How to run inference using multiGPU
• Hardware Platform (Jetson / GPU) H100
• DeepStream Version 6.4
• TensorRT Version
Hi, I would like to know are there any samples to reference for running inference using multiGPU. For example, I have 24 CCTVs, 8 GPUs for my server and I want to assign 3 CCTVs running for each of the GPU in one application. I have tried changing the config files, under the property, there is a gpu-id parameter, but the documentation stated only integer is accepted. Besides, I know that i can start 8 applications for each GPUs, but is there a way to assign running at multiGPU in one application
Do you mean to run 24 cameras with the same model while you want the cameras been assigned to different GPUs?
What kind of cameras are they? CSI cameras, RTSP IP cameras, USB cameras,…?
How many models in your pipeline? How do you want to run your models?
How will you output the inferencing result? Display, file saving, message broker,…?
Yes, i want each GPU to handle some portion of CCTVs only
Its RTSP camera
I have 3 models running in my pipeline now, i am able to run my application for 30 CCTVs for one single GPU. And if I add another 30 CCTVs, I want it to use the second GPU
I am using message broker
So the GPU can be used for video decoding with the RTSP sources and the model inferencing(including preprocessing and postprocessing).
Every GPU has the video decoding and model inferencing capabilities. But one video can only be decoded in one GPU while one model can only run on one GPU in one process.
You need to decide which video should run in which GPU, and which model should run on which GPU. Then you can configure the corresponding element correctly.
So meaning that I can only run 3 models at one GPU only, or I can choose 3 GPUs to run each model and which GPU to decode the RTSP stream. Please correct me if i am wrong
one model can only run in one GPU in one process
So you can run the three models in three different GPUs in one process.
The video decoding GPU can be different to the model inferencing GPU.
Please make sure the nvv4l2decoder “cudadec-memtype” is set to 2. Gst-nvvideo4linux2 — DeepStream documentation 6.4 documentation
“nvbuf-memory-type” of nvstreammux should be 3. Gst-nvstreammux — DeepStream documentation 6.4 documentation
“nvbuf-memory-type” of nvvideoconvert should be 3. Gst-nvvideoconvert — DeepStream documentation 6.4 documentation
Please check every DeepStream element in your pipeline to make sure they are configured correctly.
thanks, my configuration are the exact same one as u mentioned above
