GPU (NVIDIA GeForce RTX 3060 Laptop GPU)
• DeepStream Version
6.4
• TensorRT Version
535.104.05
Bug
Run a pipeline with drop-pipeline-eos=true for nvstreammux:
docker run --name test \
--gpus all \
--entrypoint gst-launch-1.0 \
nvcr.io/nvidia/deepstream:6.4-samples-multiarch \
nvstreammux name=muxer width=1280 height=720 batch-size=4 drop-pipeline-eos=true ! \
fakesink sync=false enable-last-sample=false qos=false \
videotestsrc num-buffers=300 ! \
'video/x-raw,width=1280,height=720,framerate=30/1' ! \
identity sync=true ! \
nvvideoconvert ! \
'video/x-raw(memory:NVMM),format=RGBA,width=1280,height=720' ! \
muxer.sink_0
This pipeline sends 300 frames at a framerate 30/1.
After processing all frames nvstreamux logs message:
nvstreammux: Successfully handled EOS for source_id=0
and then starts consuming 100% CPU:
$ docker stats
CONTAINER ID NAME CPU % MEM USAGE / LIMIT MEM % NET I/O BLOCK I/O PIDS
67750b1786aa test 100.76% 122.3MiB / 15.04GiB 0.79% 7.69kB / 0B 0B / 659kB 8
If you set environment GST_DEBUG=9 you can see that nvstreammux constantly aquires and releases a buffer from pool:
0:00:04.030811619 1 0x561eff7d4580 DEBUG GST_BUFFER gstbuffer.c:1470:gst_buffer_is_memory_range_writable: idx 0, length -1
0:00:04.030814133 1 0x561eff7d4580 TRACE GST_REFCOUNTING gstobject.c:264:gst_object_unref:<nvstreammuxbufferpool0> 0x561f000d7630 unref 2->1
0:00:04.030816939 1 0x561eff7d4580 LOG bufferpool gstbufferpool.c:1134:default_acquire_buffer:<nvstreammuxbufferpool0> acquired buffer 0x561f000d77e0
0:00:04.030819353 1 0x561eff7d4580 TRACE GST_REFCOUNTING gstobject.c:237:gst_object_ref:<nvstreammuxbufferpool0> 0x561f000d7630 ref 1->2
0:00:04.030827609 1 0x561eff7d4580 DEBUG GST_BUFFER gstbuffer.c:2316:gst_buffer_add_meta: alloc metadata 0x7f56f402e310 (NvDsMeta) of size 72
0:00:04.030830845 1 0x561eff7d4580 LOG GST_BUFFER gstbuffer.c:1837:gst_buffer_map_range: buffer 0x561f000d77e0, idx 0, length -1, flags 0001
0:00:04.030833119 1 0x561eff7d4580 LOG GST_BUFFER gstbuffer.c:305:_get_merged_memory: buffer 0x561f000d77e0, idx 0, length 1
0:00:04.030835644 1 0x561eff7d4580 TRACE GST_REFCOUNTING gstminiobject.c:478:gst_mini_object_ref: 0x561eff7e6610 ref 1->2
0:00:04.030837958 1 0x561eff7d4580 TRACE GST_LOCKING gstminiobject.c:233:gst_mini_object_lock: lock 0x561eff7e6610: state 00010000, access_mode 1
0:00:04.030841344 1 0x561eff7d4580 TRACE GST_LOCKING gstminiobject.c:293:gst_mini_object_unlock: unlock 0x561eff7e6610: state 00010101, access_mode 1
0:00:04.030845973 1 0x561eff7d4580 TRACE GST_REFCOUNTING gstminiobject.c:660:gst_mini_object_unref: 0x561eff7e6610 unref 2->1
0:00:04.030848187 1 0x561eff7d4580 TRACE GST_REFCOUNTING gstminiobject.c:660:gst_mini_object_unref: 0x561f000d77e0 unref 1->0
0:00:04.030850672 1 0x561eff7d4580 TRACE GST_REFCOUNTING gstminiobject.c:478:gst_mini_object_ref: 0x561f000d77e0 ref 0->1
0:00:04.030852766 1 0x561eff7d4580 LOG GST_BUFFER gstbuffer.c:765:_gst_buffer_dispose: release 0x561f000d77e0 to pool 0x561f000d7630
0:00:04.030855761 1 0x561eff7d4580 LOG GST_BUFFER gstbuffer.c:1694:gst_buffer_resize_range: trim 0x561f000d77e0 0-64 size:64 offs:0 max:64
0:00:04.030857925 1 0x561eff7d4580 DEBUG GST_BUFFER gstbuffer.c:2514:gst_buffer_foreach_meta: remove metadata 0x7f56f402e310 (NvDsMeta)
0:00:04.030863385 1 0x561eff7d4580 LOG bufferpool gstbufferpool.c:1307:default_release_buffer:<nvstreammuxbufferpool0> released buffer 0x561f000d77e0 0
0:00:04.030865940 1 0x561eff7d4580 DEBUG GST_BUFFER gstbuffer.c:1470:gst_buffer_is_memory_range_writable: idx 0, length -1
