Trying to build a DeepStream-based application for a multi-camera setup (70) and need advice how to set up deep stream
GPU two 4090 Gpus on two ubunto 22 PCs
• DeepStream Version
7.1
• TensorRT Version
I have 70 cameras and 2 gpus how can i connect them and how to setup deepstream
What does this mean? You have two separated PCs, each has a RTX 4090 GPU installed?
What kind of cameras? CSI, USB, IP camera,…?
yes two pc each with a RTX 4090 GPU
the camera types work with RSTP
For the two separated PCs, you can run DeepStream pipeline in each separately.
Since your cameras are RTSP IP cameras, the hardware video decoder will be used. From the hardware video decoding point, the Geforce RTX 4090 supports 23 1080p@30FPS h264 streams or 44 1080p@30fps H265 streams. So it may be possible for you to support 35 1080p@30FPS H265 coding RTSP video strteams with each RTX 4090 PC.
