Deepstream runs at a very low frame rate (FPS) at the beginning
At first, the fps value was very low and then became stable. What did you do at the beginning to cause the fps value to be very low?
What are your sources? Local video file, network streams such as http, rtsp, hls,… or videos from devices (such as CSI camara, USB camera,…)?
What kind of pipeline are you using? What is the configurations?
The sample program I used has not changed anything.
Deepstream_Path=/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/
deepstream-app -c $Deepstream_Path/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
• DeepStream Version
• TensorRT Version
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
Please read the code of /opt/nvidia/deepstream/deepstream/sources/apps/common/src/deepstream_perf.c, “perf_measurement_callback” is triggered in a timer g_timeout_add(The Main Event Loop: GLib Reference Manual) when start the pipeline, so the initialization time of the pipeline is also calculated in the first frame. It will take a long time for initialization. If the timeout of the timer is too short, it is possible that the first time FPS calculation output 0 value.
