.183105 out_system_timestamp = 1609917756016.560059 component latency= 1.376953
Comp name = dsanalytics0 in_system_timestamp = 1609917756048.801025 out_system_timestamp = 1609917756049.218994 component latency= 0.417969
Comp name = demuxer in_system_timestamp = 1609917756049.250977 out_system_timestamp = 1609917756049.318115 component latency= 0.067139
Comp name = osd_conv in_system_timestamp = 1609917756586.992920 out_system_timestamp = 1609917756597.852051 component latency= 10.859131
Comp name = nvosd0 in_system_timestamp = 1609917756597.996094 out_system_timestamp = 1609917756604.767090 component latency= 6.770996
Source id = 0 Frame_num = 37 Frame latency = 1585.318115 (ms)
BATCH-NUM = 160**
Batch meta not found for buffer 0x7fcc3c0970c0
BATCH-NUM = 161**
Batch meta not found for buffer 0x7fcd1c0b6ce0
BATCH-NUM = 162**
Batch meta not found for buffer 0x7fcdec0ba3c0
BATCH-NUM = 163**
BATCH-NUM = 164**
BATCH-NUM = 165**
Batch meta not found for buffer 0x7fcb4c0c2e30
BATCH-NUM = 166**
Batch meta not found for buffer 0x7fcc200cdd10
BATCH-NUM = 167**
Batch meta not found for buffer 0x7fcb4c0dc120
BATCH-NUM = 168**
Batch meta not found for buffer 0x7fcd3c090aa0
BATCH-NUM = 169**
Batch meta not found for buffer 0x7fccdc084c90
BATCH-NUM = 170**
Batch meta not found for buffer 0x7fcddc11e1e0
BATCH-NUM = 171**
Batch meta not found for buffer 0x7fcd1c093140
BATCH-NUM = 172**
Batch meta not found for buffer 0x7fcc100617c0
BATCH-NUM = 173**
Batch meta not found for buffer 0x7fcc200aa9a0
BATCH-NUM = 38**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917755259.282959 out_system_timestamp = 1609917755804.675049 component latency= 545.392090
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 38 in_system_timestamp = 1609917755804.797119 out_system_timestamp = 1609917755855.750977 component_latency = 50.953857
Comp name = primary_gie in_system_timestamp = 1609917755855.868896 out_system_timestamp = 1609917756015.991943 component latency= 160.123047
Comp name = tracking_tracker in_system_timestamp = 1609917756016.009033 out_system_timestamp = 1609917756016.762939 component latency= 0.753906
Comp name = dsanalytics0 in_system_timestamp = 1609917756217.899902 out_system_timestamp = 1609917756218.374023 component latency= 0.474121
Comp name = demuxer in_system_timestamp = 1609917756218.426025 out_system_timestamp = 1609917756253.575928 component latency= 35.149902
Comp name = osd_conv in_system_timestamp = 1609917756802.668945 out_system_timestamp = 1609917756806.224121 component latency= 3.555176
Comp name = nvosd0 in_system_timestamp = 1609917756806.382080 out_system_timestamp = 1609917756817.645020 component latency= 11.262939
Source id = 0 Frame_num = 38 Frame latency = 1558.406982 (ms)
BATCH-NUM = 174**
Batch meta not found for buffer 0x7fcb2806f4f0
BATCH-NUM = 175**
Batch meta not found for buffer 0x7fcb280780d0
BATCH-NUM = 176**
Batch meta not found for buffer 0x7fcae800dc30
BATCH-NUM = 177**
Batch meta not found for buffer 0x7fcb7012aab0
BATCH-NUM = 178**
Batch meta not found for buffer 0x7fcc10080030
BATCH-NUM = 179**
Batch meta not found for buffer 0x7fcbf80c25e0
BATCH-NUM = 180**
Batch meta not found for buffer 0x7fcbdc0957b0
BATCH-NUM = 181**
BATCH-NUM = 182**
Batch meta not found for buffer 0x7fcb400ef730
BATCH-NUM = 183**
Batch meta not found for buffer 0x7fcd100bab30
BATCH-NUM = 183**
Batch meta not found for buffer 0x7fcc7006b0a0
BATCH-NUM = 185**
Batch meta not found for buffer 0x7fcbdc085c10
BATCH-NUM = 186**
Batch meta not found for buffer 0x7fcdb007d400
BATCH-NUM = 187**
Batch meta not found for buffer 0x7fcc4806e270
BATCH-NUM = 188**
Batch meta not found for buffer 0x7fcb7c0748f0
BATCH-NUM = 189**
Batch meta not found for buffer 0x7fcd980728e0
BATCH-NUM = 190**
BATCH-NUM = 191**
Batch meta not found for buffer 0x7fcc48084a20
BATCH-NUM = 192**
Batch meta not found for buffer 0x7fcd9826f9c0
BATCH-NUM = 193**
Batch meta not found for buffer 0x7fcb4c073ab0
BATCH-NUM = 194**
Batch meta not found for buffer 0x7fcc200cd270
BATCH-NUM = 195**
Batch meta not found for buffer 0x7fcbdc07eb10
BATCH-NUM = 196**
Batch meta not found for buffer 0x7fcbdc08c5d0
BATCH-NUM = 39**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917755358.943115 out_system_timestamp = 1609917756120.384033 component latency= 761.440918
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 39 in_system_timestamp = 1609917756120.455078 out_system_timestamp = 1609917756278.733887 component_latency = 158.278809
Comp name = primary_gie in_system_timestamp = 1609917756278.809082 out_system_timestamp = 1609917756278.886963 component latency= 0.077881
Comp name = tracking_tracker in_system_timestamp = 1609917756278.933105 out_system_timestamp = 1609917756280.081055 component latency= 1.147949
Comp name = dsanalytics0 in_system_timestamp = 1609917756280.105957 out_system_timestamp = 1609917756280.458984 component latency= 0.353027
Comp name = demuxer in_system_timestamp = 1609917756280.481934 out_system_timestamp = 1609917756280.540039 component latency= 0.058105
Comp name = osd_conv in_system_timestamp = 1609917756939.879883 out_system_timestamp = 1609917756956.801025 component latency= 16.921143
Comp name = nvosd0 in_system_timestamp = 1609917756956.928955 out_system_timestamp = 1609917756991.604004 component latency= 34.675049
Source id = 0 Frame_num = 39 Frame latency = 1632.704834 (ms)
BATCH-NUM = 197**
Batch meta not found for buffer 0x7fcb940ca690
BATCH-NUM = 198**
Batch meta not found for buffer 0x7fcbc408e7c0
BATCH-NUM = 199**
Batch meta not found for buffer 0x7fcb28101270
BATCH-NUM = 200**
Batch meta not found for buffer 0x7fcd4c0f8300
BATCH-NUM = 40**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917755595.103027 out_system_timestamp = 1609917756199.827881 component latency= 604.724854
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 40 in_system_timestamp = 1609917756199.951904 out_system_timestamp = 1609917756339.187988 component_latency = 139.236084
Comp name = primary_gie in_system_timestamp = 1609917756339.329102 out_system_timestamp = 1609917756586.309082 component latency= 246.979980
Comp name = tracking_tracker in_system_timestamp = 1609917756586.345947 out_system_timestamp = 1609917756587.507080 component latency= 1.161133
Comp name = dsanalytics0 in_system_timestamp = 1609917756587.615967 out_system_timestamp = 1609917756588.653076 component latency= 1.037109
Comp name = demuxer in_system_timestamp = 1609917756588.722900 out_system_timestamp = 1609917756588.814941 component latency= 0.092041
Comp name = osd_conv in_system_timestamp = 1609917757079.437988 out_system_timestamp = 1609917757081.007080 component latency= 1.569092
Comp name = nvosd0 in_system_timestamp = 1609917757081.141113 out_system_timestamp = 1609917757093.131104 component latency= 11.989990
Source id = 0 Frame_num = 40 Frame latency = 1498.067871 (ms)
BATCH-NUM = 201**
Batch meta not found for buffer 0x7fcb4c07abd0
BATCH-NUM = 202**
Batch meta not found for buffer 0x7fcbc408d170
BATCH-NUM = 203**
Batch meta not found for buffer 0x7fcb280bc0e0
BATCH-NUM = 41**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917755702.638916 out_system_timestamp = 1609917756343.581055 component latency= 640.942139
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 41 in_system_timestamp = 1609917756343.697998 out_system_timestamp = 1609917756399.607910 component_latency = 55.909912
Comp name = primary_gie in_system_timestamp = 1609917756399.746094 out_system_timestamp = 1609917756587.039062 component latency= 187.292969
Comp name = tracking_tracker in_system_timestamp = 1609917756587.062988 out_system_timestamp = 1609917756588.141113 component latency= 1.078125
Comp name = dsanalytics0 in_system_timestamp = 1609917756590.709961 out_system_timestamp = 1609917756591.102051 component latency= 0.392090
Comp name = demuxer in_system_timestamp = 1609917756591.138916 out_system_timestamp = 1609917756591.478027 component latency= 0.339111
Comp name = osd_conv in_system_timestamp = 1609917757273.423096 out_system_timestamp = 1609917757291.152100 component latency= 17.729004
Comp name = nvosd0 in_system_timestamp = 1609917757291.350098 out_system_timestamp = 1609917757323.905029 component latency= 32.554932
Source id = 0 Frame_num = 41 Frame latency = 1621.312012 (ms)
BATCH-NUM = 204**
Batch meta not found for buffer 0x7fccdc08ea60
BATCH-NUM = 42**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917755804.944092 out_system_timestamp = 1609917756609.947021 component latency= 805.002930
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 42 in_system_timestamp = 1609917756610.079102 out_system_timestamp = 1609917756644.858887 component_latency = 34.779785
Comp name = primary_gie in_system_timestamp = 1609917756644.983887 out_system_timestamp = 1609917756789.157959 component latency= 144.174072
Comp name = tracking_tracker in_system_timestamp = 1609917756789.186035 out_system_timestamp = 1609917756789.881104 component latency= 0.695068
Comp name = dsanalytics0 in_system_timestamp = 1609917756789.993896 out_system_timestamp = 1609917756790.645996 component latency= 0.652100
Comp name = demuxer in_system_timestamp = 1609917756790.686035 out_system_timestamp = 1609917756791.240967 component latency= 0.554932
Comp name = osd_conv in_system_timestamp = 1609917757556.306885 out_system_timestamp = 1609917757565.666016 component latency= 9.359131
Comp name = nvosd0 in_system_timestamp = 1609917757565.822021 out_system_timestamp = 1609917757579.299072 component latency= 13.477051
Source id = 0 Frame_num = 42 Frame latency = 1774.419922 (ms)
BATCH-NUM = 205**
Batch meta not found for buffer 0x7fcd10087d60
BATCH-NUM = 206**
Batch meta not found for buffer 0x7fcb94137600
BATCH-NUM = 43**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917756120.541016 out_system_timestamp = 1609917756807.608887 component latency= 687.067871
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 43 in_system_timestamp = 1609917756807.666992 out_system_timestamp = 1609917756828.982910 component_latency = 21.315918
Comp name = primary_gie in_system_timestamp = 1609917756829.052002 out_system_timestamp = 1609917756938.541992 component latency= 109.489990
Comp name = tracking_tracker in_system_timestamp = 1609917756938.564941 out_system_timestamp = 1609917756939.066895 component latency= 0.501953
Comp name = dsanalytics0 in_system_timestamp = 1609917756939.090088 out_system_timestamp = 1609917756939.364990 component latency= 0.274902
Comp name = demuxer in_system_timestamp = 1609917756939.402100 out_system_timestamp = 1609917756939.764893 component latency= 0.362793
Comp name = osd_conv in_system_timestamp = 1609917757659.420898 out_system_timestamp = 1609917757659.799072 component latency= 0.378174
Comp name = nvosd0 in_system_timestamp = 1609917757659.914062 out_system_timestamp = 1609917757668.841064 component latency= 8.927002
Source id = 0 Frame_num = 43 Frame latency = 1548.343018 (ms)
BATCH-NUM = 207**
Batch meta not found for buffer 0x7fcae801cc80
BATCH-NUM = 44**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917756199.949951 out_system_timestamp = 1609917757003.363037 component latency= 803.413086
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 44 in_system_timestamp = 1609917757003.534912 out_system_timestamp = 1609917757057.465088 component_latency = 53.930176
Comp name = primary_gie in_system_timestamp = 1609917757057.593994 out_system_timestamp = 1609917757232.635986 component latency= 175.041992
Comp name = tracking_tracker in_system_timestamp = 1609917757232.650879 out_system_timestamp = 1609917757233.498047 component latency= 0.847168
Comp name = dsanalytics0 in_system_timestamp = 1609917757233.604980 out_system_timestamp = 1609917757234.419922 component latency= 0.814941
Comp name = demuxer in_system_timestamp = 1609917757234.489014 out_system_timestamp = 1609917757234.711914 component latency= 0.222900
Comp name = osd_conv in_system_timestamp = 1609917757789.731934 out_system_timestamp = 1609917757819.201904 component latency= 29.469971
Comp name = nvosd0 in_system_timestamp = 1609917757819.364014 out_system_timestamp = 1609917757875.028076 component latency= 55.664062
Source id = 0 Frame_num = 44 Frame latency = 1675.110107 (ms)
BATCH-NUM = 208**
Batch meta not found for buffer 0x7fcd98078c80
BATCH-NUM = 209**
BATCH-NUM = 45**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917756343.750977 out_system_timestamp = 1609917757093.410889 component latency= 749.659912
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 45 in_system_timestamp = 1609917757093.466064 out_system_timestamp = 1609917757117.783936 component_latency = 24.317871
Comp name = primary_gie in_system_timestamp = 1609917757117.899902 out_system_timestamp = 1609917757232.933105 component latency= 115.033203
Comp name = tracking_tracker in_system_timestamp = 1609917757232.940918 out_system_timestamp = 1609917757233.556885 component latency= 0.615967
Comp name = dsanalytics0 in_system_timestamp = 1609917757235.833008 out_system_timestamp = 1609917757236.097900 component latency= 0.264893
Comp name = demuxer in_system_timestamp = 1609917757236.125977 out_system_timestamp = 1609917757236.739014 component latency= 0.613037
Comp name = osd_conv in_system_timestamp = 1609917758006.749023 out_system_timestamp = 1609917758031.490967 component latency= 24.741943
Comp name = nvosd0 in_system_timestamp = 1609917758031.614014 out_system_timestamp = 1609917758099.768066 component latency= 68.154053
Source id = 0 Frame_num = 45 Frame latency = 1756.059082 (ms)
BATCH-NUM = 210**
Batch meta not found for buffer 0x7fcc2007ce70
BATCH-NUM = 46**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917756610.214111 out_system_timestamp = 1609917757296.863037 component latency= 686.648926
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 46 in_system_timestamp = 1609917757297.018066 out_system_timestamp = 1609917757357.208984 component_latency = 60.190918
Comp name = primary_gie in_system_timestamp = 1609917757359.102051 out_system_timestamp = 1609917757495.125977 component latency= 136.023926
Comp name = tracking_tracker in_system_timestamp = 1609917757495.220947 out_system_timestamp = 1609917757495.881104 component latency= 0.660156
Comp name = dsanalytics0 in_system_timestamp = 1609917757497.562988 out_system_timestamp = 1609917757497.873047 component latency= 0.310059
Comp name = demuxer in_system_timestamp = 1609917757497.905029 out_system_timestamp = 1609917757497.958008 component latency= 0.052979
Comp name = osd_conv in_system_timestamp = 1609917758181.531982 out_system_timestamp = 1609917758191.289062 component latency= 9.757080
Comp name = nvosd0 in_system_timestamp = 1609917758191.413086 out_system_timestamp = 1609917758199.367920 component latency= 7.954834
Source id = 0 Frame_num = 46 Frame latency = 1589.194824 (ms)
BATCH-NUM = 211**
BATCH-NUM = 47**
Comp name = nvv4l2decoder19 in_system_timestamp = 1609917756807.740967 out_system_timestamp = 1609917757567.740967 component latency= 760.000000
Comp name = src_bin_muxer source_id = 0 pad_index = 0 frame_num = 47 in_system_timestamp = 1609917757567.812988 out_system_timestamp = 1609917757628.044922 component_latency = 60.231934
Comp name = primary_gie in_system_timestamp = 1609917757628.159912 out_system_timestamp = 1609917757628.259033 component latency= 0.099121
Comp name = tracking_tracker in_system_timestamp = 1609917757628.287109 out_system_timestamp = 1609917757629.102051 component latency= 0.814941
Comp name = dsanalytics0 in_system_timestamp = 1609917757641.406982 out_system_timestamp = 1609917757641.836914 component latency= 0.429932
Comp name = demuxer in_system_timestamp = 1609917757641.874023 out_system_timestamp = 1609917757641.941895 component latency= 0.067871
Comp name = osd_conv in_system_timestamp = 1609917758435.478027 out_system_timestamp = 1609917758450.093018 component latency= 14.614990
Comp name = nvosd0 in_system_timestamp = 1609917758450.259033 out_system_timestamp = 1609917758560.843018 component latency= 110.583984
Source id = 0 Frame_num = 47 Frame latency = 1753.151123 (ms)
^C^C^C
