Running on multi-gpus
• Hardware Platform (Jetson / GPU) TITAN RTX/PCIe/SSE2
• DeepStream Version5
• TensorRT Version 7.0.0.11
• NVIDIA GPU Driver Version (valid for GPU only) 440.59
• Issue Type( questions, new requirements, bugs) questions
Hello;
I have 4 gpus with ids 0-3. I want to run deep-stream on them all. I am using one of the sample config files with name source30_1080p_dec_infer-resnet_tiled_display_int8.txt
I can copy this file 4 times and in each file change the utilized gpu-id. But I want to know if there is a more elegant way to achieve that.
I tried to change the gpu-id inside each [source] but it didn’t work.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=5
columns=6
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://…/…/streams/sample_1080p_h264.mp4
num-sources=15
#drop-frame-interval=2
gpu-id=0
cudadec-memtype=0
[source1]
enable=1
type=3
num-sources=15
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=30
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
model-engine-file=…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=30
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tests]
file-loop=0
Sorry for a late reply,
not quite follow what you mean, did you mean you want to run each stream on each GPU? let’s say, you have 4 GPUs, so you want each stream running on each GPU?
Yes I have say 16 streams and I want to divide them between the 4 gpus I have. Can I do that with one configuration file?. I was able to do that with 4 configuration files as I described above.
How about your output for the 16 streams? it would be better you can provide the configuration for a clear vision.
