Deepstream-test3 running direct Secondary_Detector
**• Hardware Platform (Jetson / GPU)**GPU
• DeepStream Version6.0
• TensorRT Version8.0
**• NVIDIA GPU Driver Version (valid for GPU only)**470
**• Hii ,
I want run direct Secodary (classificaion model) in deepstream test3 sample.
Is possible ?
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
Thanks for reply ,
But The issue has not been resolved
Can you share your use case or what kind of pipeline do you want to run? So we can suggest the sample which satisfier your requirement.
Basically I want to run my classification model in deepstream sample app with out run object detection primary model.
In the deeps-tram sample 3 app get the first object coordinate than find the color detection .In my use case I am run classification color detection model without getting object detection meta data (coordinate)
So can you make one object meta with the whole video frame and attach the meta data to the buffer?
yes can see the below code
deepstream_test_2.py (20.3 KB)
you can see line number 79 to 85
