Hi:
Im working on a Jetson TX2 with Ubuntu, my OpenCV version is 3.4.2 with Gstreamer support. I make a script in python an access the on-board camera with Gstreamer. The FPS I get when I run the app are as expected, but I have a 1-2 seconds of dealy. I think this is because of my gstreamer pipeline but Im not sure if it can be done in a better way. An extract of the code is:
The OpenCV camera frame buffer size is 10. It is hard-coded into OpenCV source code.
Your code, cv2.imshow() is 10 FPS.
Therefore, the latest frame will be displayed after 10 frames, that is, 1 second later.
terminate called after throwing an instance of 'cv::Exception'
what(): OpenCV(3.4.2) /home/nvidia/opencv/modules/imgproc/src/resize.cpp:4083: error: (-215:Assertion failed) src.type() == dst.type() in function 'cvResize'
Aborted (core dumped)
Should I make a transformation of the image format inside my code once I got a frame?
PD: I was able to reduce the delay to less than 1 second adding this in the end of my original pipeline:
drop=true sync=false
Thanks for the help. I will try to test the naisy solutions later.
I try with your second soltion, and I added this to my code:
cap = cv2.VideoCapture('nvcamerasrc ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)I420, framerate=(fraction)120/1 ! nvvidconv ! video/x-raw, width=(int)1280, height=(int)720, format=(string)BGRx ! videoconvert ! appsink drop=true sync=false')
if cap.set(cv2.CAP_PROP_BUFFERSIZE, 1):
print("Buffer size changed")
else:
print("Can not change the buffer size")
The if statement is spouse to return true if it changes. But it is returning false and I dont know why. Any clue?
I have tried to modify the opencv source code as you suggest in the third option. I didnt appreciate an improvement. Do I have to do a simple make after changing the code or a make clean and then make?
Since I may process camera frames with UDP streaming, it may occur for more than 10 seconds delay.
Therefore, I’m using background processing to solve the delay problem.
I prepared a simple code. Try this.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import cv2
import threading
class WebcamVideoStream:
Reference:
https://www.pyimagesearch.com/2015/12/21/increasing-webcam-fps-with-python-and-opencv/
def __init__(self):
self.vid = None
self.running = False
return
def __del__(self):
if self.vid.isOpened():
self.vid.release()
return
def start(self, src, width=None, height=None):
# initialize the video camera stream and read the first frame
self.vid = cv2.VideoCapture(src)
if not self.vid.isOpened():
# camera failed
raise IOError(("Couldn't open video file or webcam."))
if width is not None and height is not None:
self.vid.set(cv2.CAP_PROP_FRAME_WIDTH, width)
self.vid.set(cv2.CAP_PROP_FRAME_HEIGHT, height)
self.ret, self.frame = self.vid.read()
if not self.ret:
self.vid.release()
raise IOError(("Couldn't open video frame."))
# initialize the variable used to indicate if the thread should
# check camera vid shape
self.real_width = int(self.vid.get(3))
self.real_height = int(self.vid.get(4))
print("Start video stream with shape: {},{}".format(self.real_width, self.real_height))
self.running = True
# start the thread to read frames from the video stream
t = threading.Thread(target=self.update, args=())
t.setDaemon(True)
t.start()
return self
def update(self):
try:
# keep looping infinitely until the stream is closed
while self.running:
# otherwise, read the next frame from the stream
except:
import traceback
traceback.print_exc()
finally:
# if the thread indicator variable is set, stop the thread
self.vid.release()
return
def read(self):
# return the frame most recently read
return self.frame
def stop(self):
self.vid.release()
return
def main():
print(cv2.__version__)
input_src = "nvcamerasrc ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)I420, framerate=(fraction)120/1 ! nvvidconv ! video/x-raw, width=(int)1280, height=(int)720, format=(string)BGRx ! videoconvert ! appsink"
video_reader = WebcamVideoStream()
video_reader.start(input_src)
try:
while video_reader.running:
frame = video_reader.read()
cv2.imshow('video', frame)
if cv2.waitKey(1) & 0xFF == 27: # ESC key: quit program
break
finally:
video_reader.stop()
if __name__ == '__main__':
main()
But the delay was huge like in the beginning. Then I added this parameters to the new pipeline:
format=I420 ! appsink drop=true sync=false
The huge delay disappears. Why is this happening? What are these two parameters doing? And why I cant appreciate an improvement of the performance just by avoiding the ‘videoconvert’ bottleneck?
I will try the code of naisy later, thanks all for the help.
