**• Hardware Platform (Jetson / GPU)jetson agx orin
**• DeepStream Version 6.4 • JetPack Version (valid for Jetson only) 6.0 DP • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only)
**• Issue Type( questions, new requirements, bugs) questions
When using deepstream-server, use within_multiurisrcbin: 1 disable-passthrough: 1
drop-pipeline-eos: 1. If you comment out the tiler node and see that EOS is being passed to the videoconvert node at the end of the stream, which crashes, how do you fix this
from the screenshot, it crashed in nvvideoconvert plugin. In my last comment, I can’t reproduce this crash issue. are my reproducing steps different with yours? could you share the whole log? Thanks!
I don’t have a video output device, so I use pref-mode =1 and add tree->msgconv->msgbroker after osd nodes, I think later nodes should not affect previous nodes
please refer to my last comment. since I can’t reproduce this crash issue, if you can reproduce, could you provide a simplified code? including the source and configuration files. Thanks! You can use forum private email. please click forum avatar-> personal messages->new message.
I understand what you said, this is indeed the case in my test. At present, since I have no requirement for tiler, I would like to ask you how to avoid a crash if I comment out the tiler node
Thanks for the sharing! the issue is in closesource code. we will fix it in the later versions. in this Deepstream-server, please don’t remove tiler before nvvideoconvert.
Thank you very much for your answer. I would like to ask another question, can tiler node be set to pass-through mode? I haven’t seen relevant description in the document
