We decode the interlaced video with mmapi in TX2,and found that the de-interlacing function is problematic, the output image is rough.
This is the source image.
Please share the video file so that we can reproduce it.
Hi, DaneLLL
Thank you for your response.
Please download the video file in this url.
[url]https://pan.baidu.com/s/1Irj6LHU3XmACaqW3EWHYqg[/url]
And run this cmd.
./video_decode deint_test.264 H264 --input-nalu --disable-rendering -o deint_test.yuv
Please also share how to generate source image. Do you use ffmpeg?
Hi, DaneLLL
Play the source file by MPC-HC player ([url]https://mpc-hc.org/[/url]).
Hi zcs, we cannot access this link. Can you give a valid link?
Hi, DaneLLL
Please download it here.
[url]http://120.77.3.207/deint_test.264[/url]
I am not able to run the command on r28.2.1. Is the command correct?
Hi, DaneLLL
We work at r28.1.0.
Hi, DaneLLL
Is there any progress?
Hi zcs,
We are checking. Do you run clean r28.1? I mean a clean image flashed by Jetpack without any prebuilt libraries being replaced.
Hi, DaneLLL
I had tested it on the clean r28.1, and it look correct.
Hi zcs, do you mean you don’t see the issue on clean r28.1?
Hi, DaneLLL
I mean the command running is correct.
But the output image is also rough.
Please try attachment.
r28_1_libtegrav4l2.zip (60.3 KB)
Hi,DaneLLL
Thank you for the patch.
The output image look correct.
But it cause another issue about the timestamp of video encoder.
[url]https://devtalk.nvidia.com/default/topic/1002773/?comment=5267455[/url]
I have updated the attachment at comment #15. Please give it a try.
Hi,DaneLLL
Thank you for the update.
