Description
Depthwise conv3d is 4.7ms while normal conv3d is 3.3ms.
Environment
TensorRT Version: 8.6.1
GPU Type: RTX 4000
Nvidia Driver Version: 525
CUDA Version: 11.8
CUDNN Version: 8.6
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Steps To Reproduce
Run the code below to get the speed for normal conv3d 3.3ms:
import tensorrt as trt
import numpy as np
import os
import pycuda.driver as cuda
import pycuda.autoinit
DEPTHWISE = False
N = 1
IC = 64
D = 15
H = 75
W = 315
OC = 64
KD = 3
KH = 3
KW = 3
INPUT_SHAPE = (N, IC, D, H, W)
INPUT_SIZE = N * IC * D * H * W
OUTPUT_SHAPE = (N, OC, D, H, W)
OUTPUT_SIZE = N * OC * D * H * W
KERNEL_SHAPE = (OC, 1, KD, KH, KW) if DEPTHWISE else (OC, IC, KD, KH, KW)
EXPLICIT_BATCH = 1 << (int)(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
ALLOWED_FORMAT = (1 << int(trt.TensorFormat.LINEAR)) | (
1 << int(trt.TensorFormat.CDHW32)) | (1 << int(trt.TensorFormat.DHWC8))
trt_logger = trt.Logger(trt.Logger.VERBOSE)
builder = trt.Builder(trt_logger)
network = builder.create_network(EXPLICIT_BATCH)
input = network.add_input(name="input", shape=INPUT_SHAPE, dtype=trt.float16)
input.allowed_formats = ALLOWED_FORMAT
conv3d = network.add_convolution_nd(
input, OC, [KD, KH, KW], np.ones(KERNEL_SHAPE, dtype=np.float16))
conv3d.padding_nd = (1, 1, 1)
conv3d.stride_nd = (1, 1, 1)
if DEPTHWISE:
conv3d.num_groups = IC
output = conv3d.get_output(0)
output.name = "output"
output.dtype = trt.DataType.HALF # required
output.allowed_formats = ALLOWED_FORMAT
network.mark_output(output)
assert output.shape == OUTPUT_SHAPE
config = builder.create_builder_config()
config.set_flag(trt.BuilderFlag.FP16)
config.set_flag(trt.BuilderFlag.DIRECT_IO)
config.profiling_verbosity = trt.ProfilingVerbosity.VERBOSE
TIMING_CACHE_FILE = "/tmp/trt_conv3d.timing_cache"
if os.path.exists(TIMING_CACHE_FILE):
with open(TIMING_CACHE_FILE, "rb") as f:
timing_cache = config.create_timing_cache(f.read())
config.set_timing_cache(timing_cache, ignore_mismatch=False)
else:
timing_cache = config.create_timing_cache(b"")
timing_cache = config.get_timing_cache()
with timing_cache.serialize() as buffer:
with open(TIMING_CACHE_FILE, "wb") as f:
f.write(buffer)
context = engine.create_execution_context()
names = [_ for _ in engine]
input_names = list(filter(engine.binding_is_input, names))
output_names = list(set(names) - set(input_names))
num_bindings = len(input_names) + len(output_names)
bindings = [None] * num_bindings
inputs = {}
for name in input_names:
input_idx = engine.get_binding_index(name)
inputs[name] = cuda.mem_alloc(INPUT_SIZE * 2)
bindings[input_idx] = int(inputs[name])
outputs = {}
for name in output_names:
output_idx = engine.get_binding_index(name)
outputs[name] = cuda.mem_alloc(OUTPUT_SIZE * 2)
bindings[output_idx] = int(outputs[name])
stream = cuda.Stream()
# warm up
context.execute_async_v2(bindings, stream.handle)
start, end = cuda.Event(), cuda.Event()
start.record()
end.record()
end.synchronize()
ms = start.time_till(end)
print("Time Elapsed", ms)
stream.synchronize()
print("DONE")
Then change DEPTHWISE = False to DEPTHWISE = True and rerun, get depthwise conv3d 4.7ms.
