Deepstream VRAM Scaling?
• Hardware Platform (Jetson / GPU) 1 X RX8000
• DeepStream Version v5.0.1
• JetPack Version (valid for Jetson only) N/A
• TensorRT Version N/A
• NVIDIA GPU Driver Version (valid for GPU only) 470.57.02
• Issue Type( questions, new requirements, bugs) Question
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) N/A
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) N/A
I’m processing multiple RTSP streams at edge at 1080@15fps. I’m trying to compute scaling requirements for adding additional streams, and wanted to understand GStreamer’s impact on VRAM. Right now I’m seeing 12GB / 48 GB of FB VRAM in use for 60 streams. My question is can I roughly assume 12 GB / 60 streams requires .2 GB VRAM per stream to process?
My pipeline is currently uridecode (nvdec) → nvmstreamux → nvvideoconvert → capsfilter → nvmultistreamtiler.
From what I understand all but the capsfilter would be leveraging the VRAM.
Hi @dan.mccormack , You can roughly calculate how much storage you need with the video raw data. Like 1080P 8bit RGB video, the number is (1920x1080x8x3) bit.
