I am using dGPU and deepstream v4.0
Whenever I make changes to configuration , everytime I get different FPS performace
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: 9.61 (9.61) 7.66 (7.66) 10.05 (10.05) 6.70 (6.70)
**PERF: 0.00 (9.61) 0.00 (7.66) 0.00 (10.05) 0.00 (6.70)
My configuration :
# Copyright (c) 2018 NVIDIA Corporation. All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=10
#gie-kitti-output-dir=../../../kitti/
kitti-track-output-dir=../../../kitti_track/
[tiled-display]
enable=0
rows=1
columns=1
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
#uri=file://../../../streams/sample_1080p_h264.mp4
#uri=file://../../../../../harshit_sample/harshit_sample_vantagedorm_1.mp4
uri=rtsp://admin:@192.168.1.10:554/mode=real&idc=1&ids=1
num-sources=1
gpu-id=0
camera-id=0
#drop-frame-interval=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=4
uri=rtsp://admin:@192.168.1.12:554/mode=real&idc=1&ids=1
num-sources=1
gpu-id=0
camera-id=1
cudadec-memtype=0
[source2]
enable=1
type=4
num-sources=1
gpu-id=0
camera-id=2
cudadec-memtype=0
[source3]
enable=1
type=4
num-sources=1
gpu-id=0
camera-id=3
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=1
sync=0
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
[sink1]
enable=1
type=1
sync=0
source-id=1
gpu-id=0
qos=0
nvbuf-memory-type=0
[sink2]
enable=1
type=1
sync=0
source-id=2
gpu-id=0
qos=0
nvbuf-memory-type=0
[sink3]
enable=1
type=1
sync=0
source-id=3
gpu-id=0
qos=0
nvbuf-memory-type=0
[osd]
enable=0
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=2592
height=1944
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../../models/Primary_Detector/resnet10.caffemodel_b4_int8.engine
batch-size=2
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tracker]
enable=0
tracker-width=640
tracker-height=368
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
ll-config-file=tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=1
[secondary-gie]
enable=0
model-engine-file=../../../models/Secondary_FaceDetect/fd_lpd_model/fd_lpd.caffemodel_b1_fp32.engine
gpu-id=0
batch-size=2
gie-unique-id=4
operate-on-gie-id=1
#operate-on-class-ids=0;
config-file=config_infer_secondary.txt
[ds-example]
enable=1
processing-width=2592
processing-height=1944
full-frame=0
unique-id=15
gpu-id=0
[tests]
file-loop=0
