- the subject basically says everything. How can I detect NaN in a kernel? CUDA appears to have a library function[1], but I can’t figure out how to access it.
(my_value .NE. my_value)
returns False also for NaN value, so that approach doesn’t seem to work.
Some background on this: I may have found a bug that would lead to an unspecified launch failure if and only if an array is passed in after a NaN is being passed by value. I want to include some safety check for NaNs in the debug mode of my kernel code generator, such that these kinds of errors can be found quickly.
http://developer.download.nvidia.com/compute/cuda/4_1/rel/toolkit/docs/online/group__CUDA__MATH__DOUBLE_gf9a5caca44978ea06bfcd2345032e5b8.html[/code]
Hi MuellerM,
You can call CUDA C routines by adding an interface. Here’s an example of calling “isnan”. The only difficulty is determining what the CUDA C name is. In this case I had to go look through the CUDA C header files since “isnan” gets preprocessed to the particular routine depending upon data type.
Hope this helps,
Mat
% cat test.cuf
module bar
use cudafor
use iso_c_binding
real(8), dimension(:), allocatable, device :: Xd
real(8), dimension(:), allocatable :: X
interface
attributes(device) function isnan(a) bind(C,name="__isnand")
use iso_c_binding
integer(c_int) :: isnan
real(c_double), value :: a
end function isnan
end interface
contains
attributes(global) subroutine setnan (val)
use iso_c_binding
real(8),value :: val
integer :: idx
integer(c_int) :: nan
idx = (blockidx%x-1)*blockdim%x + threadidx%x
nan = isnan(val)
Xd(idx) = dble(nan)
end subroutine
end module bar
program foo
use cudafor
use bar
real(8) val
val=sqrt(-1.0)
print *, "VAL=", val
allocate(X(1),Xd(1))
call setnan<<<1,1>>>(val)
X=Xd
print *, "ISNAN? ", X
val=sqrt(10.0)
X=Xd
end program foo
% pgf90 test.cuf; a.out
VAL= NaN
ISNAN? 1.000000000000000
VAL= 3.162277698516846
ISNAN? 0.000000000000000
Great, thanks a lot for your time!
What if I want to use isnan function in C inside an Openacc kernel? I tried with isnan function from math.h but it is not recognized. So how can i solve it?
Hi jcastro9999,
We have an open feature request (TPR#21342) for isnan, as well as isfinite, isinf, isnormal, etc., but haven’t added this support to the compiler. I’ll add your request to this TPR and see about increasing the priority.
-Mat
