I have compiled and run the deepstream_test3_app successfully two or three times, but out of nothing, I am facing the following error:
0:00:02.541635659 2228 0x7f4d28004890 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]:log(): TensorRT was compiled against cuBLAS 10.1.0 but is linked against cuBLAS 10.2.0. This mismatch may potentially cause undefined behavior.
Decodebin child added: source
Decodebin child added: decodebin0
Running...
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
Seting bufapi_version
(videotest:2228): GLib-GObject-WARNING **: 08:06:32.687: g_object_set_is_valid_property: object class 'nvv4l2decoder' has no property named 'bufapi-version'
(videotest:2228): GStreamer-CRITICAL **: 08:06:32.688: gst_value_set_fraction: assertion 'denominator != 0' failed
In cb_newpad
in videoconvert caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)30/1, batch-size=(int)1, num-surfaces-per-frame=(int)1, format=(string)RGBA
Creating LL OSD context new
0:00:02.942199078 2228 0x7f4d203eb230 WARN nvinfer gstnvinfer.cpp:1815:gst_nvinfer_output_loop:<primary-nvinference-engine> error: Internal data stream error.
0:00:02.942221803 2228 0x7f4d203eb230 WARN nvinfer gstnvinfer.cpp:1815:gst_nvinfer_output_loop:<primary-nvinference-engine> error: streaming stopped, reason error (-5)
Is that because of the TensorRT linkage? I wonder why ânvv4l2decoderâ would not have âbufapi-versionâ
