**• Hardware Platform (Jetson / GPU) : None
**• DeepStream Version: 6.0 or later
**• JetPack Version (valid for Jetson only) : None
**• TensorRT Version : None
**• NVIDIA GPU Driver Version (valid for GPU only) : None
**• Issue Type( questions, new requirements, bugs) : Questions
**• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) : None
**• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) : None
Gst-nvdspreprocess can be used for multiple input model?
Or would it only work for models with a single input?
How can I implement a multiple-input model if I can only use Gst-nvdspreprocess for a single-input model? (using Gst-nvdsvideotemplate is the only way?)
