I think you are measuring 2 things: waiting for frame and reading it. If running at 60 fps, you cannot expect a new frame less than 16 ms after previous one.
Consider the following code with your measurement:
#include <iostream>
#include <opencv2/opencv.hpp>
#include <opencv2/videoio.hpp>
#include <opencv2/highgui.hpp>
int main()
const char* gst = "nvcamerasrc ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)I420, framerate=(fraction)120/1 ! \
nvvidconv flip-method=6 ! video/x-raw, format=(string)BGRx ! \
videoconvert ! video/x-raw, format=(string)BGR ! \
appsink";
cv::VideoCapture cap(gst);
if(!cap.isOpened())
std::cout<<"Failed to open camera."<<std::endl;
return -1;
unsigned int width = cap.get(CV_CAP_PROP_FRAME_WIDTH);
unsigned int height = cap.get(CV_CAP_PROP_FRAME_HEIGHT);
unsigned int pixels = width*height;
std::cout <<"Frame size : "<<width<<" x "<<height<<", "<<pixels<<" Pixels "<<std::endl;
//cv::namedWindow("MyCameraPreview", CV_WINDOW_AUTOSIZE);
cv::Mat frame_in(width, height, CV_8UC3);
clock_t t1;
while(1)
t1 = clock();
if (!cap.read(frame_in)) {
std::cout<<"Capture read error"<<std::endl;
break;
else {
t1 = clock() - t1;
std::cout << "it takes " << (((float)t1)/CLOCKS_PER_SEC)*1000 << " ms to capture a frame. The capture rate can reach " << 1/(((float)t1)/CLOCKS_PER_SEC) \
<< " FPS" << std::endl;
//cv::imshow("MyCameraPreview",frame_in);
cv::waitKey(1000/120); // let imshow draw and wait for 8 ms for 120 fps
cap.release();
return 0;
If you decrease the 8 ms wait, you will see your measurements showing increasing read times, while in fact it’s just waiting.
Boosting my TX2 with
sudo nvpmodel -m0
sudo /home/ubuntu/jetson_clocks.sh
it gives:
Available Sensor modes :
2592 x 1944 FR=30.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
2592 x 1458 FR=30.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
1280 x 720 FR=120.000000 CF=0x1109208a10 SensorModeType=4 CSIPixelBitDepth=10 DynPixelBitDepth=10
NvCameraSrc: Trying To Set Default Camera Resolution. Selected 1280x720 FrameRate = 120.000000 ...
Frame size : 1280 x 720, 921600 Pixels
it takes 4.586 ms to capture a frame. The capture rate can reach 218.055 FPS
it takes 5.688 ms to capture a frame. The capture rate can reach 175.809 FPS
it takes 7.229 ms to capture a frame. The capture rate can reach 138.332 FPS
it takes 1.721 ms to capture a frame. The capture rate can reach 581.058 FPS
it takes 1.149 ms to capture a frame. The capture rate can reach 870.322 FPS
it takes 1.182 ms to capture a frame. The capture rate can reach 846.024 FPS
it takes 2.264 ms to capture a frame. The capture rate can reach 441.696 FPS
it takes 2.165 ms to capture a frame. The capture rate can reach 461.894 FPS
it takes 1.166 ms to capture a frame. The capture rate can reach 857.633 FPS
it takes 1 ms to capture a frame. The capture rate can reach 1000 FPS
it takes 2.465 ms to capture a frame. The capture rate can reach 405.68 FPS
it takes 2.104 ms to capture a frame. The capture rate can reach 475.285 FPS
it takes 1.485 ms to capture a frame. The capture rate can reach 673.401 FPS
it takes 0.909 ms to capture a frame. The capture rate can reach 1100.11 FPS
it takes 2.123 ms to capture a frame. The capture rate can reach 471.032 FPS
it takes 1.528 ms to capture a frame. The capture rate can reach 654.45 FPS
it takes 0.699 ms to capture a frame. The capture rate can reach 1430.62 FPS
it takes 0.738 ms to capture a frame. The capture rate can reach 1355.01 FPS
it takes 1.088 ms to capture a frame. The capture rate can reach 919.118 FPS
it takes 2.554 ms to capture a frame. The capture rate can reach 391.543 FPS
it takes 1.764 ms to capture a frame. The capture rate can reach 566.893 FPS
it takes 1.446 ms to capture a frame. The capture rate can reach 691.563 FPS
it takes 1.058 ms to capture a frame. The capture rate can reach 945.18 FPS
it takes 2.449 ms to capture a frame. The capture rate can reach 408.33 FPS
it takes 2.04 ms to capture a frame. The capture rate can reach 490.196 FPS
it takes 1.849 ms to capture a frame. The capture rate can reach 540.833 FPS
it takes 0.802 ms to capture a frame. The capture rate can reach 1246.88 FPS
it takes 2.245 ms to capture a frame. The capture rate can reach 445.434 FPS
For your use case, this pipeline
const char* gst = "nvcamerasrc ! video/x-raw(memory:NVMM), width=(int)2592, height=(int)1458, format=(string)I420, framerate=(fraction)60/1 ! \
nvvidconv flip-method=6 ! video/x-raw, width=(int)1920, height=(int)1080, format=(string)BGRx ! \
appsink";
with a timeout of 16ms gives:
NvCameraSrc: Trying To Set Default Camera Resolution. Selected 2592x1458 FrameRate = 60.000000 ...
Frame size : 1920 x 1080, 2073600 Pixels
it takes 4.065 ms to capture a frame. The capture rate can reach 246.002 FPS
it takes 15.032 ms to capture a frame. The capture rate can reach 66.5247 FPS
it takes 14.558 ms to capture a frame. The capture rate can reach 68.6908 FPS
it takes 11.892 ms to capture a frame. The capture rate can reach 84.0901 FPS
it takes 12.732 ms to capture a frame. The capture rate can reach 78.5423 FPS
it takes 12.526 ms to capture a frame. The capture rate can reach 79.8339 FPS
it takes 12.699 ms to capture a frame. The capture rate can reach 78.7464 FPS
it takes 12.571 ms to capture a frame. The capture rate can reach 79.5482 FPS
it takes 12.51 ms to capture a frame. The capture rate can reach 79.9361 FPS
it takes 12.235 ms to capture a frame. The capture rate can reach 81.7327 FPS
it takes 12.508 ms to capture a frame. The capture rate can reach 79.9488 FPS
it takes 12.376 ms to capture a frame. The capture rate can reach 80.8016 FPS
it takes 12.233 ms to capture a frame. The capture rate can reach 81.7461 FPS
it takes 12.321 ms to capture a frame. The capture rate can reach 81.1622 FPS
it takes 12.113 ms to capture a frame. The capture rate can reach 82.5559 FPS
it takes 12.101 ms to capture a frame. The capture rate can reach 82.6378 FPS
it takes 12.176 ms to capture a frame. The capture rate can reach 82.1288 FPS
it takes 12.119 ms to capture a frame. The capture rate can reach 82.5151 FPS
it takes 12.674 ms to capture a frame. The capture rate can reach 78.9017 FPS
it takes 12.561 ms to capture a frame. The capture rate can reach 79.6115 FPS
it takes 12.626 ms to capture a frame. The capture rate can reach 79.2017 FPS
it takes 12.661 ms to capture a frame. The capture rate can reach 78.9827 FPS
it takes 12.796 ms to capture a frame. The capture rate can reach 78.1494 FPS
it takes 12.994 ms to capture a frame. The capture rate can reach 76.9586 FPS
it takes 12.702 ms to capture a frame. The capture rate can reach 78.7278 FPS
it takes 12.791 ms to capture a frame. The capture rate can reach 78.18 FPS
it takes 12.421 ms to capture a frame. The capture rate can reach 80.5088 FPS
it takes 12.451 ms to capture a frame. The capture rate can reach 80.3148 FPS
it takes 12.337 ms to capture a frame. The capture rate can reach 81.057 FPS
it takes 12.054 ms to capture a frame. The capture rate can reach 82.96 FPS
it takes 12.014 ms to capture a frame. The capture rate can reach 83.2362 FPS
it takes 12.063 ms to capture a frame. The capture rate can reach 82.8981 FPS
it takes 12.085 ms to capture a frame. The capture rate can reach 82.7472 FPS
it takes 12.082 ms to capture a frame. The capture rate can reach 82.7678 FPS
it takes 12.069 ms to capture a frame. The capture rate can reach 82.8569 FPS
it takes 12.052 ms to capture a frame. The capture rate can reach 82.9738 FPS
This is quite confirming your findings, but I’m unsure about what these results mean as the timeout seems to have no effect with this mode.
