Delay acumulation with gstreamer and opencv
I’m trying to paint some circles in the image with opencv.
I get the stream with gstreamer and I try to process the image with opencv with the next one:
GstElement* conv=gst_bin_get_by_name(GST_BIN(gst_pipeline), “myconv”);
GstPad *src_pad=gst_element_get_static_pad (conv, “src”);
gst_pad_add_probe(src_pad, GST_PAD_PROBE_TYPE_BUGFFER, frame_processing, NULL,NULL);
In the frame_processing function I have something like:
static GstPadProbeReturn frame_processing (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
GstBuffer *buffer=(GstBuffer *) info->data;
GstMapInfo map={0};
int dmabuf_fd=0;
gst_buffer_map (buffer, &map, GST_MAP_READ);
ExtractFdFromNvBuffer((void *)map.data, &dmabuf_fd);
EGLImageKHR egl_image;
egl_image=NvEGLImageFromFd(egl_display, dmabuf_fd);
CUresult status;
CUeglFrame egl_frame;
CUgraphicsResource p_resource=NULL;
cudaFree(0);
status=cuGraphicsEGLRegisterImage(&p_resource, egl_image, CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE);
status=cuGraphicsResourceGetMappedEglFrame(&egl_frame, p_resource, 0, 0);
status=cuCtxSynchronize();
cv::cuda::GpuMat d_mat(H, W, CV_8UC4, egl_frame.frame.pPitch[0]);
cv::Mat img;
d_mat.download(img);
circle(img, cv::Point(500,500), 300, cv::Scalar(0,255,0),-1);
d_mat.upload(img);
status=cuGraphicsUnregisterResource(p_resource);
gst_buffer_unmap(buffer, &map);
return GST_PAD_PROBE_OK;
When I try to make something like this, I see how the video slows down and accumulate a lot of delay, I think the reason is the computing cost to transform the cuda mat to opencv mat, because if I remove that, the video works fine.
Anyone knows any solution to that?
Thanks in advance.
Looks like the circle() function executes on CPU buffers. You may try to get cv::Mat instead of cv::cuda::GpuMat. Please refer to
and run sudo nvpmodel-m 0 and sudo jetson_clocks to get max CPU performance.
cv::cuda::GpuMat is better if you use cuda filter function calls.
Sorry for the delay in respondering, but I can’t work with that before.
I tried putting the nvpmodel-m0 and sudo jetson_clocks but I get the same results.
On the other hand, I have checked how many frames I get by second and I see that I have ~36 so I should see the video well and smooth, but I keep seeing how the video is continuously slow down and accumulating delay.
Maybe the problem is in the pipelines? I’m feel very lost with that problem.
If your source is a video file, you may try this simple code:
It is RTSP source. For video file source, it should work by replace rtspsrc ! rtph264depay with filesrc. You may check if you observe the same accumulation in running it.
My video must come from a rtsp source, I can’t change that.
There is a way to make that don’t accumulate delay?
We have seen performance issues if there are heavy operations in prob functions. A similar topic:
Is it possible to link to appsink plugin and use OpenCV functions in it?
