Derived types not working correctly with "!$acc parallel" and Unified Memory
I have been trying to use unified memory in a code that utilizes derived types. I have found an issue when I try to utilize managed memory with “!$acc parallel” and have no data directives. Code 1, has no data movement directives and compiles fine, but once the program is run there is an error where name v cannot be found on device. In Code 2, I add in “!$acc enter data create(v)” and “!$acc exit data delete(v)” and then the code runs correctly. If I convert the “!$acc parallel” loops in Code 1 to DO CONCURRENT (code 3), then the code compiles and runs correctly and the two data directives are no longer needed. It seems that “!$acc parallel” is not working correctly with unified memory.
Code 1 compiled with “mpif90 -O3 -march=native -acc=gpu -gpu=cc60,cc70,cc80,managed test.f”
c#######################################################################
c
c ****** PSI_MULTIGPU_TEST_CODE
c
c     This code mimics the basic MPI+OpenACC tasks of PSI's
c     MAS Solar MHD code.
c
c     It sets up a Cartesian MPI topology, sets up a 3D grid
c     and tests a "seam" (point to point) MPI communication
c     using asyncronous Send and Recv calls, which use
c     OpenACC's 'host_data' to use CUDA-aware MPI.
c     This is used both on a allocatable sub-array, as well as
c     on a local buffer static array.
c
c     The code will automatically configure the topology based on
c     the number of MPI ranks it is called with.
c
c     The code uses an MPI shared communicator to set the GPU device
c     number using the 'set device' ACC pragma.
c
c     This code assumes you launch it with the number of MPI ranks per
c     node = number of GPUs per node
c     (e.g. for a dual socket node with 4 GPUs: mpiexec -npersocket 2)
c
c     If this code works on a multi-node GPU system,
c     than (most likely) so will MAS!
c
c     Author:  Ronald M. Caplan
c
c     Predictive Science Inc.
c     www.predsci.com
c     San Diego, California, USA 92121
c
c Copyright 2022 Predictive Science Inc.
c
c Licensed under the Apache License, Version 2.0 (the "License");
c you may not use this file except in compliance with the License.
c You may obtain a copy of the License at
c
c    http://www.apache.org/licenses/LICENSE-2.0
c
c Unless required by applicable law or agreed to in writing, software
c distributed under the License is distributed on an "AS IS" BASIS,
c WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
c implied.
c See the License for the specific language governing permissions and
c limitations under the License.
c
      module number_types
c
        use iso_fortran_env
c
        implicit none
c
        integer, parameter :: r_typ=REAL64
c
      end module
      module types
       use number_types
       type :: vvec
         real(r_typ), dimension(:,:,:), allocatable :: r !(nrm,nt,np)
         real(r_typ), dimension(:,:,:), allocatable :: t !(nr,ntm,np)
         real(r_typ), dimension(:,:,:), allocatable :: p !(nr,nt,npm)
       end type
      end module
      module mpidefs
c
        implicit none
c
        include "mpif.h"
c ****** Total number of processors.
      integer :: nproc
c ****** Total number of processors per node.
      integer :: nprocsh
c ****** Processor rank of this process in communicator
c ****** MPI_COMM_WORLD.
      integer :: iprocw
c ****** comm_shared.
      integer :: iprocsh
c ****** Flag to designate that this is the processor with
c ****** rank 0 in communicator MPI_COMM_WORLD.
      logical :: iamp0
c ****** Communicator over all processors in the Cartesian topology.
      integer :: comm_all
c ****** COMM_ALL.
      integer :: iproc
c ****** Processor rank in communicator COMM_ALL for the
c ****** processor that has rank 0 in MPI_COMM_WORLD.
      integer :: iproc0
c ****** Communicators over all processors in the phi dimension.
      integer :: comm_phi
c ****** Communicator over all shared processors on the node.
      integer :: comm_shared
c ****** Communicators over all processors in the theta and phi
c ****** dimensions.
      integer :: comm_tp
c ****** Communicators over all processors in the r dimension.
      integer :: comm_r
c ****** Processor rank in communicator COMM_R of the processor
c ****** that contains the lower radial boundary r=R0.
      integer :: iproc_rb0
c ****** Processor coordinate indices of this process
c ****** in the Cartesian topology.
      integer :: iproc_r,iproc_t,iproc_p
c ****** Processor coordinate indices of the neighboring
c ****** processors in the Cartesian topology.
      integer :: iproc_rm,iproc_rp
      integer :: iproc_tm,iproc_tp
      integer :: iproc_pm,iproc_pp
c ****** Number of processors along r, theta, and phi.
      integer :: nproc_r,nproc_t,nproc_p
c ****** Number of processors in 2D theta-phi plane.
      integer :: nproc_tp
c ****** Processor coordinate indices in 2D theta-phi plane.
      integer :: iproc2d_tp
c ****** Number type for REALs to be used in MPI calls.
      integer :: ntype_real
      end module
      module decomposition_params
c
c-----------------------------------------------------------------------
c ****** Input parameters that define the domain decomposition
c ****** among processors.
c
      implicit none
c
c ****** Number of processors per dimension.
c
      integer, dimension(3) :: nprocs=(/-1,-1,-1/)
c
c ****** Number of mesh points per processor.
c
      integer, parameter :: mx_procs_per_dim=100
      integer, dimension(mx_procs_per_dim) :: mp_r=0
      integer, dimension(mx_procs_per_dim) :: mp_t=0
      integer, dimension(mx_procs_per_dim) :: mp_p=0
c
c ****** Mesh sizes for the "automatic" mesh decomposition.
c
      integer :: nr_auto
      integer :: nt_auto
      integer :: np_auto
c
      end module
      subroutine init_mpi
c
c
c ****** Initialize MPI.
c
c
      use number_types
      use mpidefs
c
c
      implicit none
c
c
c ****** MPI error return.
c
      integer :: ierr,tcheck
c
c
      call MPI_Init_thread (MPI_THREAD_FUNNELED,tcheck,ierr)
c
c ****** Get the total number of processors.
c
      call MPI_Comm_size (MPI_COMM_WORLD,nproc,ierr)
c
c ****** Get the index (rank) of the local processor in
c ****** communicator MPI_COMM_WORLD in variable IPROCW.
c
      call MPI_Comm_rank (MPI_COMM_WORLD,iprocw,ierr)
c
c ****** Create a shared communicator for all ranks in the node.
c
      call MPI_Comm_split_type (MPI_COMM_WORLD,MPI_COMM_TYPE_SHARED,0,
     &                          MPI_INFO_NULL,comm_shared,ierr)
c
c ****** Get the total number of processors in node.
c
      call MPI_Comm_size (comm_shared,nprocsh,ierr)
c
c ****** Get the index (rank) of the local processor in the local node.
c
      call MPI_Comm_rank (comm_shared,iprocsh,ierr)
c
c ****** Set the flag to designate whether this processor
c ****** has rank 0 in communicator MPI_COMM_WORLD.
c
      if (iprocw.eq.0) then
        iamp0=.true.
      else
        iamp0=.false.
      end if
c
      ntype_real=MPI_REAL8
c
      end subroutine
      subroutine check_proc_topology
c
c
c ****** Check/set the requested processor topology.
c
c
      use mpidefs
      use decomposition_params
c
c
      implicit none
c
c
      integer :: i,nreq
c
c
c ****** Set the optimal values of the topology for unset dimensions.
c
      call set_proc_topology
c
c ****** Check that the number of processors available
c ****** matches the number requested.
c
      nreq=nprocs(1)*nprocs(2)*nprocs(3)
c
      if (nreq.ne.nproc) then
        if (iamp0) then
          write (*,*)
          write (*,*) '### ERROR in CHECK_PROC_TOPOLOGY:'
          write (*,*) '### Processor topology specification error.'
          write (*,*) 'The number of processors requested does not'//
     &                ' equal the number available.'
          write (*,*) 'Number of processors requested = ',nreq
          write (*,*) 'Number of processors available = ',nproc
        end if
      end if
c
c ****** Set GPU device number for current rank.
c
!$acc set device_num(iprocsh)
c
      end subroutine
      subroutine set_proc_topology
c
c
c ****** Set the optimal values of the MPI rank topology
c ****** in dimensions not set by user.
c
c
      use number_types
      use mpidefs
c
c
      implicit none
c
c
      real(r_typ), parameter :: one=1.0_r_typ
      real(r_typ), parameter :: zero=0.0_r_typ
      real(r_typ), parameter :: bigval=HUGE(1.0_r_typ)
c
c
      integer, dimension(:), allocatable :: factors
      integer, dimension(:,:), allocatable :: rank_factors
      real(r_typ), dimension(:,:), allocatable :: nperrank
      real(r_typ), dimension(:), allocatable :: penalty
c
      integer :: i,j,k,fr,ft,fp,num_fac,num_rank_fac,best_idx
      real(r_typ) :: a12,a13,a23
c
c
c ****** Extract nproc values.  A value of -1 indicates the dimension
c ****** should be autoset.
c
      nproc_r=nprocs(1)
      nproc_t=nprocs(2)
      nproc_p=nprocs(3)
c
c ****** If no dimensions are to be autoset, return.
c
      if(nproc_r.ne.-1.and.nproc_t.ne.-1.and.nproc_p.ne.-1) return
c
c ****** Get all factors of nproc and store them in factors array.
c
      i=1
      num_fac=0
      do while(i.le.nproc)
        if (MOD(nproc,i).eq.0) then
          num_fac=num_fac+1
        end if
        i=i+1
      enddo
      allocate (factors(num_fac))
      i=1
      num_fac=0
          num_fac=num_fac+1
          factors(num_fac)=i
        end if
        i=i+1
      enddo
c
c ****** Set penalty function parameters and any fixed dimensions
c ****** based on which dimensions are to be autoset.
c
      a12=one
      a13=one
      a23=one
c
      if (nproc_r.ne.-1) then
        fr=nproc_r
        a12=zero
        a13=zero
      end if
      if (nproc_t.ne.-1) then
        ft=nproc_t
        a12=zero
        a23=zero
      end if
      if (nproc_p.ne.-1) then
        fp=nproc_p
        a13=zero
        a23=zero
      end if
c
c ****** Loop over all combinations of factors and save those that
c ****** yield the correct number of MPI ranks into rank_factors array.
c
      num_rank_fac=0
      do k=1,num_fac
        do j=1,num_fac
          do i=1,num_fac
            if(nproc_r.eq.-1) fr=factors(i)
            if(nproc_t.eq.-1) ft=factors(j)
            if(nproc_p.eq.-1) fp=factors(k)
            if (fr*ft*fp.eq.nproc) then
              num_rank_fac=num_rank_fac+1
            end if
          enddo
        enddo
      enddo
c
      if (num_rank_fac.eq.0) then
        if (iamp0) then
          write (*,*)
          write (*,*) '### ERROR in SET_PROC_TOPOLOGY:'
          write (*,*) 'No valid topologies found for selected options.'
          write (*,*) 'Number of MPI ranks = ',nproc
          write (*,*) 'NPROC_R = ',nproc_r
          write (*,*) 'NPROC_T = ',nproc_t
          write (*,*) 'NPROC_P = ',nproc_p
        end if
      end if
c
      allocate(rank_factors(num_rank_fac,3))
      allocate(nperrank(num_rank_fac,3))
      allocate(penalty(num_rank_fac))
c
      rank_factors(:,:)=-1
      penalty(:)=bigval
c
      num_rank_fac=0
      do k=1,num_fac
        do j=1,num_fac
          do i=1,num_fac
              rank_factors(num_rank_fac,1)=fr
              rank_factors(num_rank_fac,2)=ft
              rank_factors(num_rank_fac,3)=fp
            end if
          enddo
        enddo
      enddo
c
c ****** Get number of grid points per rank for each dimension.
c
c      nperrank(:,1)=real(nr_g)/rank_factors(:,1)
c      nperrank(:,2)=real(nt_g)/rank_factors(:,2)
c      nperrank(:,3)=real(np_g)/rank_factors(:,3)
c
c ****** Compute penalty function.
c
      penalty(:)=a12*(rank_factors(:,1)-rank_factors(:,2))**2
     &          +a23*(rank_factors(:,2)-rank_factors(:,3))**2
     &          +a13*(rank_factors(:,3)-rank_factors(:,1))**2
c
c ****** Eliminate any choices that yield less than a minimum number
c ****** of grid points per rank.
c
c      do i=1,num_rank_fac
c        if (nperrank(i,1).lt.4) penalty(i)=bigval
c        if (nperrank(i,2).lt.4) penalty(i)=bigval
c        if (nperrank(i,3).lt.3) penalty(i)=bigval
c      enddo
c
c ****** Find optimal topology.
c
      best_idx=MINLOC(penalty,1)
c
      if (penalty(best_idx).eq.bigval) then
        if (iamp0) then
          write (*,*)
          write (*,*) 'No valid topologies found for selected options'
          write (*,*) 'with selected grid.  '
          write (*,*) 'It is likely you are using too many MPI ranks.'
c          write (*,*) 'NR = ',nr_g
c          write (*,*) 'NT = ',nt_g
c          write (*,*) 'NP = ',np_g
        end if
      end if
c
c ****** Set optimal topology.
c
      nprocs(1)=rank_factors(best_idx,1)
      nprocs(2)=rank_factors(best_idx,2)
      nprocs(3)=rank_factors(best_idx,3)
c
      deallocate(factors)
      deallocate(rank_factors)
      deallocate(nperrank)
      deallocate(penalty)
c
      end subroutine
      subroutine decompose_domain
c
c
c ****** Decompose the domain into a Cartesian MPI topology.
c
c
      use number_types
      use mpidefs
c
c
      implicit none
c
c
      integer :: ierr
c
c
      integer, parameter :: ndim=3
      integer, dimension(ndim) :: coords
      logical, dimension(ndim) :: periodic
      logical :: reorder
      logical, dimension(ndim) :: keep_dim
c
c
c ****** Create a communicator over all processors, COMM_ALL,
c ****** that has a Cartesian topology.
c
c ****** Specify the periodicity of the coordinate system.
c
      periodic(1)=.false.
      periodic(2)=.false.
      periodic(3)=.true.
c
c ****** Allow re-ordering in the Cartesian topology.
c
      reorder=.true.
c
      call MPI_Cart_create (MPI_COMM_WORLD,ndim,nprocs,
     &                      periodic,reorder,comm_all,ierr)
c
c ****** communicator COMM_ALL in variable IPROC.
c
c ****** IMPORTANT NOTE:
c ****** If re-odering was allowed in the Cartesian topology
c ****** creation (above), then the rank of the local processor
c ****** in communicator COMM_ALL may be different from its rank
c ****** in communicator MPI_COMM_WORLD.
c
      call MPI_Comm_rank (comm_all,iproc,ierr)
c
c ****** Set the processor rank IPROC0 in communicator COMM_ALL
c ****** for the processor that has rank 0 in MPI_COMM_WORLD.
c ****** This value is broadcast to all the processors.
c
      if (iamp0) then
        iproc0=iproc
      end if
      call MPI_Bcast (iproc0,1,MPI_INTEGER,0,MPI_COMM_WORLD,ierr)
c
c ****** Get the coordinate indices of this processor in the
c ****** Cartesian MPI topology.
c
      call MPI_Cart_coords (comm_all,iproc,ndim,coords,ierr)
c
      iproc_r=coords(1)
      iproc_t=coords(2)
      iproc_p=coords(3)
c
      nproc_r=nprocs(1)
      nproc_t=nprocs(2)
      nproc_p=nprocs(3)
c
      nproc_tp=nproc_t*nproc_p
c
c ****** Get the rank of the neighboring processors in the
c
      call MPI_Cart_shift (comm_all,0,1,iproc_rm,iproc_rp,ierr)
      call MPI_Cart_shift (comm_all,1,1,iproc_tm,iproc_tp,ierr)
      call MPI_Cart_shift (comm_all,2,1,iproc_pm,iproc_pp,ierr)
c
c ****** Create communicators for operations involving all
c ****** processors in the phi dimension.  These communicators
c ****** are stored in COMM_PHI (and generally represent different
c ****** communicators on different processors).
c
      keep_dim(1)=.false.
      keep_dim(2)=.false.
      keep_dim(3)=.true.
c
      call MPI_Cart_sub (comm_all,keep_dim,comm_phi,ierr)
c
c ****** all processors in the theta and phi dimensions.
c ****** These communicators are stored in COMM_TP
c ****** (and generally represent different communicators on
c ****** different processors).
c ****** These communicators are used for operations that
c ****** involve radial planes.
c
      keep_dim(1)=.false.
      keep_dim(2)=.true.
      keep_dim(3)=.true.
c
      call MPI_Cart_sub (comm_all,keep_dim,comm_tp,ierr)
c
c ****** Get rank in the theta-phi communicator.
c ****** This is used for 2D IO.
c
      call MPI_Comm_rank (comm_tp,iproc2d_tp,ierr)
c
c ****** all processors in the r dimension.
c ****** These communicators are stored in COMM_R
c
      keep_dim(1)=.true.
      keep_dim(2)=.false.
      keep_dim(3)=.false.
c
      call MPI_Cart_sub (comm_all,keep_dim,comm_r,ierr)
c
      return
      end
      subroutine seam_vvec (v)
c
c
c ****** Seam the boundary points of a v vector between adjacent
c ****** processors.
c
c
      use number_types
      use types
      use mpidefs
c
c
      implicit none
c
c
      type(vvec) :: v
c
c
      real(r_typ),dimension(size(v%r,2),size(v%r,3)) :: sbuf11r,rbuf11r
      real(r_typ),dimension(size(v%r,2),size(v%r,3)) :: sbuf12r,rbuf12r
      real(r_typ),dimension(size(v%r,1),size(v%r,3)) :: sbuf21r,rbuf21r
      real(r_typ),dimension(size(v%r,1),size(v%r,3)) :: sbuf22r,rbuf22r
      real(r_typ),dimension(size(v%t,2),size(v%t,3)) :: sbuf11t,rbuf11t
      real(r_typ),dimension(size(v%t,2),size(v%t,3)) :: sbuf12t,rbuf12t
      real(r_typ),dimension(size(v%t,1),size(v%t,3)) :: sbuf21t,rbuf21t
      real(r_typ),dimension(size(v%t,1),size(v%t,3)) :: sbuf22t,rbuf22t
      real(r_typ),dimension(size(v%p,2),size(v%p,3)) :: sbuf11p,rbuf11p
      real(r_typ),dimension(size(v%p,2),size(v%p,3)) :: sbuf12p,rbuf12p
      real(r_typ),dimension(size(v%p,1),size(v%p,3)) :: sbuf21p,rbuf21p
      real(r_typ),dimension(size(v%p,1),size(v%p,3)) :: sbuf22p,rbuf22p
c
c
c
      integer :: ierr
c
c ****** MPI tags for MPI_ISEND and MPI_IRECV.
c
      integer :: tagr=0
      integer :: tagt=1
      integer :: tagp=2
c
c
      integer :: lbuf3r,lbuf3t,lbuf3p
      integer :: lbuf1r,lbuf1t,lbuf1p
      integer :: lbuf2r,lbuf2t,lbuf2p
      integer :: n1r,n2r,n3r,n1t,n2t,n3t,n1p,n2p,n3p
      integer :: req(12)
c
c
c ****** Get the dimensions of the arrays and buffer sizes:
c
      n1r=size(v%r,1);   n2r=size(v%r,2);   n3r=size(v%r,3)
      n1t=size(v%t,1);   n2t=size(v%t,2);   n3t=size(v%t,3)
      n1p=size(v%p,1);   n2p=size(v%p,2);   n3p=size(v%p,3)
c
      lbuf3r=n1r*n2r;    lbuf3t=n1t*n2t;    lbuf3p=n1p*n2p
      lbuf1r=n2r*n3r;    lbuf1t=n2t*n3t;    lbuf1p=n2p*n3p
      lbuf2r=n1r*n3r;    lbuf2t=n1t*n3t;    lbuf2p=n1p*n3p
c
c ****** Seam the third (periodic) dimension. Since seam data
c        is stride-1 in this case, no buffers are needed.
c
c ****** Launch async receives.
c
      call MPI_Irecv (v%r(:,:,  1),lbuf3r,ntype_real,iproc_pm,tagr,
     &                comm_all,req(1),ierr)
      call MPI_Irecv (v%r(:,:,n3r),lbuf3r,ntype_real,iproc_pp,tagr,
     &                comm_all,req(2),ierr)
      call MPI_Irecv (v%t(:,:,  1),lbuf3t,ntype_real,iproc_pm,tagt,
     &                comm_all,req(3),ierr)
      call MPI_Irecv (v%t(:,:,n3t),lbuf3t,ntype_real,iproc_pp,tagt,
     &                comm_all,req(4),ierr)
      call MPI_Irecv (v%p(:,:,  1),lbuf3p,ntype_real,iproc_pm,tagp,
     &                comm_all,req(5),ierr)
      call MPI_Irecv (v%p(:,:,n3p),lbuf3p,ntype_real,iproc_pp,tagp,
     &                comm_all,req(6),ierr)
c
c ****** Launch async sends.
c
      call MPI_Isend (v%r(:,:,n3r-1),lbuf3r,ntype_real,iproc_pp,tagr,
     &                comm_all,req(7),ierr)
      call MPI_Isend (v%r(:,:,    2),lbuf3r,ntype_real,iproc_pm,tagr,
     &                comm_all,req(8),ierr)
      call MPI_Isend (v%t(:,:,n3t-1),lbuf3t,ntype_real,iproc_pp,tagt,
     &                comm_all,req(9),ierr)
      call MPI_Isend (v%t(:,:,    2),lbuf3t,ntype_real,iproc_pm,tagt,
     &                comm_all,req(10),ierr)
      call MPI_Isend (v%p(:,:,n3p-1),lbuf3p,ntype_real,iproc_pp,tagp,
     &                comm_all,req(11),ierr)
      call MPI_Isend (v%p(:,:,    2),lbuf3p,ntype_real,iproc_pm,tagp,
     &                comm_all,req(12),ierr)
c
c ****** Wait for all seams to complete.
c
      call MPI_Waitall (12,req,MPI_STATUSES_IGNORE,ierr)
c
c ****** Seam the first dimension.
c
      if (nproc_r.gt.1) then
c
c ****** Load buffers.
c
!$acc kernels default(present)
        sbuf11r(:,:)=v%r(n1r-1,:,:)
        sbuf12r(:,:)=v%r(    2,:,:)
        sbuf11t(:,:)=v%t(n1t-1,:,:)
        sbuf12t(:,:)=v%t(    2,:,:)
        sbuf11p(:,:)=v%p(n1p-1,:,:)
        sbuf12p(:,:)=v%p(    2,:,:)
!$acc end kernels
c
        call MPI_Irecv (rbuf11r,lbuf1r,ntype_real,iproc_rm,tagr,
        call MPI_Irecv (rbuf12r,lbuf1r,ntype_real,iproc_rp,tagr,
        call MPI_Irecv (rbuf11t,lbuf1t,ntype_real,iproc_rm,tagt,
        call MPI_Irecv (rbuf12t,lbuf1t,ntype_real,iproc_rp,tagt,
        call MPI_Irecv (rbuf11p,lbuf1p,ntype_real,iproc_rm,tagp,
        call MPI_Irecv (rbuf12p,lbuf1p,ntype_real,iproc_rp,tagp,
c
c
        call MPI_Isend (sbuf11r,lbuf1r,ntype_real,iproc_rp,tagr,
        call MPI_Isend (sbuf12r,lbuf1r,ntype_real,iproc_rm,tagr,
        call MPI_Isend (sbuf11t,lbuf1t,ntype_real,iproc_rp,tagt,
        call MPI_Isend (sbuf12t,lbuf1t,ntype_real,iproc_rm,tagt,
        call MPI_Isend (sbuf11p,lbuf1p,ntype_real,iproc_rp,tagp,
        call MPI_Isend (sbuf12p,lbuf1p,ntype_real,iproc_rm,tagp,
c
c
c
c ****** Unload buffers.
c
        if (iproc_rm.ne.MPI_PROC_NULL) then
           v%r(1,:,:)=rbuf11r(:,:)
           v%t(1,:,:)=rbuf11t(:,:)
           v%p(1,:,:)=rbuf11p(:,:)
        end if
        if (iproc_rp.ne.MPI_PROC_NULL) then
           v%r(n1r,:,:)=rbuf12r(:,:)
           v%t(n1t,:,:)=rbuf12t(:,:)
           v%p(n1p,:,:)=rbuf12p(:,:)
        end if
!$acc end kernels
c
      end if
c
c ****** Seam the second dimension.
c
      if (nproc_t.gt.1) then
c
        sbuf21r(:,:)=v%r(:,n2r-1,:)
        sbuf22r(:,:)=v%r(:,    2,:)
        sbuf21t(:,:)=v%t(:,n2t-1,:)
        sbuf22t(:,:)=v%t(:,    2,:)
        sbuf21p(:,:)=v%p(:,n2p-1,:)
        sbuf22p(:,:)=v%p(:,    2,:)
!$acc end kernels
c
        call MPI_Irecv (rbuf21r,lbuf2r,ntype_real,iproc_tm,tagr,
        call MPI_Irecv (rbuf22r,lbuf2r,ntype_real,iproc_tp,tagr,
        call MPI_Irecv (rbuf21t,lbuf2t,ntype_real,iproc_tm,tagt,
        call MPI_Irecv (rbuf22t,lbuf2t,ntype_real,iproc_tp,tagt,
        call MPI_Irecv (rbuf21p,lbuf2p,ntype_real,iproc_tm,tagp,
        call MPI_Irecv (rbuf22p,lbuf2p,ntype_real,iproc_tp,tagp,
c
c
        call MPI_Isend (sbuf21r,lbuf2r,ntype_real,iproc_tp,tagr,
        call MPI_Isend (sbuf22r,lbuf2r,ntype_real,iproc_tm,tagr,
        call MPI_Isend (sbuf21t,lbuf2t,ntype_real,iproc_tp,tagt,
        call MPI_Isend (sbuf22t,lbuf2t,ntype_real,iproc_tm,tagt,
        call MPI_Isend (sbuf21p,lbuf2p,ntype_real,iproc_tp,tagp,
        call MPI_Isend (sbuf22p,lbuf2p,ntype_real,iproc_tm,tagp,
c
c
c
c
        if (iproc_tm.ne.MPI_PROC_NULL) then
           v%r(:,1,:)=rbuf21r(:,:)
           v%t(:,1,:)=rbuf21t(:,:)
           v%p(:,1,:)=rbuf21p(:,:)
        end if
        if (iproc_tp.ne.MPI_PROC_NULL) then
           v%r(:,n2r,:)=rbuf22r(:,:)
           v%t(:,n2t,:)=rbuf22t(:,:)
           v%p(:,n2p,:)=rbuf22p(:,:)
        end if
!$acc end kernels
c
      end if
c
      end subroutine
      program psi_multigpu_test_code
c
      use number_types
      use types
      use mpidefs
c
c
      implicit none
c
c
      integer :: nr,nt,np
      integer :: i,j,k,ierr
      integer, parameter :: n_per_dim=6
      type(vvec), target :: v
c
      call init_mpi
c
c ****** Set the resolution for each MPI rank
c
      nr = n_per_dim
      nt = n_per_dim
      np = n_per_dim
c
      nprocs(1)=-1
      nprocs(2)=-1
      nprocs(3)=-1
c
      if (iamp0) then
        print*, 'Grid size per dimension per rank: ',n_per_dim
        print*, 'Grid size per rank: ',n_per_dim**3
        print*,' '
      endif
c
c ****** Check/set the processor topology.
c
      call check_proc_topology
c
      call decompose_domain
c
      if (iamp0) then
        print*, 'Number of ranks in DIM1: ',nproc_r
        print*, 'Number of ranks in DIM2: ',nproc_t
        print*, 'Number of ranks in DIM3: ',nproc_p
        print*, 'Total number of ranks: ',nproc
        print*,' '
      endif
c
      write(*,'(5(a,i3),a)'),'World rank ',iprocw,
     &' has cart rank ',iproc,
     &' and shared rank ',iprocsh,' (i.e. GPU device number ',
     & iprocsh+1,' out of ',nprocsh,')'
c
      allocate(v%r(nr-1,nt,np))
      allocate(v%t(nr,nt-1,np))
      allocate(v%p(nr,nt,np-1))
c
!$acc parallel default(present)
!$acc loop collapse(3)
      do k=1,np
        do j=1,nt
          do i=1,nr-1
            v%r(i,j,k)=iproc
          enddo
        enddo
      enddo
      do k=1,np
        do j=1,nt-1
          do i=1,nr
            v%t(i,j,k)=iproc
          enddo
        enddo
      enddo
      do k=1,np-1
        do j=1,nt
          do i=1,nr
            v%p(i,j,k)=iproc
          enddo
        enddo
      enddo
!$acc end parallel
c
      call seam_vvec (v)
c
      if (iamp0) then
        print*, "vr(:,:,1):", v%r(:,:,1)
        print*, "vr(:,:,2):", v%r(:,:,2)
        print*, "vr(:,:,np-1):", v%r(:,:,np-1)
        print*, "vr(:,:,np):", v%r(:,:,np)
      end if
c
      deallocate(v%r,v%t,v%p)
c
      call MPI_Finalize (ierr)
c
      end program
Code 2 compiled with “mpif90 -O3 -march=native -acc=gpu -gpu=cc60,cc70,cc80,managed test.f”
c
c
c
c
c
c
c
c
c
c     www.predsci.com
c
c
c
c
c implied.
c
      module number_types
c
        use iso_fortran_env
c
        implicit none
c
c
      end module
      module types
       use number_types
       type :: vvec
       end type
      end module
      module mpidefs
c
        implicit none
c
        include "mpif.h"
      integer :: nproc
      integer :: nprocsh
      integer :: iprocw
      integer :: iprocsh
      logical :: iamp0
      integer :: comm_all
c ****** COMM_ALL.
      integer :: iproc
      integer :: iproc0
      integer :: comm_phi
      integer :: comm_tp
      integer :: comm_r
      integer :: nproc_tp
      end module
c
c
      implicit none
c
c
c
c
c
c
      integer :: nr_auto
      integer :: nt_auto
      integer :: np_auto
c
      end module
      subroutine init_mpi
c
c
c
c
      use number_types
      use mpidefs
c
c
      implicit none
c
c
c
c
c
c
c
c
c
c
c
c
c
c
c
c
c
        iamp0=.true.
      else
        iamp0=.false.
      end if
c
c
      end subroutine
c
c
c
c
      use mpidefs
c
c
      implicit none
c
c
      integer :: i,nreq
c
c
c
c
c
c
        if (iamp0) then
          write (*,*)
        end if
      end if
c
c
c
      end subroutine
c
c
c
c
      use number_types
      use mpidefs
c
c
      implicit none
c
c
c
c
c
c
c
c
      nproc_r=nprocs(1)
      nproc_t=nprocs(2)
      nproc_p=nprocs(3)
c
c
c
c
      i=1
      num_fac=0
          num_fac=num_fac+1
        end if
        i=i+1
      enddo
      i=1
      num_fac=0
          num_fac=num_fac+1
          factors(num_fac)=i
        end if
        i=i+1
      enddo
c
c
      a12=one
      a13=one
      a23=one
c
        fr=nproc_r
        a12=zero
        a13=zero
      end if
        ft=nproc_t
        a12=zero
        a23=zero
      end if
        fp=nproc_p
        a13=zero
        a23=zero
      end if
c
c
      num_rank_fac=0
      do k=1,num_fac
        do j=1,num_fac
          do i=1,num_fac
            end if
          enddo
        enddo
      enddo
c
        if (iamp0) then
          write (*,*)
        end if
      end if
c
c
      penalty(:)=bigval
c
      num_rank_fac=0
      do k=1,num_fac
        do j=1,num_fac
          do i=1,num_fac
            end if
          enddo
        enddo
      enddo
c
c
c
c
c
c
c      enddo
c
c
c
        if (iamp0) then
          write (*,*)
        end if
      end if
c
c
c
      deallocate(factors)
      deallocate(penalty)
c
      end subroutine
c
c
c
c
      use number_types
      use mpidefs
c
c
      implicit none
c
c
      integer :: ierr
c
c
      logical :: reorder
c
c
c
c
      periodic(1)=.false.
      periodic(2)=.false.
      periodic(3)=.true.
c
c
      reorder=.true.
c
c
c
c
c
c
      if (iamp0) then
        iproc0=iproc
      end if
c
c
c
      iproc_r=coords(1)
      iproc_t=coords(2)
      iproc_p=coords(3)
c
      nproc_r=nprocs(1)
      nproc_t=nprocs(2)
      nproc_p=nprocs(3)
c
c
c
c
c
      keep_dim(1)=.false.
      keep_dim(2)=.false.
      keep_dim(3)=.true.
c
c
c
      keep_dim(1)=.false.
      keep_dim(2)=.true.
      keep_dim(3)=.true.
c
c
c
c
c
      keep_dim(1)=.true.
      keep_dim(2)=.false.
      keep_dim(3)=.false.
c
c
      return
      end
c
c
c
c
      use number_types
      use types
      use mpidefs
c
c
      implicit none
c
c
      type(vvec) :: v
c
c
c
c
c
      integer :: ierr
c
c
      integer :: tagr=0
      integer :: tagt=1
      integer :: tagp=2
c
c
      integer :: req(12)
c
c
c
c
c
c
c
c
c
c
c
c
c
c
c
!$acc end kernels
c
c
c
c
c
c
c
        end if
        end if
!$acc end kernels
c
      end if
c
c
c
!$acc end kernels
c
c
c
c
c
c
c
        end if
        end if
!$acc end kernels
c
      end if
c
      end subroutine
c
      use number_types
      use types
      use mpidefs
c
c
      implicit none
c
c
      integer :: nr,nt,np
c
      call init_mpi
c
c
      nr = n_per_dim
      nt = n_per_dim
      np = n_per_dim
c
      nprocs(1)=-1
      nprocs(2)=-1
      nprocs(3)=-1
c
      if (iamp0) then
        print*,' '
      endif
c
c
c
c
      if (iamp0) then
        print*,' '
      endif
c
c
c
      do k=1,np
        do j=1,nt
          do i=1,nr-1
            v%r(i,j,k)=iproc
          enddo
        enddo
      enddo
      do k=1,np
        do j=1,nt-1
          do i=1,nr
            v%t(i,j,k)=iproc
          enddo
        enddo
      enddo
      do k=1,np-1
        do j=1,nt
          do i=1,nr
            v%p(i,j,k)=iproc
          enddo
        enddo
      enddo
!$acc end parallel
c
      call seam_vvec (v)
c
      if (iamp0) then
      end if
c
c
c
      end program
Code 3 compiled with “mpif90 -O3 -march=native -stdpar=gpu -gpu=cc60,cc70,cc80 test.f”
c
c
c
c
c
c
c
c
c
c     www.predsci.com
c
c
c
c
c implied.
c
      module number_types
c
        use iso_fortran_env
c
        implicit none
c
c
      end module
      module types
       use number_types
       type :: vvec
       end type
      end module
      module mpidefs
c
        implicit none
c
        include "mpif.h"
      integer :: nproc
      integer :: nprocsh
      integer :: iprocw
      integer :: iprocsh
      logical :: iamp0
      integer :: comm_all
c ****** COMM_ALL.
      integer :: iproc
      integer :: iproc0
      integer :: comm_phi
      integer :: comm_tp
      integer :: comm_r
      integer :: nproc_tp
      end module
c
c
      implicit none
c
c
c
c
c
c
      integer :: nr_auto
      integer :: nt_auto
      integer :: np_auto
c
      end module
      subroutine init_mpi
c
c
c
c
      use number_types
      use mpidefs
c
c
      implicit none
c
c
c
c
c
c
c
c
c
c
c
c
c
c
c
c
c
        iamp0=.true.
      else
        iamp0=.false.
      end if
c
c
      end subroutine
c
c
c
c
      use mpidefs
c
c
      implicit none
c
c
      integer :: i,nreq
c
c
c
c
c
c
        if (iamp0) then
          write (*,*)
        end if
      end if
c
c
c
      end subroutine
c
c
c
c
      use number_types
      use mpidefs
c
c
      implicit none
c
c
c
c
c
c
c
c
      nproc_r=nprocs(1)
      nproc_t=nprocs(2)
      nproc_p=nprocs(3)
c
c
c
c
      i=1
      num_fac=0
          num_fac=num_fac+1
        end if
        i=i+1
      enddo
      i=1
      num_fac=0
          num_fac=num_fac+1
          factors(num_fac)=i
        end if
        i=i+1
      enddo
c
c
      a12=one
      a13=one
      a23=one
c
        fr=nproc_r
        a12=zero
        a13=zero
      end if
        ft=nproc_t
        a12=zero
        a23=zero
      end if
        fp=nproc_p
        a13=zero
        a23=zero
      end if
c
c
      num_rank_fac=0
      do k=1,num_fac
        do j=1,num_fac
          do i=1,num_fac
            end if
          enddo
        enddo
      enddo
c
        if (iamp0) then
          write (*,*)
        end if
      end if
c
c
      penalty(:)=bigval
c
      num_rank_fac=0
      do k=1,num_fac
        do j=1,num_fac
          do i=1,num_fac
            end if
          enddo
        enddo
      enddo
c
c
c
c
c
c
c      enddo
c
c
c
        if (iamp0) then
          write (*,*)
        end if
      end if
c
c
c
      deallocate(factors)
      deallocate(penalty)
c
      end subroutine
c
c
c
c
      use number_types
      use mpidefs
c
c
      implicit none
c
c
      integer :: ierr
c
c
      logical :: reorder
c
c
c
c
      periodic(1)=.false.
      periodic(2)=.false.
      periodic(3)=.true.
c
c
      reorder=.true.
c
c
c
c
c
c
      if (iamp0) then
        iproc0=iproc
      end if
c
c
c
      iproc_r=coords(1)
      iproc_t=coords(2)
      iproc_p=coords(3)
c
      nproc_r=nprocs(1)
      nproc_t=nprocs(2)
      nproc_p=nprocs(3)
c
c
c
c
c
      keep_dim(1)=.false.
      keep_dim(2)=.false.
      keep_dim(3)=.true.
c
c
c
      keep_dim(1)=.false.
      keep_dim(2)=.true.
      keep_dim(3)=.true.
c
c
c
c
c
      keep_dim(1)=.true.
      keep_dim(2)=.false.
      keep_dim(3)=.false.
c
c
      return
      end
c
c
c
c
      use number_types
      use types
      use mpidefs
c
c
      implicit none
c
c
      type(vvec) :: v
c
c
c
c
c
      integer :: ierr
c
c
      integer :: tagr=0
      integer :: tagt=1
      integer :: tagp=2
c
c
      integer :: req(12)
c
c
c
c
c
c
c
c
c
c
c
c
c
c
c
!$acc end kernels
c
c
c
c
c
c
c
        end if
        end if
!$acc end kernels
c
      end if
c
c
c
!$acc end kernels
c
c
c
c
c
c
c
        end if
        end if
!$acc end kernels
c
      end if
c
      end subroutine
c
      use number_types
      use types
      use mpidefs
c
c
      implicit none
c
c
      integer :: nr,nt,np
c
      call init_mpi
c
c
      nr = n_per_dim
      nt = n_per_dim
      np = n_per_dim
c
      nprocs(1)=-1
      nprocs(2)=-1
      nprocs(3)=-1
c
      if (iamp0) then
        print*,' '
      endif
c
c
c
c
      if (iamp0) then
        print*,' '
      endif
c
c
c
      do concurrent (k=1:np, j=1:nt, i=1:nr-1)
        v%r(i,j,k)=iproc
      enddo
      do concurrent (k=1:np, j=1:nt-1, i=1:nr)
        v%t(i,j,k)=iproc
      enddo
      do concurrent (k=1:np-1, j=1:nt, i=1:nr)
        v%p(i,j,k)=iproc
      enddo
c
      call seam_vvec (v)
c
      if (iamp0) then
      end if
c
c
c
      end program
  • Miko
Hi Miko,
CUDA Unified Memory is currently only available for dynamically allocated memory. So while the allocatable members in the type will be placed in UM, “v” is a static object hence will not.
The creation and copying of “v” to the device can either be done explicitly, as you do in test2, or implicitly by the compiler as is done in test3. The problem with test1 is the use of “default(present)” which will disable the implicit copy and instead do a runtime check if the variable is present, giving an error (as is the case here) if it is not. To have test1 match the behavior of test3, remove the “default(present)” clauses.
-Mat
I assume scalars are a special case since default(present) does not check for them on the device?
On another related note - I had thought that UM only works with dynamically allocated arrays (as you mention) but in our codes, we have static local arrays (e.g. real, dimension(N) :: array1) and when UM is turned on - they all work fine.
Is the NV compiler by default using the equivalent to the Intel compiler’s -heap-arrays and putting even local static arrays on the heap instead of the stack, and the UM is then active for them?
– Ron
Scalars are first private by default.
Are the arrays really static (i.e. fixed size at compilation) or are they automatics? Automatics are implicitly allocated upon entry into the routine. On the heap by default, or on the stack if “-mp” or “-Mstack_arrays” is used. If they are fixed, the compiler is probably implicitly copying them upon entry into to compute region. This is the same as OpenACC when not using data regions.
Yes - I suppose they are “automatics” since “N” is not set until runtime.
We do have some arrays that are “fixed” size but they might not be being used in compute regions (actually I think we use “declare create” on them).
Thanks for the info!
– Ron
