DeepStream smart record memory leak (DS 8.0, RTX 5070 16GB)
Summary
When enabling smart recording (smart_record: 2) with nvmultiurisrcbin, RSS grows steadily over hours. Disabling smart record keeps RAM stable. Leak persists even after app-level guards (SmartRecordHandlerV2) that prevent overlaps and clean state. Suspect nvurisrcbin/smart-record internal buffers not freed reliably.
Environment
- DeepStream: 8.0
- GPU: RTX 5070 16GB
- Driver: 580.82.07
- CUDA: (fill)
- OS: (fill, e.g., Ubuntu 24.04)
- GStreamer: from DeepStream 8.x
- App: Custom C++/CMake pipeline (not using deepstream-app); we build our own elements/blocks and integrate SmartRecordHandler in code (see source below).
Pipeline/config (minimal repro)
sources:
- id: multi_rtsp_source
type: rtsp
mode: multi
uris:
- rtsp://<cam1>
- rtsp://<cam2>
backend_options:
deepstream:
smart_record: 2 # 0=off, 1=cloud-only, 2=cloud+local
smart_rec_cache: 5 # seconds
smart_rec_mode: 0 # audio+video
smart_rec_dir_path: "/opt/lantana/rec"
smart_rec_file_prefix: "lsr"
smart_rec_default_duration: 20
disable_audio: false
max_batch_size: 4
width: 1920
height: 1080
live_source: true
drop_pipeline_eos: true
batched_push_timeout: 40000
latency: 400
rtsp_reconnect_interval: 10
rtsp_reconnect_attempts: -1
max_latency: 3000000000
sync_inputs: false
event_handlers:
- id: detect_handler_1
type: on_detect
enable: true
source_from: multi_rtsp_source
signal_from: output_appsink # appsink emits new-sample
signal_name: new-sample
label_filter: [bike, bus, car, person, truck]
record: true # triggers smart record
mbroker_host: 192.168.1.99
mbroker_port: 6979
mbroker_channel: worker_lsr
outputs:
- id: output_appsink
type: appsink
input_from: raw
destination:
appsink:
emit_signals: true
max_buffers: 5
drop_buffers: true
Repro steps
- Run pipeline with 4 RTSP sources (1080p).
- Enable smart record as above (pre=5s cache, post=20s).
- Let it run for several hours with regular detections (start-sr/stop-sr via handler).
- Observe in docker stats: over ~1 hour it climbs roughly +500 MB.
- Disable
smart_record(set to 0) and rerun: RAM stays stable.
What happens
- With
smart_record: 2: RSS keeps increasing; eventually OOM/kill. - With
smart_record: 0: RSS stable. - No overlapping sessions at app layer; handler enforces safety gap and timeouts.
Expected
Smart record should release internal buffers after sr-done; RSS should stay bounded.
App-side safeguards already in place (SmartRecordHandlerV2)
- Prevent overlap: state machine IDLE/RECORDING/STOPPING + 2s safety gap.
- Force stop on expiry; STOPPING timeout 15s.
- Evict idle sources after 2 minutes; disconnect sr-done; drop cached nvurisrcbin refs if bin is recreated.
- Periodic cleanup every 500 frames; memory stats every 1000 frames.
- Redis publish uses stack strings; no long-lived GstSample refs.
Observations
- Leak only when smart record is enabled → points to nvurisrcbin smart-record internals.
- Appsink and handler maps remain bounded (logged); state maps do not grow.
- Overlap prevented; still leaks.
- Lowering cache/post reduces growth rate but leak persists.
Requests
- Is there a known memory leak with smart record in DS 8.x / nvurisrcbin?
- Any patches/workarounds (force flush, smart_rec_mode=video, disable audio, specific cache/duration constraints)?
- Guidance on safe start/stop patterns to avoid internal buffer retention.
Source code
#pragma once
* @file smart_record_handler_v2.hpp
* @brief Optimized Smart Record Handler with improved memory safety
* Key improvements over v1:
* - RAII pattern for all resources (no manual new/delete)
* - GstElement weak references to avoid dangling pointers
* - Thread-safe signal connection/disconnection
* - Simplified state machine
* - Proper cleanup on destruction
#include "lantana/core/eventing/ievent_handler.hpp"
#include "lantana/core/utils/logger.hpp"
#include <gst/gst.h>
#include <gst/gstclock.h>
#include <gst/gstelement.h>
#include <gst-nvdssr.h>
#include <any>
#include <atomic>
#include <chrono>
#include <memory>
#include <mutex>
#include <optional>
#include <shared_mutex>
#include <string>
#include <unordered_map>
#include <unordered_set>
#include <vector>
// Forward declaration
namespace lantana::infrastructure::messaging {
class RedisStreamProducer;
namespace lantana::backends::deepstream::events {
* @brief RAII wrapper for GstElement with automatic ref/unref
class GstElementRef {
public:
GstElementRef() = default;
explicit GstElementRef(GstElement* elem, bool add_ref = true) : element_(elem) {
if (element_ && add_ref) {
gst_object_ref(element_);
~GstElementRef() {
reset();
// Move only
GstElementRef(GstElementRef&& other) noexcept : element_(other.element_) {
other.element_ = nullptr;
GstElementRef& operator=(GstElementRef&& other) noexcept {
if (this != &other) {
reset();
element_ = other.element_;
return *this;
// No copy
GstElementRef(const GstElementRef&) = delete;
GstElementRef& operator=(const GstElementRef&) = delete;
void reset() {
if (element_) {
gst_object_unref(element_);
element_ = nullptr;
GstElement* get() const {
return element_;
GstElement* operator->() const {
return element_;
explicit operator bool() const {
return element_ != nullptr && GST_IS_ELEMENT(element_);
private:
GstElement* element_ = nullptr;
* @brief Recording session info - immutable after creation
struct RecordingSessionV2 {
uint32_t session_id;
uint32_t source_id;
std::string source_name;
std::string pipeline_id;
GstClockTime start_time;
uint32_t duration_sec;
std::chrono::system_clock::time_point wall_clock_start;
bool is_expired(GstClockTime current_time) const {
if (!GST_CLOCK_TIME_IS_VALID(start_time) || !GST_CLOCK_TIME_IS_VALID(current_time)) {
return true;
return current_time >= (start_time + static_cast<GstClockTime>(duration_sec) * GST_SECOND);
* @brief Configuration for SmartRecordHandlerV2
struct SmartRecordConfigV2 {
std::string source_from;
std::string pipeline_id = "default";
uint32_t pre_event_sec = 2; // Seconds before detection (from cache)
uint32_t post_event_sec = 15; // Seconds after detection
// RECORDING SAFETY & OVERLAP BEHAVIOR:
// Safety Mechanism:
// - Handler enforces 2s minimum safety gap after recording completes
// - This prevents memory corruption from overlapping nvurisrcbin operations
// - Even with min_interval_sec=0, actual gap = max(min_interval_sec, 2s)
// Timeline Overlap (when min_interval_sec=0):
// Event A (t=0): [-5s cache] [0s trigger] → [+10s post] = 15s video
// Event B (t=5): Must wait until t=17s (15s duration + 2s safety gap)
// [-5s cache] [17s trigger] → [+27s post] = 15s video
// Gap Behavior:
// min_interval_sec=0 → Actual gap: 2s (safety enforced)
// min_interval_sec=5 → Actual gap: 5s (user config)
// min_interval_sec=20 → Actual gap: 20s (user config)
// Trade-offs:
// ✅ Memory safe: Prevents corruption from concurrent recordings
// ✅ Reliable: No invalid free or double-free errors
// ⚠️ Minimum 2s gap: Cannot record continuously without gap
// ⚠️ May miss events: If object appears during safety gap
uint32_t min_interval_sec = 3;
// Maximum number of concurrent Smart Record sessions across all sources.
// 0 = unlimited (default, preserves current behavior).
// Setting to 1 can be used as a mitigation/workaround for platform instability
// when multiple sources record concurrently.
uint32_t max_concurrent_recordings = 0;
std::unordered_set<std::string> target_labels;
// Redis config
std::string redis_host = "localhost";
uint16_t redis_port = 6379;
std::string redis_channel = "smart_record_events";
// Source name mapping
std::unordered_map<uint32_t, std::string> source_id_to_name;
* @brief Optimized Smart Record Handler V2
* Thread-safe, memory-safe implementation using RAII patterns.
class SmartRecordHandlerV2 : public core::events::IEventHandler {
public:
SmartRecordHandlerV2();
~SmartRecordHandlerV2() override;
// Non-copyable, non-movable (due to signal connections)
SmartRecordHandlerV2(const SmartRecordHandlerV2&) = delete;
SmartRecordHandlerV2& operator=(const SmartRecordHandlerV2&) = delete;
SmartRecordHandlerV2(SmartRecordHandlerV2&&) = delete;
SmartRecordHandlerV2& operator=(SmartRecordHandlerV2&&) = delete;
// IEventHandler interface
bool init_context(const std::string& config) override;
bool init_context(const std::string& config, const std::any& extra_context) override;
void destroy_context() override;
void register_callback() override;
std::string get_handler_name() const override;
std::vector<std::string> get_supported_event_types() const override;
void process_event(GstSample* sample, const std::string& event_type, std::any* batch_meta,
std::any* frame_meta, std::any* object_meta,
std::any* analytics_meta) override;
private:
// --- Internal types ---
enum class RecordingState {
IDLE, // No recording, can start new
RECORDING, // Recording in progress, cannot start new
STOPPING // Recording ending, wait for cleanup
struct SourceState {
GstClockTime last_record_start = GST_CLOCK_TIME_NONE;
GstClockTime last_record_end = GST_CLOCK_TIME_NONE; // When recording actually finished
std::optional<RecordingSessionV2> active_session;
RecordingState recording_state = RecordingState::IDLE;
// When we have requested a stop (stop-sr emitted) but have not yet received sr-done.
// Used to prevent starting a new recording in this transient state.
std::optional<uint32_t> stopping_session_id;
GstClockTime stop_request_time = GST_CLOCK_TIME_NONE;
gulong signal_handler_id = 0;
// --- Helper methods ---
void parse_config(const std::string& config_str);
GstElementRef get_nvurisrcbin(uint32_t source_id);
bool can_start_recording(uint32_t source_id, GstClockTime current_time);
void start_recording(uint32_t source_id, uint64_t trigger_object_id, GstClockTime current_time);
void cleanup_expired_sessions(GstClockTime current_time);
void disconnect_all_signals();
std::string get_source_name(uint32_t source_id) const;
// Signal callback (static to match GObject signature)
static void on_recording_done(GstElement* element, NvDsSRRecordingInfo* info,
gpointer recording_user_data, gpointer user_data);
// --- Members ---
std::atomic<bool> initialized_{false};
std::atomic<bool> shutting_down_{false};
// Configuration (immutable after init)
SmartRecordConfigV2 config_;
// GStreamer elements (protected by mutex)
mutable std::shared_mutex elements_mutex_;
GstElementRef multiuribin_;
std::unordered_map<uint32_t, GstElementRef> source_elements_;
// State (protected by mutex)
mutable std::mutex state_mutex_;
std::unordered_map<uint32_t, SourceState> source_states_;
// Redis producer (thread-safe, owned)
std::unique_ptr<infrastructure::messaging::RedisStreamProducer> redis_producer_;
// Lightweight counters for debugging long-running RSS growth.
// These are intentionally atomics so we can increment from callbacks safely.
std::atomic<uint64_t> sr_started_{0};
std::atomic<uint64_t> sr_done_{0};
std::atomic<uint64_t> sr_stop_emitted_{0};
std::atomic<uint64_t> sr_stopping_timeouts_{0};
} // namespace lantana::backends::deepstream::events
* @file smart_record_handler_v2.cpp
* @brief Optimized Smart Record Handler implementation
* Memory-safe implementation with proper RAII, no manual new/delete,
* and proper GStreamer object lifecycle management.
#include "lantana/backends/deepstream/event_handlers/smart_record_handler_v2.hpp"
#include "lantana/infrastructure/messaging/redis_stream_producer.hpp"
#include <nvdsmeta.h>
#include <gstnvdsmeta.h>
#include <algorithm>
#include <chrono>
#include <cstring>
#include <sstream>
namespace {
// Minimum safety gap (seconds) after recording ends before allowing new recording
// This prevents memory corruption from overlapping nvurisrcbin operations
constexpr uint32_t RECORDING_SAFETY_GAP_SEC = 2;
// Key used to attach source_id to nvurisrcbin for reliable callback mapping
constexpr const char* kSourceIdDataKey = "lantana_source_id";
bool is_descendant_of(GstObject* obj, GstObject* ancestor) {
if (!obj || !ancestor) {
return false;
GstObject* current = GST_OBJECT(gst_object_ref(obj));
while (current) {
GstObject* parent = gst_object_get_parent(current);
gst_object_unref(current);
if (!parent) {
return false;
if (parent == ancestor) {
gst_object_unref(parent);
return true;
current = parent;
return false;
* @brief Get current Unix timestamp in milliseconds as string
std::string get_unix_millis() {
auto now = std::chrono::system_clock::now();
auto millis =
std::chrono::duration_cast<std::chrono::milliseconds>(now.time_since_epoch()).count();
return std::to_string(millis);
* @brief Get GStreamer system clock time safely
GstClockTime get_gst_system_time() {
GstClock* clock = gst_system_clock_obtain();
if (!clock) {
return GST_CLOCK_TIME_NONE;
GstClockTime time = gst_clock_get_time(clock);
gst_object_unref(clock);
return time;
* @brief Find nvurisrcbin element by source ID within a bin
GstElement* find_nvurisrcbin_in_bin(GstElement* bin, uint32_t source_id,
const std::string& source_from) {
if (!bin || !GST_IS_BIN(bin)) {
return nullptr;
// Try to find the creator bin
const gchar* parent_name = GST_ELEMENT_NAME(bin);
gchar* creator_name = g_strdup_printf("%s_creator", parent_name);
GstElement* creator_bin = gst_bin_get_by_name(GST_BIN(bin), creator_name);
g_free(creator_name);
// Fallback to hardcoded name
if (!creator_bin && !source_from.empty()) {
std::string fallback_name = source_from + "_creator";
creator_bin = gst_bin_get_by_name(GST_BIN(bin), fallback_name.c_str());
if (!creator_bin || !GST_IS_BIN(creator_bin)) {
if (creator_bin) {
gst_object_unref(creator_bin);
return nullptr;
// Find the specific nvurisrcbin
gchar* target_name = g_strdup_printf("dsnvurisrcbin%u", source_id);
GstElement* urisrcbin = gst_bin_get_by_name(GST_BIN(creator_bin), target_name);
g_free(target_name);
// Validate it's actually a nvurisrcbin
if (urisrcbin) {
GstElementFactory* factory = gst_element_get_factory(urisrcbin);
if (factory) {
const gchar* factory_name = gst_plugin_feature_get_name(GST_PLUGIN_FEATURE(factory));
if (!g_str_has_prefix(factory_name, "nvurisrcbin")) {
LOGW("Element found for source {} is not nvurisrcbin (type: {})", source_id,
factory_name);
gst_object_unref(urisrcbin);
return nullptr;
return urisrcbin; // Caller owns the reference
} // namespace
// SmartRecordHandlerV2 Implementation
SmartRecordHandlerV2::SmartRecordHandlerV2() {
LOGD("SmartRecordHandlerV2: Constructor");
SmartRecordHandlerV2::~SmartRecordHandlerV2() {
LOGD("SmartRecordHandlerV2: Destructor");
destroy_context();
bool SmartRecordHandlerV2::init_context(const std::string& config) {
LOGW("SmartRecordHandlerV2: init_context called without multiuribin - handler disabled");
parse_config(config);
return false; // Cannot function without multiuribin
bool SmartRecordHandlerV2::init_context(const std::string& config, const std::any& extra_context) {
if (initialized_.load()) {
LOGW("SmartRecordHandlerV2: Already initialized");
return true;
// Extract multiuribin from context
GstElement* multiuribin_raw = nullptr;
try {
multiuribin_raw = std::any_cast<GstElement*>(extra_context);
} catch (const std::bad_any_cast& e) {
LOGE("SmartRecordHandlerV2: Failed to cast extra_context: {}", e.what());
return false;
if (!multiuribin_raw || !GST_IS_BIN(multiuribin_raw)) {
LOGE("SmartRecordHandlerV2: Invalid multiuribin element");
return false;
// Parse configuration
// Store multiuribin reference
std::unique_lock lock(elements_mutex_);
multiuribin_ = GstElementRef(multiuribin_raw, true);
// Get source_from from element if not set
if (config_.source_from.empty()) {
config_.source_from = GST_ELEMENT_NAME(multiuribin_raw);
// Initialize Redis producer
try {
redis_producer_ = std::make_unique<infrastructure::messaging::RedisStreamProducer>(
config_.redis_host, config_.redis_port, config_.redis_channel);
LOGI("SmartRecordHandlerV2: Redis producer initialized for {}:{}/{}", config_.redis_host,
} catch (const std::exception& e) {
LOGE("SmartRecordHandlerV2: Failed to init Redis producer: {}", e.what());
// Continue without Redis - not a fatal error
initialized_.store(true);
LOGI("SmartRecordHandlerV2: Initialized successfully with multiuribin '{}'",
config_.source_from);
return true;
void SmartRecordHandlerV2::destroy_context() {
if (!initialized_.exchange(false)) {
return; // Already destroyed or never initialized
LOGI("SmartRecordHandlerV2: Destroying context...");
shutting_down_.store(true);
// Disconnect all signal handlers first (must be done before releasing elements)
// Clear state
std::lock_guard lock(state_mutex_);
source_states_.clear();
// Release GStreamer elements
source_elements_.clear();
multiuribin_.reset();
// Release Redis producer
redis_producer_.reset();
shutting_down_.store(false);
LOGI("SmartRecordHandlerV2: Context destroyed");
void SmartRecordHandlerV2::register_callback() {
// No-op: Signal connections are made lazily when starting recordings
std::string SmartRecordHandlerV2::get_handler_name() const {
return "SmartRecordHandlerV2";
std::vector<std::string> SmartRecordHandlerV2::get_supported_event_types() const {
return {"on_detect"};
void SmartRecordHandlerV2::process_event(GstSample* sample, const std::string& event_type,
std::any* batch_meta_any, std::any* frame_meta_any,
std::any* object_meta_any, std::any* analytics_meta_any) {
// Early exit checks
if (!initialized_.load() || shutting_down_.load()) {
return;
if (event_type != "on_detect") {
return;
// Check multiuribin is valid
std::shared_lock lock(elements_mutex_);
if (!multiuribin_) {
return;
// Extract batch metadata
NvDsBatchMeta* batch_meta = nullptr;
try {
if (batch_meta_any && batch_meta_any->has_value()) {
batch_meta = std::any_cast<NvDsBatchMeta*>(*batch_meta_any);
} catch (const std::bad_any_cast&) {
LOGE("SmartRecordHandlerV2: Failed to cast batch_meta");
return;
if (!batch_meta) {
return;
GstClockTime current_time = get_gst_system_time();
if (!GST_CLOCK_TIME_IS_VALID(current_time)) {
LOGW("SmartRecordHandlerV2: Invalid system time");
return;
// EMERGENCY CLEANUP: Check if state maps are growing out of control
static std::atomic<uint64_t> frame_count{0};
++frame_count;
const size_t MAX_SOURCES = 100; // Safety limit for source tracking
std::shared_lock elem_lock(elements_mutex_);
std::lock_guard state_lock(state_mutex_);
size_t max_size = std::max(source_elements_.size(), source_states_.size());
if (max_size > MAX_SOURCES) {
LOGW(
"SmartRecordHandlerV2: EMERGENCY - source tracking exceeded limit ({}), forcing "
"cleanup",
max_size);
LOGW(" cached_elements={}, tracked_sources={}", source_elements_.size(),
// Cleanup expired sessions MORE FREQUENTLY (every 500 frames instead of on-demand)
if (frame_count % 500 == 0) {
cleanup_expired_sessions(current_time);
// Log comprehensive memory stats periodically (every ~1000 frames)
if (frame_count % 1000 == 0) {
LOGI("SmartRecordHandlerV2: Memory stats - cached_elements={}, tracked_sources={}",
// Count active recordings
size_t active_count = 0;
size_t idle_count = 0;
for (const auto& [sid, state] : source_states_) {
if (state.recording_state == RecordingState::RECORDING) {
active_count++;
} else if (state.recording_state == RecordingState::IDLE) {
idle_count++;
LOGI(" Recording states - active={}, idle={}, other={}", active_count, idle_count,
source_states_.size() - active_count - idle_count);
// Estimate memory usage
size_t approx_mem_kb = (source_elements_.size() * 64) + // GstElement refs + overhead
(source_states_.size() * 128); // RecordingState structs
LOGI(" Estimated handler memory: ~{} KB", approx_mem_kb / 1024);
// Process frames
for (NvDsFrameMetaList* l_frame = batch_meta->frame_meta_list; l_frame != nullptr;
l_frame = l_frame->next) {
NvDsFrameMeta* frame_meta = static_cast<NvDsFrameMeta*>(l_frame->data);
if (!frame_meta) {
continue;
uint32_t source_id = frame_meta->source_id;
// Process objects in frame
for (NvDsObjectMetaList* l_obj = frame_meta->obj_meta_list; l_obj != nullptr;
l_obj = l_obj->next) {
NvDsObjectMeta* obj_meta = static_cast<NvDsObjectMeta*>(l_obj->data);
if (!obj_meta || !obj_meta->obj_label) {
continue;
std::string label(obj_meta->obj_label);
// Check if this label is in our target list
if (!config_.target_labels.empty() &&
config_.target_labels.find(label) == config_.target_labels.end()) {
continue;
// Check if we can start recording for this source
if (!can_start_recording(source_id, current_time)) {
continue;
// Start recording
LOGI("SmartRecordHandlerV2: Triggering record for source {} by object {} ({})",
source_id, obj_meta->object_id, label);
start_recording(source_id, obj_meta->object_id, current_time);
// Only one recording trigger per frame per source
break;
// Private Methods
void SmartRecordHandlerV2::parse_config(const std::string& config_str) {
LOGD("SmartRecordHandlerV2: Parsing config: {}", config_str);
// Helper lambda to extract value
auto get_value = [&config_str](const std::string& key) -> std::string {
size_t key_pos = config_str.find(key);
if (key_pos == std::string::npos) {
return "";
size_t eq_pos = config_str.find('=', key_pos);
if (eq_pos == std::string::npos) {
return "";
size_t start = eq_pos + 1;
size_t end = config_str.find(';', start);
if (end == std::string::npos) {
end = config_str.length();
return config_str.substr(start, end - start);
// Parse string values
std::string val;
val = get_value("source_from=");
if (!val.empty())
config_.source_from = val;
val = get_value("pipeline_id=");
if (!val.empty())
config_.pipeline_id = val;
val = get_value("mbroker_host=");
if (!val.empty())
config_.redis_host = val;
val = get_value("mbroker_channel=");
if (!val.empty())
config_.redis_channel = val;
// Parse numeric values
val = get_value("mbroker_port=");
if (!val.empty()) {
try {
config_.redis_port = static_cast<uint16_t>(std::stoul(val));
} catch (...) {
val = get_value("pre=");
if (!val.empty()) {
try {
config_.pre_event_sec = std::stoul(val);
} catch (...) {
val = get_value("post=");
if (!val.empty()) {
try {
config_.post_event_sec = std::stoul(val);
} catch (...) {
val = get_value("min_interval=");
if (!val.empty()) {
try {
config_.min_interval_sec = std::stoul(val);
} catch (...) {
val = get_value("max_concurrent_recordings=");
if (!val.empty()) {
try {
config_.max_concurrent_recordings = std::stoul(val);
} catch (...) {
// Parse class_ids/labels
val = get_value("class_ids=");
if (!val.empty()) {
std::istringstream iss(val);
std::string label;
while (std::getline(iss, label, ',')) {
// Trim whitespace
label.erase(0, label.find_first_not_of(" \t"));
label.erase(label.find_last_not_of(" \t") + 1);
if (!label.empty()) {
config_.target_labels.insert(label);
// Parse source_names
val = get_value("source_names=");
if (!val.empty()) {
std::string name;
uint32_t idx = 0;
while (std::getline(iss, name, ',')) {
name.erase(0, name.find_first_not_of(" \t"));
name.erase(name.find_last_not_of(" \t") + 1);
if (!name.empty()) {
config_.source_id_to_name[idx] = name;
++idx;
// Log parsed config
std::string labels_str;
for (const auto& l : config_.target_labels) {
if (!labels_str.empty())
labels_str += ",";
labels_str += l;
LOGI(
"SmartRecordHandlerV2: Config - source_from={}, pre={}s, post={}s, "
"min_interval={}s, max_concurrent_recordings={}, labels=[{}], redis={}:{}/{}",
config_.source_from, config_.pre_event_sec, config_.post_event_sec,
config_.min_interval_sec, config_.max_concurrent_recordings, labels_str, config_.redis_host,
GstElementRef SmartRecordHandlerV2::get_nvurisrcbin(uint32_t source_id) {
// Check cache first
auto it = source_elements_.find(source_id);
if (it != source_elements_.end() && it->second) {
// Return cached element only if it still belongs to our multiuribin.
// On RTSP reconnect, DeepStream may recreate nvurisrcbin and remove the old element
// from the bin; holding a ref would keep the old element alive and leak memory.
if (multiuribin_ &&
is_descendant_of(GST_OBJECT(it->second.get()), GST_OBJECT(multiuribin_.get()))) {
return GstElementRef(it->second.get(), true);
// If cached element exists but is no longer in multiuribin, drop it + disconnect its signal.
std::unique_lock elem_lock(elements_mutex_);
bool still_attached = multiuribin_ && is_descendant_of(GST_OBJECT(it->second.get()),
GST_OBJECT(multiuribin_.get()));
if (!still_attached) {
LOGW(
"SmartRecordHandlerV2: Cached nvurisrcbin for source {} is stale (likely "
"reconnect) - dropping cache",
source_id);
auto st_it = source_states_.find(source_id);
if (st_it != source_states_.end() && st_it->second.signal_handler_id != 0) {
g_signal_handler_disconnect(it->second.get(),
st_it->second.signal_handler_id);
st_it->second.signal_handler_id = 0;
source_elements_.erase(it);
// Find and cache
GstElement* urisrcbin = nullptr;
return GstElementRef();
urisrcbin = find_nvurisrcbin_in_bin(multiuribin_.get(), source_id, config_.source_from);
if (!urisrcbin) {
LOGW("SmartRecordHandlerV2: Could not find nvurisrcbin for source {}", source_id);
// Cache it (transfer ownership to cache, get a new ref for return)
// Double-check
gst_object_unref(urisrcbin); // Already cached
source_elements_[source_id] = GstElementRef(urisrcbin, false); // Takes ownership
// Attach source_id to element so callback can map reliably even if cache changes
g_object_set_data(G_OBJECT(urisrcbin), kSourceIdDataKey, GUINT_TO_POINTER(source_id));
// Connect signal for this source
auto& state = source_states_[source_id];
if (state.signal_handler_id == 0) {
state.signal_handler_id = g_signal_connect(
urisrcbin, "sr-done", G_CALLBACK(SmartRecordHandlerV2::on_recording_done), this);
LOGD("SmartRecordHandlerV2: Connected sr-done signal for source {}", source_id);
// Return a new reference to the cached element
return GstElementRef(urisrcbin, true);
bool SmartRecordHandlerV2::can_start_recording(uint32_t source_id, GstClockTime current_time) {
if (config_.max_concurrent_recordings > 0) {
uint32_t active_count = 0;
for (const auto& [sid, st] : source_states_) {
if (st.recording_state != RecordingState::IDLE) {
++active_count;
if (active_count >= config_.max_concurrent_recordings) {
LOGT("SmartRecordHandlerV2: Skipping - max concurrent recordings reached ({})",
config_.max_concurrent_recordings);
return false;
auto it = source_states_.find(source_id);
if (it == source_states_.end()) {
return true; // No state yet = can start
const auto& state = it->second;
// Check #0: Recording state (CRITICAL for memory safety)
// Purpose: Prevent overlapping recordings that cause memory corruption
// Must wait for previous recording to fully complete and cleanup
if (state.recording_state != RecordingState::IDLE) {
LOGT("SmartRecordHandlerV2: Skipping - recording state is not IDLE (source {})", source_id);
return false;
// Check #0.5: Safety gap after recording ends (CRITICAL)
// Purpose: GStreamer/nvurisrcbin needs time to cleanup internal state
// Even with min_interval_sec=0, we enforce minimum 2s gap for stability
if (GST_CLOCK_TIME_IS_VALID(state.last_record_end)) {
GstClockTime elapsed = current_time - state.last_record_end;
GstClockTime safety_gap = RECORDING_SAFETY_GAP_SEC * GST_SECOND;
if (elapsed < safety_gap) {
LOGT("SmartRecordHandlerV2: Skipping due to safety gap ({}s < {}s)",
elapsed / GST_SECOND, RECORDING_SAFETY_GAP_SEC);
return false;
// Check #1: Minimum interval between recordings (user-configured throttle)
// Purpose: Additional user-defined gap between recordings
// Note: Actual minimum gap = max(min_interval_sec, RECORDING_SAFETY_GAP_SEC)
if (GST_CLOCK_TIME_IS_VALID(state.last_record_start)) {
GstClockTime elapsed = current_time - state.last_record_start;
GstClockTime min_interval = config_.min_interval_sec * GST_SECOND;
if (elapsed < min_interval) {
LOGT("SmartRecordHandlerV2: Skipping due to min_interval ({}s < {}s)",
elapsed / GST_SECOND, config_.min_interval_sec);
return false;
return true;
void SmartRecordHandlerV2::start_recording(uint32_t source_id, uint64_t trigger_object_id,
// Get nvurisrcbin element
GstElementRef urisrcbin = get_nvurisrcbin(source_id);
if (!urisrcbin) {
LOGE("SmartRecordHandlerV2: Cannot get nvurisrcbin for source {}", source_id);
return;
// DeepStream Smart Record semantics: startTime = seconds BEFORE now, duration = seconds AFTER
// now. If we pass (pre + post) as duration, recordings become ~pre seconds longer than expected
// and can enlarge internal buffering requirements.
uint32_t start_time_sec = config_.pre_event_sec;
uint32_t duration_sec = config_.post_event_sec;
uint32_t total_duration_sec = start_time_sec + duration_sec;
if (total_duration_sec == 0) {
// Minimum 1 second after-event duration.
duration_sec = 1;
std::string source_name = get_source_name(source_id);
// Create session info
RecordingSessionV2 session;
// DeepStream assigns the actual session id via the start-sr out-parameter.
// We set placeholder here and update immediately after emitting start-sr.
session.session_id = 0;
session.source_id = source_id;
session.source_name = source_name;
session.pipeline_id = config_.pipeline_id;
session.start_time = current_time;
session.duration_sec = total_duration_sec;
session.wall_clock_start = std::chrono::system_clock::now();
// Update state
state.last_record_start = current_time;
state.active_session = session;
state.recording_state = RecordingState::RECORDING; // Mark as recording
// Emit start-sr signal
// Note: We pass nullptr for user_data since we track sessions internally
NvDsSRSessionId sr_session_id = 0;
g_signal_emit_by_name(urisrcbin.get(), "start-sr", &sr_session_id, start_time_sec, duration_sec,
nullptr); // No user_data - avoids memory management issues
const uint32_t ds_session_id = static_cast<uint32_t>(sr_session_id);
if (it != source_states_.end() && it->second.active_session) {
it->second.active_session->session_id = ds_session_id;
LOGI(
"SmartRecordHandlerV2: Started recording - session={}, source={}, startTime={}s, "
"duration={}s (total={}s)",
ds_session_id, source_id, start_time_sec, duration_sec, total_duration_sec);
const uint64_t started = ++sr_started_;
if (started % 100 == 0) {
LOGI(
"SmartRecordHandlerV2: SR stats - started={}, done={}, stop_emitted={}, "
"stopping_timeouts={}",
started, sr_done_.load(), sr_stop_emitted_.load(), sr_stopping_timeouts_.load());
// Publish to Redis (compatible with V1 field names)
if (redis_producer_) {
// CRITICAL: Store string conversions in variables to ensure lifetime
// std::to_string() returns temporary - must persist until send_message() completes
std::string sid_str = std::to_string(source_id);
std::string session_id_str = std::to_string(ds_session_id);
std::string start_time_str = std::to_string(config_.pre_event_sec);
std::string duration_str =
std::to_string(total_duration_sec * 1000); // V1 sends milliseconds
std::string trigger_obj_str = std::to_string(trigger_object_id);
std::string event_ts_str = get_unix_millis();
std::vector<std::pair<std::string, std::string>> fields = {
{"event", "record_started"},
{"pid", config_.pipeline_id},
{"sid", sid_str},
{"sname", source_name},
{"session_id", session_id_str},
{"start_time", start_time_str},
{"duration", duration_str},
{"trigger_obj", trigger_obj_str},
{"event_ts", event_ts_str},
redis_producer_->send_message(fields);
void SmartRecordHandlerV2::cleanup_expired_sessions(GstClockTime current_time) {
struct RemoveInfo {
uint32_t source_id;
gulong signal_handler_id;
struct StopInfo {
uint32_t source_id;
std::vector<RemoveInfo> to_remove;
std::vector<StopInfo> to_stop;
constexpr GstClockTime STOPPING_TIMEOUT = 15 * GST_SECOND;
// Phase 1: decide what to evict + capture signal handler ids while holding state_mutex_
for (auto& [source_id, state] : source_states_) {
// If we're in STOPPING for too long, force-reset to IDLE.
// This is a last resort to avoid permanently blocking a source if sr-done is lost.
if (state.recording_state == RecordingState::STOPPING &&
GST_CLOCK_TIME_IS_VALID(state.stop_request_time)) {
GstClockTime elapsed = current_time - state.stop_request_time;
if (elapsed > STOPPING_TIMEOUT) {
LOGW(
"SmartRecordHandlerV2: STOPPING timeout - forcing state to IDLE (source "
source_id);
++sr_stopping_timeouts_;
state.stopping_session_id.reset();
state.stop_request_time = GST_CLOCK_TIME_NONE;
state.active_session.reset();
state.recording_state = RecordingState::IDLE;
state.last_record_end = current_time;
// Clear expired active sessions
if (state.active_session && state.active_session->is_expired(current_time)) {
LOGD("SmartRecordHandlerV2: Clearing expired session for source {}", source_id);
// Best-effort stop to avoid stuck SR sessions if sr-done never arrives.
if (state.active_session->session_id != 0) {
const uint32_t session_id =
static_cast<uint32_t>(state.active_session->session_id);
to_stop.push_back(StopInfo{source_id, session_id});
// IMPORTANT: Do NOT mark IDLE before stop-sr completes.
// Starting a new recording in this window can overlap and destabilize
// DeepStream smart record.
state.stopping_session_id = session_id;
state.stop_request_time = current_time;
state.recording_state = RecordingState::STOPPING;
} else {
// No session id yet; treat as finished.
// Mark very old inactive entries for removal (prevent unbounded growth)
// CRITICAL: Reduced from 5min to 2min for aggressive cleanup
constexpr GstClockTime MAX_IDLE_TIME = 2 * 60 * GST_SECOND; // 2 minutes (was 5)
if (state.recording_state == RecordingState::IDLE && !state.active_session &&
GstClockTime idle_time = current_time - state.last_record_end;
if (idle_time > MAX_IDLE_TIME) {
to_remove.push_back(RemoveInfo{source_id, state.signal_handler_id});
// Remove states now (we'll disconnect signals + drop cached elements in phase 2)
for (const auto& info : to_remove) {
LOGI("SmartRecordHandlerV2: Evicting inactive source {} from state cache",
info.source_id);
source_states_.erase(info.source_id);
if (to_remove.empty()) {
// Still may need to stop expired sessions.
// Phase 2a: emit stop-sr for expired sessions (no state_mutex_ held)
for (const auto& info : to_stop) {
GstElementRef urisrcbin = get_nvurisrcbin(info.source_id);
if (urisrcbin) {
NvDsSRSessionId sr_session_id = static_cast<NvDsSRSessionId>(info.session_id);
g_signal_emit_by_name(urisrcbin.get(), "stop-sr", sr_session_id);
++sr_stop_emitted_;
LOGD("SmartRecordHandlerV2: Emitted stop-sr for expired session {} (source {})",
info.session_id, info.source_id);
return;
// Phase 2: disconnect signals and drop cached elements while holding elements_mutex_
// Lock order across this class is elements_mutex_ -> state_mutex_. We intentionally
// do NOT acquire state_mutex_ here to avoid lock inversion.
auto elem_it = source_elements_.find(info.source_id);
if (elem_it != source_elements_.end() && elem_it->second) {
if (info.signal_handler_id != 0) {
g_signal_handler_disconnect(elem_it->second.get(), info.signal_handler_id);
LOGD("SmartRecordHandlerV2: Disconnected sr-done for evicted source {}",
info.source_id);
source_elements_.erase(elem_it);
LOGI("SmartRecordHandlerV2: Removed cached element for evicted source {}",
info.source_id);
void SmartRecordHandlerV2::disconnect_all_signals() {
for (auto& [source_id, element] : source_elements_) {
if (element) {
auto state_it = source_states_.find(source_id);
if (state_it != source_states_.end() && state_it->second.signal_handler_id != 0) {
g_signal_handler_disconnect(element.get(), state_it->second.signal_handler_id);
state_it->second.signal_handler_id = 0;
LOGD("SmartRecordHandlerV2: Disconnected signal for source {}", source_id);
std::string SmartRecordHandlerV2::get_source_name(uint32_t source_id) const {
auto it = config_.source_id_to_name.find(source_id);
if (it != config_.source_id_to_name.end()) {
return it->second;
return "source_" + std::to_string(source_id);
// Static callback
void SmartRecordHandlerV2::on_recording_done(GstElement* element, NvDsSRRecordingInfo* info,
gpointer recording_user_data, gpointer user_data) {
auto* handler = static_cast<SmartRecordHandlerV2*>(user_data);
if (!handler || handler->shutting_down_.load()) {
return;
if (!info) {
LOGW("SmartRecordHandlerV2: on_recording_done called with null info");
return;
LOGI("SmartRecordHandlerV2: Recording done - file={}, width={}, height={}, duration={}",
info->filename ? info->filename : "null", info->width, info->height, info->duration);
const uint64_t done = ++handler->sr_done_;
if (done % 100 == 0) {
LOGI(
handler->sr_started_.load(), done, handler->sr_stop_emitted_.load(),
handler->sr_stopping_timeouts_.load());
// Find which source this is from and get session_id
uint32_t source_id = 0;
uint32_t session_id = static_cast<uint32_t>(info->sessionId);
bool found = false;
// Preferred: read source_id directly from element qdata (safe across reconnect/cache eviction)
if (element) {
gpointer sid_ptr = g_object_get_data(G_OBJECT(element), kSourceIdDataKey);
if (sid_ptr) {
source_id = GPOINTER_TO_UINT(sid_ptr);
found = true;
if (!found) {
std::shared_lock lock(handler->elements_mutex_);
for (const auto& [sid, elem] : handler->source_elements_) {
if (elem.get() == element) {
source_id = sid;
found = true;
break;
// Get session_id from active session if available
if (found) {
std::lock_guard lock(handler->state_mutex_);
auto it = handler->source_states_.find(source_id);
if (it != handler->source_states_.end()) {
if (it->second.active_session) {
if (it->second.active_session->session_id != session_id) {
LOGW(
"SmartRecordHandlerV2: sr-done session mismatch (source {}): active={}, "
"info={}",
source_id, it->second.active_session->session_id, session_id);
// Clear active session - recording is done (free memory)
it->second.active_session.reset();
// Clear STOPPING bookkeeping (if any)
it->second.stopping_session_id.reset();
it->second.stop_request_time = GST_CLOCK_TIME_NONE;
// Update recording state to IDLE - recording is done
it->second.recording_state = RecordingState::IDLE;
// Get current time for safety gap tracking
GstClockTime end_time = get_gst_system_time();
if (GST_CLOCK_TIME_IS_VALID(end_time)) {
it->second.last_record_end = end_time;
} else {
// Fallback: use last_record_start + duration
if (GST_CLOCK_TIME_IS_VALID(it->second.last_record_start)) {
it->second.last_record_start +
(handler->config_.pre_event_sec + handler->config_.post_event_sec) *
GST_SECOND;
LOGD("SmartRecordHandlerV2: Recording complete, state set to IDLE (source {})",
source_id);
if (handler->redis_producer_ && found) {
// CRITICAL: Store string conversions to ensure lifetime
std::string source_name = handler->get_source_name(source_id);
std::string session_id_str = std::to_string(session_id);
std::string width_str = info->width ? std::to_string(info->width) : "";
std::string height_str = info->height ? std::to_string(info->height) : "";
std::string filename_str = info->filename ? info->filename : "";
std::string duration_str = std::to_string(info->duration);
{"event", "record_done"},
{"pid", handler->config_.pipeline_id},
{"sid", sid_str},
{"width", width_str},
{"height", height_str},
{"filename", filename_str},
handler->redis_producer_->send_message(fields);
