GPU (A5000)
• DeepStream Version
Deepstream 6.2
• TensorRT Version
TensorRT 8.5.2
Version 525.85
Question / Bug
When running multiple video files as input, the nvof plugin crashes as soon as any input video reaches EOS. The same behavior is observed when the input sources are set to loop indefinitely.
We have encountered an issue with the nvof
plugin when we attempted to run multiple videos of differing lengths with nvof
enabled. The plugin crashes as soon as any input video reaches EOS. The error message that appears is as follows :
** INFO: <bus_callback:226>: Pipeline running
gst_ds_optical_flow_set_caps: Creating OpticalFlow Context for Source = 0
libnvds_opticalflow_dgpu: Setting GPU_ID = 0
gst_ds_optical_flow_set_caps: Creating OpticalFlow Context for Source = 1
gst_ds_optical_flow_set_caps: Creating OpticalFlow Context for Source = 2
gst_ds_optical_flow_set_caps: Creating OpticalFlow Context for Source = 3
Processing frame number = 0 batch_id = 0 src_id = 1
Processing frame number = 250 batch_id = 0 src_id = 1
**PERF: 4.90 (5.03) 4.90 (5.03) 4.90 (5.05) 4.90 (5.05)
**PERF: 5.80 (5.03) 5.80 (5.03) 5.80 (5.05) 5.80 (5.05)
**PERF: 4.59 (5.03) 4.59 (5.03) 4.59 (5.05) 4.59 (5.05)
**PERF: 6.08 (5.05) 6.08 (5.05) 6.08 (5.07) 6.08 (5.07)
**PERF: 5.00 (5.05) 5.00 (5.05) 5.00 (5.07) 5.00 (5.07)
**PERF: 4.87 (5.05) 4.87 (5.05) 4.87 (5.07) 4.87 (5.07)
**PERF: 4.43 (5.05) 4.43 (5.05) 4.43 (5.06) 4.43 (5.06)
**PERF: 6.25 (5.05) 6.25 (5.05) 6.25 (5.06) 6.25 (5.06)
**PERF: 4.66 (5.04) 4.66 (5.04) 4.66 (5.06) 4.66 (5.06)
nvstreammux: Successfully handled EOS for source_id=3
Processing frame number = 300 batch_id = 0 src_id = 2
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: 5.29 (5.06) 5.29 (5.06) 5.29 (5.08) 5.29 (5.08)
Processing frame number = 300 batch_id = 0 src_id = 1
Error: A batch of multiple frames received from the same source.
Set sync-inputs property of streammux to TRUE.
0:02:10.064676997 34233 0x55c9aa914120 ERROR nvdsmetamux gstnvdsmetamux.cpp:952:gst_nvdsmetamux_aggregate:<infer_bin_muxer> push error
ERROR from opticalflow_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:deepstream-skt-pipeline/GstBin:parallel_infer_bin/GstBin:opticalflow_bin/GstQueue:opticalflow_queue:
streaming stopped, reason error (-5)
Quitting
Source 3 is the shortest input video that contains ~300 frames in total, and as soon as it reaches EOS, nvof
crashes with the message ERROR from opticalflow_queue: Internal data stream error.
, followed by the whole pipeline stopping due to this.
The question we have is whether there is a way to gracefully handle these cases, so that the system continues to function until all the videos reach EOS or if input videos are set to repeat indefinitely over a loop.
A follow-up question we have is whether this issue could appear when we use input streams over network. For example, if there is a certain delay in stream due to network turbulence, should we expect nvof
to behave like this?
Thank you
