• Hardware Platform (Jetson / GPU) H100
• DeepStream Version 7.0
• TensorRT Version
Hi, I would like to ask
- Can i use deepstream to run on 2 different GPUs? For example, I would like my decoding, streammux to be done on GPUID 0 and inference to be done on GPUID 1.
- Lets say I am decoding 1 stream @25fps and it uses 500MB of VRAM, if I am reading the stream @1fps, will the VRAM drop? Assuming 1fps is set from my camera source, not dropping frames within Deepstream
