Nvmultiurisrcbin does not exit cleanly after EOS
Jetson Orin
• DeepStream Version
Deepstream 6.3
Jetpack 5.1
After converting to nvmultiurisrcbin our pipeline occasionally doesn’t exit after hitting EOS from multiple streams. As you can see it hit’s EOS and then just get’s stuck waiting for more sources
nvstreammux: Successfully handled EOS for source_id=1
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=2
Warning: gst-resource-error-quark: No Sources found at the input of muxer. Waiting for sources. (3): gstnvstreammux.cpp(2777): gst_nvstreammux_src_push_loop (): /GstPipeline:pipeline0/GstDsNvMultiUriBin:nvmultiurisrcbin/GstBin:nvmultiurisrcbin_creator/GstNvStreamMux:src_bin_muxer
We are running from mp4 in this case and drop-pipeline-eos is false. This issue happens randomly and is not consistently reproduceable.
Thanks for the sharing. which DeepStream sample are you testing? can you provide the simplest code diff? or can you provide a gst-launch command to reproduce this issue?
