Memory leak when I put for recording (smart recording)
We are creating a sub topic based on following forum link.
Scenario1:
Lets say I have an rtsp where Iam allocating the buffer and giving signal to start recording for every 10 seconds. following is the code
a = pyds.alloc_buffer1(4)
element.emit(‘start-sr’, a, 5, 5, None)
so, In this case Iam recording for 10 seconds. It is giving me video and renaming it with whatever name we want.
In this scenario1, there is huge amount of memory leak happening.
Scenario2:
Lets say I have an rtsp where Iam allocating the buffer and but I am not giving signal to start recording(start-sr) for every 10 seconds. following is the code
so, In this case Iam allocating buffer, but not recording.
In this scenario2, there is very little memory leak happening.
So, based on these scenarios can you figure out why is it happening and what is the best ever solution you think can fix this.
@snehashish.debnath @debjit.adak @junshengy
please respond ASAP, Thanks.
1.smart recording memory leaks are not detected using valgrind, can you share how you detected them?
valgrind --tool=memcheck --leak-check=full --num-callers=100 --show-leak-kinds=definite,indirect --track-origins=yes python3 sr_test.py "rtsp://xxxxx"
2.There is no memory leak here. In the FAQ, there is the following code to release memory
   # release native memory
    pyds.free_gbuffer(sessionid)
    pyds.free_gbuffer(sr_user_context_buf)
You seem to have provided some legacy code, please refer to this FAQ.
QUESTION1:
We are running below deepstream app with smart recording code. can you tell us why is it leaking memory.
we are checking memory profiling with the docker stats.
#!/usr/bin/env python3
# SPDX-FileCopyrightText: Copyright (c) 2019-2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: Apache-2.0
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import sys
sys.path.append('../')
from pathlib import Path
import gi
import configparser
import argparse
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
from ctypes import *
import time
import sys
import math
import platform
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
from common.FPS import PERF_DATA
import time, threading
import pyds
import ctypes
no_display = False
silent = False
file_loop = False
perf_data = None
MAX_DISPLAY_LEN=64
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_OUTPUT_WIDTH=1920
MUXER_OUTPUT_HEIGHT=1080
MUXER_BATCH_TIMEOUT_USEC = 33000
TILED_OUTPUT_WIDTH=1280
TILED_OUTPUT_HEIGHT=720
GST_CAPS_FEATURES_NVMM="memory:NVMM"
OSD_PROCESS_MODE= 0
OSD_DISPLAY_TEXT= 1
pgie_classes_str= ["Vehicle", "TwoWheeler", "Person","RoadSign"]
list_for_nvurisrcbin = []
class SRUserContext(ctypes.Structure):
    _fields_ = [
        ("sessionid", ctypes.c_int),
        ("name", ctypes.c_char * 32)
# pgie_src_pad_buffer_probe  will extract metadata received on tiler sink pad
# and update params for drawing rectangle, object information etc.
def pgie_src_pad_buffer_probe(pad,info,u_data):
    frame_number=0
    num_rects=0
    got_fps = False
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
        except StopIteration:
            break
        frame_number=frame_meta.frame_num
        l_obj=frame_meta.obj_meta_list
        num_rects = frame_meta.num_obj_meta
        obj_counter = {
        PGIE_CLASS_ID_VEHICLE:0,
        PGIE_CLASS_ID_PERSON:0,
        PGIE_CLASS_ID_BICYCLE:0,
        PGIE_CLASS_ID_ROADSIGN:0
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            obj_counter[obj_meta.class_id] += 1
            try:
                l_obj=l_obj.next
                break
        if not silent:
            print("Frame Number=", frame_number, "Number of Objects=",num_rects,"Vehicle_count=",obj_counter[PGIE_CLASS_ID_VEHICLE],"Person_count=",obj_counter[PGIE_CLASS_ID_PERSON])
        # Update frame rate through this probe
        stream_index = "stream{0}".format(frame_meta.pad_index)
        global perf_data
        perf_data.update_fps(stream_index)
        try:
            l_frame=l_frame.next
            break
    return Gst.PadProbeReturn.OK
def cb_newpad(decodebin, decoder_src_pad,data):
    print("In cb_newpad\n")
    caps=decoder_src_pad.get_current_caps()
    if not caps:
        caps = decoder_src_pad.query_caps()
    gststruct=caps.get_structure(0)
    gstname=gststruct.get_name()
    source_bin=data
    features=caps.get_features(0)
    # Need to check if the pad created by the decodebin is for video and not
    # audio.
    print("gstname=",gstname)
    if(gstname.find("video")!=-1):
        # Link the decodebin pad only if decodebin has picked nvidia
        # decoder plugin nvdec_*. We do this by checking if the pad caps contain
        # NVMM memory features.
        print("features=",features)
        if features.contains("memory:NVMM"):
            # Get the source bin ghost pad
            bin_ghost_pad=source_bin.get_static_pad("src")
            if not bin_ghost_pad.set_target(decoder_src_pad):
                sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
        else:
            sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy,Object,name,user_data):
    print("Decodebin child added:", name, "\n")
    if(name.find("decodebin") != -1):
        Object.connect("child-added",decodebin_child_added,user_data)
    if "source" in name:
        source_element = child_proxy.get_by_name("source")
        if source_element.find_property('drop-on-latency') != None:
            Object.set_property("drop-on-latency", True)
def create_source_bin(index,uri):
    print("Creating source bin")
    # Create a source GstBin to abstract this bin's content from the rest of the
    # pipeline
    bin_name="source-bin-%02d" %index
    print(bin_name)
    nbin=Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write(" Unable to create source bin \n")
    # Source element for reading from the uri.
    # We will use decodebin and let it figure out the container format of the
    # stream and the codec and plug the appropriate demux and decode plugins.
    if not file_loop:
        # use nvurisrcbin to enable file-loop
        print("HEY DEB I CAME INSIDE FILE LOOP --------------------------------> I don't know what to do ")
        uri_decode_bin=Gst.ElementFactory.make("nvurisrcbin", "uri-decode-bin" + str(index))
        # uri_decode_bin.set_property("file-loop", 1)
        uri_decode_bin.set_property("cudadec-memtype", 0)
    else:
        uri_decode_bin=Gst.ElementFactory.make("nvurisrcbin", "uri-decode-bin")
    if not uri_decode_bin:
        sys.stderr.write(" Unable to create uri decode bin \n")
    uri_decode_bin.set_property("smart-record", 2)
    uri_decode_bin.set_property("smart-rec-dir-path", ".")
    uri_decode_bin.set_property("source-id",index)
    # We set the input uri to the source element
    uri_decode_bin.set_property("uri",uri)
    list_for_nvurisrcbin.append(uri_decode_bin)
    # Connect to the "pad-added" signal of the decodebin which generates a
    # callback once a new pad for raw data has beed created by the decodebin
    uri_decode_bin.connect("pad-added",cb_newpad,nbin)
    uri_decode_bin.connect("child-added",decodebin_child_added,nbin)
    # We need to create a ghost pad for the source bin which will act as a proxy
    # for the video decoder src pad. The ghost pad will not have a target right
    # now. Once the decode bin creates the video decoder and generates the
    # cb_newpad callback, we will set the ghost pad target to the video decoder
    # src pad.
    Gst.Bin.add(nbin,uri_decode_bin)
    bin_pad=nbin.add_pad(Gst.GhostPad.new_no_target("src",Gst.PadDirection.SRC))
    if not bin_pad:
        sys.stderr.write(" Failed to add ghost pad in source bin \n")
        return None
    return nbin
def start_sr_function(emement):
    sessionid = pyds.get_native_ptr(pyds.alloc_buffer(4))
    print(f"sessionid {sessionid}")
    sr_user_context_size = ctypes.sizeof(SRUserContext)
    sr_user_context_buf = pyds.get_native_ptr(pyds.alloc_buffer(sr_user_context_size))
    sr_user_context = pyds.SRUserContext.cast(sr_user_context_buf)
    sr_user_context.sessionid = 42
    sr_user_context.name = "sr-demo"
    print(f"sr_user_context_buf {sr_user_context_buf}")
    emement.emit('start-sr', sessionid, 5, 5, sr_user_context_buf)
    print('******start sr*****')
    return True
def main(args, requested_pgie=None, config=None, disable_probe=False):
    global perf_data
    perf_data = PERF_DATA(len(args))
    number_sources=len(args)
    # Standard GStreamer initialization
    Gst.init(None)
    # Create gstreamer elements */
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        print("Creating source_bin ",i," \n ")
        uri_name=args[i]
        if uri_name.find("rtsp://") == 0 :
            is_live = True
        source_bin=create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname="sink_%u" %i
        sinkpad= streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad=source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    queue1=Gst.ElementFactory.make("queue","queue1")
    queue2=Gst.ElementFactory.make("queue","queue2")
    queue3=Gst.ElementFactory.make("queue","queue3")
    queue4=Gst.ElementFactory.make("queue","queue4")
    queue5=Gst.ElementFactory.make("queue","queue5")
    pipeline.add(queue1)
    pipeline.add(queue2)
    pipeline.add(queue3)
    pipeline.add(queue4)
    pipeline.add(queue5)
    nvdslogger = None
    print("Creating Pgie \n ")
    if requested_pgie != None and (requested_pgie == 'nvinferserver' or requested_pgie == 'nvinferserver-grpc') :
        pgie = Gst.ElementFactory.make("nvinferserver", "primary-inference")
    elif requested_pgie != None and requested_pgie == 'nvinfer':
        pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    else:
    if not pgie:
        sys.stderr.write(" Unable to create pgie :  %s\n" % requested_pgie)
    if disable_probe:
        # Use nvdslogger for perf measurement instead of probe function
        print ("Creating nvdslogger \n")
        nvdslogger = Gst.ElementFactory.make("nvdslogger", "nvdslogger")
    print("Creating tiler \n ")
    tiler=Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        sys.stderr.write(" Unable to create tiler \n")
    print("Creating nvvidconv \n ")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    print("Creating nvosd \n ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    nvosd.set_property('process-mode',OSD_PROCESS_MODE)
    nvosd.set_property('display-text',OSD_DISPLAY_TEXT)
    if file_loop:
        if is_aarch64():
            # Set nvbuf-memory-type=4 for aarch64 for file-loop (nvurisrcbin case)
            streammux.set_property('nvbuf-memory-type', 4)
        else:
            # Set nvbuf-memory-type=2 for x86 for file-loop (nvurisrcbin case)
            streammux.set_property('nvbuf-memory-type', 2)
    if no_display:
        print("Creating Fakesink \n")
        sink = Gst.ElementFactory.make("fakesink", "fakesink")
        sink.set_property('enable-last-sample', 0)
        sink.set_property('sync', 0)
    else:
        if is_aarch64():
            print("Creating nv3dsink \n")
            sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
            if not sink:
                sys.stderr.write(" Unable to create nv3dsink \n")
        else:
            print("Creating EGLSink \n")
            sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
            if not sink:
                sys.stderr.write(" Unable to create egl sink \n")
    if not sink:
        sys.stderr.write(" Unable to create sink element \n")
    if is_live:
        print("At least one of the sources is live")
        streammux.set_property('live-source', 1)
    streammux.set_property('width', 1920)
    streammux.set_property('height', 1080)
    streammux.set_property('batch-size', number_sources)
    streammux.set_property('batched-push-timeout', MUXER_BATCH_TIMEOUT_USEC)
    if requested_pgie == "nvinferserver" and config != None:
        pgie.set_property('config-file-path', config)
    elif requested_pgie == "nvinferserver-grpc" and config != None:
    elif requested_pgie == "nvinfer" and config != None:
    else:
        pgie.set_property('config-file-path', "dstest3_pgie_config.txt")
    pgie_batch_size=pgie.get_property("batch-size")
    if(pgie_batch_size != number_sources):
        print("WARNING: Overriding infer-config batch-size",pgie_batch_size," with number of sources ", number_sources," \n")
        pgie.set_property("batch-size",number_sources)
    tiler_rows=int(math.sqrt(number_sources))
    tiler_columns=int(math.ceil((1.0*number_sources)/tiler_rows))
    tiler.set_property("rows",tiler_rows)
    tiler.set_property("columns",tiler_columns)
    tiler.set_property("width", TILED_OUTPUT_WIDTH)
    tiler.set_property("height", TILED_OUTPUT_HEIGHT)
    sink.set_property("qos",0)
    print("Adding elements to Pipeline \n")
    pipeline.add(pgie)
    if nvdslogger:
        pipeline.add(nvdslogger)
    pipeline.add(tiler)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(sink)
    print("Linking elements in the Pipeline \n")
    streammux.link(queue1)
    queue1.link(pgie)
    pgie.link(queue2)
    if nvdslogger:
        queue2.link(nvdslogger)
        nvdslogger.link(tiler)
    else:
        queue2.link(tiler)
    tiler.link(queue3)
    queue3.link(nvvidconv)
    nvvidconv.link(queue4)
    queue4.link(nvosd)
    nvosd.link(queue5)
    queue5.link(sink)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    pgie_src_pad=pgie.get_static_pad("src")
    if not pgie_src_pad:
        sys.stderr.write(" Unable to get src pad \n")
    else:
        if not disable_probe:
            pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, pgie_src_pad_buffer_probe, 0)
            # perf callback function to print fps every 5 sec
            GLib.timeout_add(5000, perf_data.perf_print_callback)
    # List the sources
    print("Now playing...")
    for i, source in enumerate(args):
        print(i, ": ", source)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    for uribin in list_for_nvurisrcbin:
        timer_id = GLib.timeout_add_seconds(10, start_sr_function,uribin)
    try:
        loop.run()
    except:
        pass
    # cleanup
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
def parse_args():
    parser = argparse.ArgumentParser(prog="deepstream_test_3",
                    description="deepstream-test3 multi stream, multi model inference reference app")
    parser.add_argument(
        "-i",
        "--input",
        help="Path to input streams",
        nargs="+",
        metavar="URIs",
        default=["a"],
        required=True,
        "-c",
        "--configfile",
        metavar="config_location.txt",
        default=None,
        help="Choose the config-file to be used with specified pgie",
        "-g",
        "--pgie",
        default=None,
        help="Choose Primary GPU Inference Engine",
        choices=["nvinfer", "nvinferserver", "nvinferserver-grpc"],
        "--no-display",
        action="store_true",
        default=True,
        dest='no_display',
        help="Disable display of video output",
        "--file-loop",
        default=False,
        dest='file_loop',
        help="Loop the input file sources after EOS",
        "--disable-probe",
        default=False,
        dest='disable_probe',
        help="Disable the probe function and use nvdslogger for FPS",
        "-s",
        "--silent",
        default=False,
        dest='silent',
        help="Disable verbose output",
    # Check input arguments
    if len(sys.argv) == 1:
        parser.print_help(sys.stderr)
        sys.exit(1)
    args = parser.parse_args()
    stream_paths = args.input
    pgie = args.pgie
    config = args.configfile
    disable_probe = args.disable_probe
    global no_display
    global silent
    global file_loop
    # no_display = args.no_display
    no_display = True
    # silent = args.silent
    silent = True
    # file_loop = args.file_loop
    file_loop = True
    if config and not pgie or pgie and not config:
        sys.stderr.write ("\nEither pgie or configfile is missing. Please specify both! Exiting...\n\n\n\n")
        parser.print_help()
        sys.exit(1)
    if config:
        config_path = Path(config)
        if not config_path.is_file():
            sys.stderr.write ("Specified config-file: %s doesn't exist. Exiting...\n\n" % config)
            sys.exit(1)
    print(vars(args))
    return stream_paths, pgie, config, disable_probe
if __name__ == '__main__':
    stream_paths, pgie, config, disable_probe = parse_args()
    sys.exit(main(stream_paths, pgie, config, disable_probe))
Following is the memory graph of above code where the memory is gradually leaking.
QUESTION2:
If we are keeping smart-rec-video-cache= 50 which is Size of video cache in seconds. If Iam not wrong this parameter will increase the overall memory usages of the application???
There are some issues in your code. I modified it and tested it for a long time, but no memory leak was found.
The following is the modified code
import sys
import gi
import configparser
import argparse
import time
import sys
import math
import platform
from common.platform_info import PlatformInfo
import pyds
import ctypes
no_display = False
silent = False
file_loop = False
perf_data = None
MAX_DISPLAY_LEN=64
OSD_PROCESS_MODE= 0
OSD_DISPLAY_TEXT= 1
    _fields_ = [
    frame_number=0
    num_rects=0
    got_fps = False
    if not gst_buffer:
        return
        try:
            # it alone.
            break
        obj_counter = {
            try:
                break
            try:
                l_obj=l_obj.next
                break
        if not silent:
        global perf_data
        try:
            break
    if not caps:
    source_bin=data
    # audio.
        else:
    # pipeline
    print(bin_name)
    if not nbin:
    if not file_loop:
    else:
    uri_decode_bin.set_property("smart-rec-cache", 20) # enable smart record.
    uri_decode_bin.connect("sr-done", record_done, nbin)
    global list_for_nvurisrcbin
    # src pad.
    if not bin_pad:
        return None
    return nbin
def start_sr_function(element):
    sr_user_context.name = "sr-demo " + element.get_name()
    print(f"sr_user_context_buf {sr_user_context_buf} {element.get_name()}")
    element.emit('start-sr', sessionid, 5, 5, sr_user_context_buf)
    return True
def record_done(nvurisrcbin, recordingInfo, user_ctx, user_data):
    print('******sr done*****')
    sr = pyds.SRUserContext.cast(hash(user_ctx))
    print(f"session id {sr.sessionid} -- name {sr.name}")
    pyds.free_buffer(hash(user_ctx))
    global perf_data
    platform_info = PlatformInfo()
    Gst.init(None)
    is_live = False
    if not pipeline:
    if not streammux:
        uri_name=args[i]
            is_live = True
        if not source_bin:
        if not sinkpad:
        if not srcpad:
    nvdslogger = None
    else:
    if not pgie:
    if disable_probe:
    if not tiler:
    if not nvvidconv:
    if not nvosd:
    if file_loop:
        if platform_info.is_integrated_gpu():
        else:
    if no_display:
    else:
            if not sink:
        else:
            if not sink:
    if not sink:
    if is_live:
    else:
    pipeline.add(pgie)
    if nvdslogger:
    pipeline.add(tiler)
    pipeline.add(nvosd)
    pipeline.add(sink)
    queue1.link(pgie)
    pgie.link(queue2)
    if nvdslogger:
    else:
        queue2.link(tiler)
    tiler.link(queue3)
    queue4.link(nvosd)
    nvosd.link(queue5)
    queue5.link(sink)
    else:
    # List the sources
        timer_id = GLib.timeout_add_seconds(10, start_sr_function, uribin)
    try:
        loop.run()
    except:
        pass
    # cleanup
def parse_args():
        "-i",
        "--input",
        nargs="+",
        metavar="URIs",
        default=["a"],
        required=True,
        "-c",
        "--configfile",
        default=None,
        "-g",
        "--pgie",
        default=None,
        "--no-display",
        default=True,
        dest='no_display',
        "--file-loop",
        default=False,
        dest='file_loop',
        "--disable-probe",
        default=False,
        "-s",
        "--silent",
        default=False,
        dest='silent',
        sys.exit(1)
    pgie = args.pgie
    global no_display
    global silent
    global file_loop
    no_display = True
    silent = True
    file_loop = True
        parser.print_help()
        sys.exit(1)
    if config:
            sys.exit(1)
    print(vars(args))
I tested it using the following command
python3 test3-sr.py -i rtsp://xxxx/media/video1 rtsp://xxxx/media/video2 --no-display
I use top to monitor RES usage,There is no significant increase in memory
Here is the result.
log.log (1.8 MB)
Thanks for the above code!!
Based on the code you provided, I modified code in following places.
  1. After record_done() signal, Iam just deleting the recorded videos.
  2. Modified following piece of code
timer_ids = {}
for i, uribin in enumerate(list_for_nvurisrcbin):
    timer_id_name = f"timer_id_{i}"
    timer_ids[timer_id_name] = GLib.timeout_add_seconds(10, start_sr_function, uribin)
All RTSP are H265 encoded.
But still Iam facing memory leak issues. I am attaching the code and docker stats memory graph below. please have a look and let me know something is wrong.
import sys
import gi
import configparser
import argparse
import time
import sys
import math
import platform
import pyds
import os
import ctypes
no_display = False
silent = False
file_loop = False
perf_data = None
MAX_DISPLAY_LEN=64
OSD_PROCESS_MODE= 0
OSD_DISPLAY_TEXT= 1
    _fields_ = [
    frame_number=0
    num_rects=0
    got_fps = False
    if not gst_buffer:
        return
        try:
            # it alone.
            break
        obj_counter = {
            try:
                break
            try:
                l_obj=l_obj.next
                break
        if not silent:
        global perf_data
        try:
            break
    if not caps:
    source_bin=data
    # audio.
        else:
    # pipeline
    print(bin_name)
    if not nbin:
    if not file_loop:
    else:
    dir = f"/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test3/videos"
    uri_decode_bin.set_property("smart-rec-dir-path", dir)
    # src pad.
    if not bin_pad:
        return None
    return nbin
    return True
    try:
        latest_mp4=[f for f in os.listdir("/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test3/videos") if f.endswith(".mp4") and f.startswith("Smart_Record")]
        directory = f"/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test3/videos"
        #latest_mp4.sort(key=lambda x: os.path.getctime(x))
        if not os.path.exists(directory):
            print(f"Directory {directory} does not exist.")
        else:
            if not latest_mp4:
                print("No .mp4 file found.....")
            else:
                for file in latest_mp4:
                    file_path = os.path.join(directory, file)
                    try:
                        os.remove(file_path)
                        print(f"Deleted file: {file_path}")
                    except OSError as e:
                        print(f"Error deleting file {file_path}: {e}")
    except:
        print("CANTTTTTTTTTTTTTTTTTTTTTTTTTTTTT deleteeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee")
    global perf_data
    Gst.init(None)
    is_live = False
    if not pipeline:
    if not streammux:
        uri_name=args[i]
            is_live = True
        if not source_bin:
        if not sinkpad:
        if not srcpad:
    nvdslogger = None
    else:
    if not pgie:
    if disable_probe:
    if not tiler:
    if not nvvidconv:
    if not nvosd:
    if file_loop:
        else:
    if no_display:
    else:
            if not sink:
        else:
            if not sink:
    if not sink:
    if is_live:
    else:
    pipeline.add(pgie)
    if nvdslogger:
    pipeline.add(tiler)
    pipeline.add(nvosd)
    pipeline.add(sink)
    queue1.link(pgie)
    pgie.link(queue2)
    if nvdslogger:
    else:
        queue2.link(tiler)
    tiler.link(queue3)
    queue4.link(nvosd)
    nvosd.link(queue5)
    queue5.link(sink)
    else:
    # List the sources
    timer_ids = {}
    try:
        loop.run()
    except:
        pass
    # cleanup
def parse_args():
        "-i",
        "--input",
        nargs="+",
        metavar="URIs",
        default=["a"],
        required=True,
        "-c",
        "--configfile",
        default=None,
        "-g",
        "--pgie",
        default=None,
        "--no-display",
        default=True,
        dest='no_display',
        "--file-loop",
        default=False,
        dest='file_loop',
        "--disable-probe",
        default=False,
        "-s",
        "--silent",
        default=False,
        dest='silent',
        sys.exit(1)
    pgie = args.pgie
    global no_display
    global silent
    global file_loop
    no_display = True
    silent = True
    file_loop = True
        parser.print_help()
        sys.exit(1)
    if config:
            sys.exit(1)
    print(vars(args))
Following is the command I used to run above code.
python3 smart_record.py -i rtsp://media/xxxxx rtsp://media/xxxxx rtsp://media/xxxxx rtsp://media/xxxxx rtsp://media/xxxxx rtsp://media/xxxxx rtsp://media/xxxxx rtsp://media/xxxxx rtsp://media/xxxxx  -c /opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/deepstream-test3/dstest3_pgie_config.txt  -g nvinfer
In the below graph, for sometime it is good and then in the middle it is throwing below error and I am thinking because of the below error, sudden increment in leak.
libv4l2: error getting capabilities: Invalid argument
Failed to query video capabilities: Invalid argument
./log_docker_stats.sh
TegraV4L2_Open for ENCODER failed: Success
Following is the graph
@junshengy
These errors are not important and can be ignored.
Are you using Jetson? What are your Jetpack and DeepStream versions?
Can you upgrade to JP-6.1 and DS-7.1? I tested the above results on AGX Orin.
How do you count memory usage? I can’t reproduce this problem
**• Hardware Platform --------> L4
**• DeepStream Version ---------> 7.0
• TensorRT Version -----------> 8.5
**• NVIDIA GPU Driver Version -----> 550.67
Memory profiling without smart recording code is always a straight line which means no leak at all.
But, I shared you the graphs with smart recording code, there you can see how fast memory is increasing
How do you count memory usage? Is it the video memory? I ran the above program with dGPU and found no memory leaks
with how many streams you are running this??
I used two h265 test streams and tested it for almost 10 hours.
With two streams, we are also getting the same results like yours.
But the moment, we run 80 streams for 6 hours and below is the graph.
Can you please run it with 80 streams and let me know please.
Please tell me how to count memory usage, Is it physical memory, virtual memory, or video memory?
The picture above is two h265 streams with a resolution of 1280x720, which takes up 550M.
DS-7.0 depends on TRT 8.6.1.6, try to upgrade the correct version
When you use docker stats, the memory usage it shows is physical memory, which is the actual RAM used by the Docker container. It does not include video memory or virtual memory as part of its measurement.
I am using nvidia deepstream 7.0 docker image , which having “TRT 8.6.1.6” as default.
With 60 streams, we can able to achieve the same results in the below graph.
Based on above graph, Memory difference for every hour (in GiB) pasted below:
timestamp memory_increase
2024-11-07 11:00:00 11.106 GB
2024-11-07 12:00:00 18.400 GB
2024-11-07 13:00:00 4.970 GB
2024-11-07 14:00:00 2.140 GB
2024-11-07 15:00:00 2.090 GB
2024-11-07 16:00:00 1.580 GB
2024-11-07 17:00:00 1.020 GB
2024-11-07 18:00:00 1.370 GB
2024-11-07 19:00:00 0.640 GB
2024-11-07 20:00:00 0.460 GB
2024-11-07 21:00:00 0.480 GB
2024-11-07 22:00:00 -0.050 GB
2024-11-07 23:00:00 0.310 GB
2024-11-08 00:00:00 0.130 GB
2024-11-08 01:00:00 0.370 GB
2024-11-08 02:00:00 0.340 GB
2024-11-08 03:00:00 0.070 GB
2024-11-08 04:00:00 0.210 GB
2024-11-08 05:00:00 0.390 GB
2024-11-08 06:00:00 0.220 GB
2024-11-08 07:00:00 0.050 GB
2024-11-08 08:00:00 0.370 GB
2024-11-08 09:00:00 0.170 GB
2024-11-08 10:00:00 0.160 GB
2024-11-08 11:00:00 0.240 GB
2024-11-08 12:00:00 0.080 GB
2024-11-08 13:00:00 0.030 GB
2024-11-08 14:00:00 0.130 GB
  1. why is it increasing rapidly in the beginning of the graph and after 12 hours, I am still getting a leak of around 100MB per hour? Can you please look why is it happening?
Below is the latest memory graph after running 60 streams for 3 days
Use the following command to detect the location of the memory leak
# install valgrind in DS-7.0/1 container
apt install valgrind
PYTHONMALLOC=malloc valgrind --tool=memcheck --leak-check=full --show-leak-kinds=all --suppressions=/usr/lib/valgrind/python3.supp python3 test-sr.py -i rtsp://xxx rtsp://xxxxx > leak.log 2>&1
When the program exits, the unreleased memory will be output to leak.log, which can be used to find the location of the leak.
Using valgrind to detect memory leak will make the program very slow, but this is not a problem
This command throwing below error and stopping immediately.
Can you tell us the issue??
Valgrind will hook malloc, which may cause instability. Try to reduce the input source. I tried to input two sources and it worked.
I tried with single source and still the same. Any other solutions?
1.I don’t know what happened. I’m using DS-7.1container and driver version 550.127.05, try the DS-7.1 container
2.Try using native code first to make sure the smart recording feature has no memory leaks. pyds is just a binding for native code.
Use the following sample to detect memory leak.
/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-testsr
valgrind --tool=memcheck --leak-check=full --show-leak-kinds=all ./deepstream-testsr-app rtsp://xxx > leak2.log 2>&1
