I dont have access to a display to be able to install ubuntu on Jetson Orin Agx.
I connected the uart cable and I can get access to the console.
What are the default credentials to login?
Jorge
Jorge
It has been several years since there was a default login. California implemented a law regarding such default credentials, so if NVIDIA had kept that method, then they would have had to have stopped selling in California. Instead there is a first boot account setup.
If you had the ancient L4T R28.x or earlier release (L4T is Ubuntu plus NVIDIA drivers…this is what gets flashed, whereas JetPack/SDK Manager is a front end for flashing), then it would be “nvidia
”/“nvidia
” for user/pass.
Your screenshot above though indicates perhaps first boot setup was completed (assuming it is not an ancient L4T release). Normally you would get one of the following:
l4t_create_default_user.sh
on the host PC before flashing to finish this, or:Did you flash the AGX Orin? If so, which release? I think sometimes where the first boot setup occurs might change if you have a monitor during flash or not.
